Question about SimpleTech SimpleDrive Pininfarina 320GB External USB 2.0 Hard Drive - Blue
I am trying to restore from a SimpleTech pinifarina 320G USB HDD and after installing the software on the system it will only allow me to restore from a HDD or CD disk. The backup is on the drive. What do I do?
    President:
  • 3,278 Answers
Hello.
Sounds like you no longer see the drive.
If you no longer see the SimpleTech drive, reinstall the Simple Tech driver. Do not format the drive, but install the driver.
If you see the drive letter, but cannot restore, please provide more details, such as error messages when trying to restore from the drive.
Hope this helps.
Posted on Jul 05, 2010
When I plug my 320G WD Elements there is no WD icon on my windows or my computer window. thanks
Have you used this HDD before?, it this is the first time?
Sometimes you have to install the WD Smartware Software. In the case of the 320G, which are the first HDD released, The computer should detect them automatically.
Try with another USB port. Do not use a USB multiport because it won't power the HD.
If it doesn't work on your computer, try it on another one. This way you can discard the possibility that the HDD is damaged.
God BLess You!!!
Feb 14, 2011 | Western Digital Passport 320GB External...
Device no reconized , my W7 don't want install drivers for simpledrive 640 GB pinifarina
The usb device not recognized error generally means the right drivers are not present on the computer. I would expect that Windows 7 can recognize most external HDD automatically, but you might need to install a driver for it.
But try the disk on a different USB port, or even computer, to see if it still works properly.
Jun 28, 2010 | SimpleTech SimpleDrive Pininfarina 320GB...
SimpleTech 250GB External Hard Drive can't be recognized
First of all,
uncheck the "Allow the computer to turn off this device to save power" option in the device manager for USB Hub Properties, Power Management Tab.
Try rebooting the computer once as C:\Windows\inf\INFCACHE.1 file may be corrupted and need to be replaced (either restore a previous version or just delete it and try connecting again).
Next,completely uninstall all USB devices and the main hub and then re-install.
Sep 07, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
Simpletech pinifarina 500GB external drive - unable to access
A few things to check but assumes USB for other interfaces similar steps may be followed
1. ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer.
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply (Dont use any other unless you know it has both the same voltage and current rating eg. 12V 500mA anything rated below that would not work properly)
If you checked and fixed anything there and still have issues carry on reading.
Go to your control panel and then administrative tools, select computer management.
Now select Disk Management and expand the window.
Your drive should be listed here (if not then you need to check your computer hardware has not got any issues before proceeding)
If your drive is listed and says healthy then right click on it an select Properties, click tools and then error checking, Check now, tick the two boxes and then start.
This will attempt to fix any errors on the drive. It may also ask you to restart which is fine. Allow it to finish its work or you could corrupt the drive. If all went well you should be able to use it normally again.
If you drive was listed ut did NOT say healthy then right click and select Format. Choose NTFS as the file system and do not tick any boxes you do NOT want quick format. Again start and let it do its thing. when it is done restart your computer and you should be good to go.
Aug 16, 2009 | SimpleTech SimpleDrive Pininfarina 500GB...
Simpletech 160mg pinifarina wont work
sounds like a corrupt driver. Go to device manager, and see if the USB tree has a yellow exclamation, if yes, uninstall USB driver and reboot.
Jul 25, 2009 | SimpleTech SimpleDrive 160 GB External USB...
I formatted the simpledrive 320g portable hard drive and now the one click software is missing.
Does the software perhaps have a hidden attribute? Does anything happen when you depress the one click button on the top of the drive?
Mar 22, 2009 | SimpleTech SimpleDrive Pininfarina 320GB...
Can't install SimpleTech 160 gigabytes
The usb port in your compute dosent support usb 2 please change the port if your system is latest dont connect both the usb cables of the hdd cauz the latest system is with usb 2 and dosent need power if old system please connect the power usb first and then the data usb cable it should work
please also try to connect to another port of your pc if available
thanks and regards
DUSHAYaNT
Jan 03, 2009 | SimpleTech Signature Mini 160GB External...
System restore isnt working now
not supposed to do another system restore. You are basically re-installing USB devices one by one again so the devices dont have conflict. Be sure to install the driver for the drive first before plugging it in.
Dec 27, 2008 | SimpleTech SimpleDrive Portable USB 2.0...
SimpleTech SimpleDrive Pininfarina 320GB External USB 2.0 Hard Drive - Blue Logo
160 people viewed this question
Top SimpleTech Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Lyle Siemens
Lyle Siemens
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
