Question about Acer Aspire 5610-4648 Notebook
THE MEMORY CANT BE READ
HI , I HAVE ACER 5600 AND WHEN I TURN IT ON IT SHOWS A MSG SAID THAT THE MEMORY CANT BE READ THEN IT SHUT DOWN THE SECOND THING THAT IF I WANT TO DOWNLOAD ANY PROGRAMS IT SUDDENLY SHUT DOWN , WHAT TO DO ?
    Sergeant:
  • 228 Answers
Boot into the BIOS (setup) and see if your computer has a memory test in it. if so, run it.
Also you can open the memory bay and remove and reset the memory card and make sure it's seated right. It has 2 clips on the side of it, spread them and it will "pop up" to a 30 degree angle and you can just pull it out. Then press it back in until it locks, and see if you still have a problem.
You can also try that memory in another laptop and see if it causes the problem in another machine...then you will know if you have a memory issue, or an operating system issue. If you get the message from the BIOS (before windows loads) as the system is booting, the memory is probably bad. Just go get another one at Fry's. (or whatever computer store you have) or you can get online at Crucial.com, or some other site. There are a million places to get memory. eBay is also good if funds are tight.
Please put the exact error message you get.
If this post has helped, please vote.
Posted on Jul 05, 2010
    Guru:
  • 366 Answers
You need to go into control panel then display then screensaver.Click on power make sure your power off settings are correct.For system standby set to never.Then click advanced at the top make sure those settings are correct
you also want to click on hibernate and make sure there is no check mark in enabling hibernate.
Click apply restart and then see what happens.
or
If the the laptop is failing to boot very early in the4 boot sequence, then this usually points to a failure somewhere on the motherboard. There are a few test you can run to try.
1) Try downloading the following Diagnostic program and running it on your computer. The download makes a bootable CD, and you can try running a bunch of diagnostics on your computer with out having to boot into Windows. You can test memory, the hard drive, and other things.
http://www.ultimatebootcd.com/
2) Try replacing the memory. Sometimes bad memory can cause a device not to boot.
3) If neither of the above suggestions work, then I'm afraid you will need a new motherboard.
THE MEMORY CANT BE READ - blank.gifblank.gifblank.giTHE MEMORY CANT BE READ - blank.gif blank.gifblank.gifblank.gif
Hello !! i have an acer aspire 5600 and the problem is that i cant power it on .without battery there is a light on charger but nowhere on laptop. when i put the battery it power on for a while and then it...
If you can not power it up without the battery then you have a bad charger.
The battery has just enough life to turn it on and then shuts it down due to a weak battery.
If you are going to buy a charger I recommend you take your computer in with you and make sure you can power it on without the battery.
Mar 28, 2011 | Acer Aspire 5600 Series 5610-2013 Notebook
Always show msg memmory full ,cant change default memory from sim
there some msg in your phone give it to your phone memory full you check it.
Mar 01, 2010 | Samsung S3650 Corby / S3650 Genio Touch...
Laptop keeps rebooting.
It can be a hardware problem (defective memory) or a software problem (defective OS) and/or virus infection.
Dec 01, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Acer 5630
reload the operating system
Nov 30, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
I am trying to reboot my acer laptop
have you tried configuring the BIOS to its default setting or setting it to its optimized default. and then restart. if still doesn't work out change the CMOS battery. if you need driver try this website  www.driver.com
Acer aspire 5600 shut down
the only way you can upgrade the graphics on a laptop is to purchase a graphics accelerator card that plugs in to the usb slot, its not an upgrade as such but it will allow you to play high res games on the laptop, there would have to be a memory upgrade to go with that also
Nvidia are doing some good laptop accelerators at the moment but they are expensive!!!
kind regards
Nov 17, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
it sounds like the video card cannot support or handle the pressure put on it by the game you are trying to play, if it is an OEM game have a look for the minium system requirements that the game will run on, you can also find this information on line, you will probably find out that the graphics card doesn't support the game, do this check with all games you try to play
another thing is to upgrade your memory because some laptops don't have a devoted graphics card thus they are relient on the system memory
good luck
Nov 16, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
5600 aspire shut down prob.
the problem is not your hard drive, if you are using vista then there are compatbility issues with certain programmes, if yoou are using XP all you need to do is download the latest codecs, this also goes for vista, try not to use XP programmes with vista because you will run into problems
Cant shut down
keep start button pressed 30 seconds, the pc should turn off. If not brutally unplug the power cable. Do a scan disk on restart.
Feb 16, 2008 | Acer Aspire™ T180 PC Desktop
Acer Aspire 5610-4648 Notebook Logo
47 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
