Question about Bosch Axxis WFL 2060 Front Load Washer
Gets stuck midway in the cycle and gives a code 3
  • Mark MacDonald
    Mark MacDonald Jul 05, 2010
    Hi welcome to Fixya.
    Can you varify the model of your Bosch washer as they have distinct error codes from model to model.
    Once done that I should be able to help.
    Thanks.
    macmarkus :)
  • Bosch Master
  • 2,605 Answers
Hello rmurray1, welcome to Fixya.
First off, I don't think the model number in the post is correct as the WFL2060 only gives flashing L.E.D. for error codes, so I suspect it is likely a WFR2460 or other that does have an L.E.D. display for digital error codes.
If you could confirm your model number it could save a lot of potentially reduntant questions and answer's.
Based on what you've described "stuck midway in the cycle and gives a code 3" you've got an issue with the door lock, at least as detected by the control.
This means there may or may not be a problem. The first step is to unplug the unit from either your dryer or the wall, whatever the case may be in your set up.
Leave it unplugged for several minutes and plug it in again. Try the machine though a cycle with no items/clothing in it and see how it goes.
Let me know what you find and we can move forward from there.
Thanks for visiting "fixya" and good luck.
If this indeed solved your problem please take a second to rate the info and leave a testimony accordingly. If more assistance is required, let me know.
macmarkus :)
Posted on Jul 07, 2010
Samsung get stuck at 40 minute cycle
I think the dishwasher gets stuck at the point where it is supposed to heat the water. If it can't heat the water (because the heating element isn't working, or because the heater relay inside the controller is bad), then it may stay there indefinately. In other dishwashers, the timer/controller will give up after 3 or 4 hours and finish the cycle. In others, the dishwasher will shut down and indicate an error condition.
Sep 20, 2014 | Samsung 24 in. DB5710DT Stainless Steel...
What might cause a flashing PF code midway through a cycle? Circuit breaker is fine. Any advice greatly appreciated.
Stop trying to restart it! There is obviously a fault so check your manual. If not in there contact Manufacturer or service agent.
Aug 10, 2014 | Frigidaire Dishwashers
Washer shut down midway through cycle, will not power back up
Sometimes things can get out of sync. Try unplugging the machine for a few hours to rest the code on the board.
Oct 15, 2013 | Fisher and Paykel IWL12 Top Load Washer
John lewis integrated dishwasher
make this test and fix it. God bless you
Float Switch
The float switch may be hung up and this can cause the dishwasher to be stuck in a cycle.
Timer / Control
If your dishwasher gets stuck in a cycle first try shutting off the breaker for at least 5 minutes if this does not correct the problem you will need to replace timer/control board
Jul 24, 2013 | John Lewis JLBIDWS1804 Builtin Dishwasher
Hoshizaki km-1300skf 3 beep error code
The 3 beeps indicates that the freeze cycle is longer than 60 minutes. with the suction pressure at 20, it sounds like low on charge (freon). I believe this is an R 404-A unit. Other things to look for are: Stuck float switch (in the up position), Water valve leaking, hot gas valve leaking, txv not feeding properly, weak compressor. Look at high side pressure too. It should not go below 210 psi during the freeze cycle. Low pressure should be in the middle to upper 40's psi.
Let me know if you need more.
Jan 02, 2009 | Freezers
Stuck in update cycle
hi do you have channels that r working, if not its because you need to update the codes, if this is the case if you let me no what network ie telewest i will give you the updated codes
Jul 12, 2008 | StarTech.com StarView SV211K 2-port KVM...
Cycle stops, won't drain
This is either a bad timer or a bad heat sensor. On most cycles that call for the water to be heated it will pause the timer and continue washing/heating until the sensor is satisfied the water is hot enough. Try selecting a quick, delicate, or china cycle without heated rinse or dry. If it works this way the timer is fine but the sensor is bad. Sometimes cold water to the machine will cause this problem because the machine is not capable of totallly heating cold water. It is only designed to boost the temp. Make sure you run hot water at the sink before you start the machine.
Jul 03, 2008 | GE Nautilus 24" Built-in Dishwasher
Error Code FL
it is saying failed to lock the door need door latch switch part # 22003269
Apr 13, 2008 | Maytag Neptune MAH5500B Front Load Washer
Kenmore elite he4t
CHECK DRAIN HOSE coming from washer TO ENSURE WATER IS DRAINING PROPERLY down drain.
USUALLY YOU CAN RAISE DRAIN HOSE A LITTE AND RESET WASHER TO RINSE & SPIN F6 is caused by water not draining Fast Enough
Dec 12, 2007 | Kenmore Elite 45986 Front Load Washer
Bosch Axxis WFL 2060 Front Load Washer Logo
171 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
