Question about Dewalt DC385B 18v. Cordless Bare Reciprocating Saw Contractors Special
Blade not releasing
I have a dewalt sawzall and i cant get blade out. saw has only been used a few times i have tried to blow the dirt out with compressor and when i pull up on lever it still doesn't release.
  • 43,501 Answers
Getting a broken blade our of the sawzall chuck can be difficult and require some ingenuity and patience...
Sometimes there be enough blade left so that you can grab it with a needle nose pliers... othertimes it is flush and that makes it more difficult... holding the chuck in the release position and rapping the saw against a table or with a hammer can jiggle the piece out....of course you have the chuck pointed down while you do that...
Also moving the piece around a bit with a stiff wire and also soaking the chuck and blade with WD-40 helps also....
Usually it will take a combination of these things and some persistance to get the job done...
heatman101
Posted on Aug 27, 2010
A piece of a broken blade is stuck here the blade fits into the saw (Dewalt DW 303m). How do I get it out?
Craig, a drop of penetrate oil and you will just have to work at it with ice pick.small screwdriver, or needle nose pliers if you can, make sure you have blade release depressed while trying to pry blade shank out. Once you get it moving it will fall out. Clean and blow out blade port before inserting another blade.
How to Remove Stuck Blade on Sawzall Hatchet eHow
Troubleshooting Your Malfunctioning Reciprocating Saw DoItYourself com
May 26, 2016 | Dewalt Saws
Broken blade in dewalt sawzall
Remove broken blade, install new one. These blades don't change themselves, unfortunately.
May 06, 2012 | Dewalt Dw938 18v Reciprocating Saw Sawzall...
The blades come out
The piece that holds the blade in is held in place by a spring that sometimes breaks. eReplacementparts.com has a diagram and sells the springs for 78 cents.
Apr 25, 2012 | Dewalt Dw938 18v Reciprocating Saw Sawzall...
Replacing blade assembly on a dewalt 18v Reciprocating Saw Sawzall
Remove the foot, remove the boot (and yellow lever), pull shaft out all the way (so you have more room to work with), remove the spring clip from the clamp block, remove the lever and ball, the clamp block will then slide off once the wire clip that wraps around it is removed.
Apr 22, 2012 | Dewalt Dw938 18v Reciprocating Saw Sawzall...
I'm unable to remove the blade from the quick change something won't release the blade model 6521-21
what you can try is to unplug tool and spray something like WD-40 on the collar mechanism and usually it is simpler for this to remove the pivot shoe and turn the collar and release until you can get full rotation and pull the blade out. There might be some dirt in the release mechanism not allowing the blad/collar to release. This is about the only way without having to remove the assembly. Let me know if you need more assistance
Mar 11, 2011 | Milwaukee 6520 21 12 Amp Orbital Sawzall...
Have DeWalt Model 303 Type 1 Blade is stuck can not remove, removed Scew part # 99164-06. Blade is still stuck, blade will move side to side, back and forth but will not slide out. Any ideas
It sounds like the set-screw may have caused a burr on the blade, and that's preventing you from removing it. You might use a tool like vice-grips, and apply more force. I don't think you can hurt anything by doing that if the blade is in the fully-extended position.
Good luck,
genetuck
Feb 13, 2011 | Dewalt 15 6" Reciprocating Sawzall Saw...
Saw is binding up and not reciprocating.
Assuming you are cutting through material that your saw and blade are capable of cutting through - you either have a low or dying battery (if you have a bcakup battery - try that) - or you are using the wrong blade for the job - or it is dull. You can find battery replacements on Ebay. Blades are usually pretty cheap at the hardward store. Bring yours in and as someone in the hardware dept what they think about your blade. Good luck!
Nov 20, 2010 | Dewalt Dw938 18v Reciprocating Saw Sawzall...
Can not replace blade on Dewalt 303 6.5amp
heatman101
May 23, 2010 | Dewalt DW303 Heavy Duty 65 Amp...
I have a Milwaukee sawzall 6509-22 with a quick loc cam. Blade went in fine, but now the saw wont release the blade to come out. How do I fix this problem. Note: locking cam is turning fine
K you used the saw after inserting blade?? If so couple ideas, hold collar open and put saw blade in a vise and try pulling back on saw, or you can remove the quik lok cam and release it that way, its not that hard, but I would try vise first. Let me know
Jul 29, 2009 | Milwaukee Tool 10 Amp Sawzall Plus with...
Dewalt DC385B 18v. Cordless Bare Reciprocating Saw Contractors Special Logo
509 people viewed this question
Top Dewalt Saws Experts
Parson's Repair...
Parson's Repair...
JOHN LAPIER
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
