Question about Refrigerators
H i have an HJA6100 sideby side fridge since seting up t doesnt make ice and theirn is a flashing error code E8. i hae checked all set up it dispences cold wwater but no water fills the ice maker tray and then maes the ice . any ideas?
I have Leisure Refrigerator HJA6100 with the error code E8 flashing up. Any ideas what the problem could be?
Posted on Aug 11, 2011
My Samsung refrigerator Model RFG297HDRS-XAA has 15-E code flashing.
Existing error codes for Samsung fridges run from 1 up to 13, in the majority of models as far as I could find out.
You might be having two error codes instead of one code
error 1 and Error 5.
Error 1 refers to 1. Ice Maker Sensor:
Ice Maker sensor connector missing, contact failure, electric wire cut, short-circuit, Ice Maker sensor failure.
Indicates an error when the temperature sensed by Ice Maker sensor is higher than 150 or lower than -58.
Error 5 refers to 5. Ice Maker Function Error:
Ice ejector and level failed three times or more.
Jul 12, 2017 | Samsung Refrigerators
Hi. I have an E8 error code flashing on the freezer side of my leisure fridge freezer model APL13963B. Any ideas please
This error code is caused by a defective Ice Maker sensor. It is a common failure in this make and model. It is located behind the ice maker assembly which must be removed to replace the faulty part. As to whether this will fix all the problems I can only guess and say not sure. Cost to replace the part would be at least $150.00 USD
Jul 18, 2016 | Refrigerators
Electrolux icon side by side fridge is flashing E and F instead of holding the temp for the freezer and fridge. How can I fix this?
Hello Debbie Zymet - Typically error code E and F indicates that there is an error with the evaporator fan in the refrigerator compartment and fan in freezer. I would suggest contacting a professional move forward accurately for proper diagnosing and repair.
Nov 18, 2012 | Electrolux 25.9 Cu. Ft. Side-by-Side...
Samsung SRS583HDP fridge not cooling. Side by side
Most likely the thermostat in the fridge, especially if it read 5 degrees until you reset it. Possibly the compressor in the fridge side as this fridge has twin cooling, or the circulating fan in the back of the fridge is frozen, which is a common problem as well.
Easiest things to try is to see if the fan is frozen and check if the fridge cooling is actually working. Turn off the fridge, remove the shelves, remove the 4 screws that hold in the bottom cover and the 2 screws that hold the water tank in. Cover should then come out a few inches. Reach behind and unplug the 2 plugs and pull out the cover. If the cover doesnt come out easily it may be glued to the back of the fridge by ice. Leave for a couple of hours and gently prize it off. Check for ice around the fan and that the fan spins freely. You could try sitting the cover inside the fridge, plug it in turn it back on for a few minutes (be careful) and then open the door and quickly look / listen to see if the fan is still spinning (it stops when you open the door). Leave the fridge off for a while until the ice disappears off the coils. Turn back on for half an hour. The coils should be icy again. Anything else call Samsung. If the deal in your country is the same as mine the fridge has a 2 year warranty but in the fine print the sealed compressor unit has five years on parts only. You could get the unit replaced for labour costs only. Check your warranty card.
Jun 22, 2010 | Samsung Refrigerators
Replaced water valve to ice maker -used jumper method on the ice maker to test - worked once then not again. checked the voltage coming in and it was 33 volts the ice maker also won't cycle with the jumper...
You need to replace the icemaker . Pt # 2198597 . When you open the freezer door . the laser flash 2 times , then pause , then 2 more times continually (normal) ? If the laser does not light at all , then icemaker is in the harvest mode ( may be stuck , replace icemaker ) . If in harvest mode , even slightly , jumper will not work .
Aug 29, 2009 | Refrigerators
Fault e8 displayed on beko ap930 fridge freezer
I had the same error message and the ice cube dispenser stopped working. On examining the workings, I found that the wire that should have been connected to the ice cube tray had sheared somehow (???) - a simple splice with lots of insulation tape has apparently fixed the problem.
Jul 03, 2008 | Refrigerators
Kenmore sideby side fridge
You have a defrost system problem. Defrost is controlled by a timer which energizes the heater circuit. The heater circuit has a radiant or cal rod type heater which melts the frost from the coil. When the coil reaches a temperature where all ice would be gone a termination switch opens and shuts of the heater. The timer will continue to run until defrost time expires (18-22 minutes).
If you can locate the timer there is a clutch head screw to advance the timer to the defrost position. Turn the screw clockwise SLOWLY until you hear one audible click. The heaters should come on and defrost take place. If the unit restarts after the 18-22 minute period the timer is good, if it does not restart advance the screw to a second audible click and it will restart.
If you had to turn the timer the to second click to get it started cooling replace the timer.
If the unit restarted after the 18-22 minutes and defrost did not happen your problem is in the heater circuit. This would be an open heater or bad defrost terminator switch. To access the heater and defrost terminator the back panel in the freezer section must be removed. With an Ohm meter you can check the heater to see if it is good.
Jul 01, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice and Water Dispenser Quit Working
I am having the same problem. Were you able to get it fixed?
Jun 16, 2008 | Refrigerators
FLASHING E8 (WARNING) ON MY FRIDGE FREEZER
A model number and serial number would help in any diagnosis.
May 04, 2008 | Freezers
Refrigerators Logo
680 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
