Question about kawasaki Full Suspension Mountain Bike Men
How to change the oil in a 2000 Kawasaki Jet ski. The oil is black when it comes out and it will not stay on
    President:
  • 1,978 Answers
You can purchase a cheap pump that will work off a drill, or a hand pumper. You will have to pump the oil out of the motor into a container, change the filter, and be careful not to overfill the engine when putting the new oil back in with a funnel. It is possible that the motor is not staying on because the oil level is low. Some machines have on oil level sensor that turns them off when the level is too low.
Posted on Sep 10, 2010
What is the gas-oil ratio mixture for a 1995 kawasaki jh750-a4 jet ski
50 to 1 that is 2.5 ounces to the gallon for pleasure riding
40 to 1 that is 3.2 ounces to the gallon for racing
May 09, 2015 | kawasaki 2010 Jet Ski Ultra 260X
Oil change
Ask the dealer if this affects the warranty.
Nov 28, 2013 | kawasaki 2010 Jet Ski Ultra 260X
What oil and how to you check it in a 93 kawsaki 750 jet ski, not engine oil the transmission oil
Your 750 jet ski does not have a gear box. If you are referring to what looks like a filler cap on the front of the motor, that is the generator/flywheel cover and it is a dry compartment and should remain that way.
Jun 11, 2011 | Encore Software Kawasaki Jet Ski...
IF THE OIL TANK IS GONE CAN YOU RUN A JET SKI IF YOU MIX THE GAS AND OIL
Yes , the mix is the same as a standard out board motor. Pre-mix your gas oil mixture at a 50-1 ratio.
Feb 15, 2011 | Monkey Byte Development Kawasaki Jet Ski...
Jet ski bogs out under load.
I had a similar experience with that model. It turned out to be a mouse nest in the water box. However , in this case i think you just have some moisture corrosion on the rubber tipped needle in the carburetor. Clean that part of the carb and do not alter the tiny spring in any way. If that does not work open the electronics box, if it is wet , dry it out , and seal it back up. Those are the three things I know of that will cause your problem. Start with the carb.
Apr 06, 2010 | Encore Software Kawasaki Jet Ski...
1995 kawasaki jet ski guages wont work is there a fuse somewhere that i am not finding?
There is/are fuses in the electronics box. Most ski's have just one main fuse for the whole machine. I suggest unplugging all the wire connections and plugging them back in, you probably just have a problem with continuity. If the gauges are all bad , you might find a good used set on EBAY. Just remember the gauges are pretty and cool but not really necessary as long as you fill your oil tank before riding and drive with the fuel petcock in the ON position.
Mar 14, 2010 | Encore Software Kawasaki Jet Ski...
kawasaki Full Suspension Mountain Bike Men Logo
157 people viewed this question
Top kawasaki Sport & Outdoor - Others Experts
Phillip Edwin
Level 1 Expert
michael
michael
Are you a kawasaki Sport and Outdoor - Other Expert? Answer questions, earn points and help others
