Hi I have a whirlpool washer and it will not drain the water out is it an easy fix or should I just get a new one thank you
  • Washing Mach... Master
  • 8,220 Answers
Use a quarter inch nutdriver to get the bottom panel offHi I have a whirlpool washer and it will not drain - 0f57e07.jpg87a8b9e.jpg
Posted on Jul 05, 2010
Ld code on my whirlpool cabrio, won't drain water, what do you do?
Hi There
OK here's something you can read to help you with. I hope this helps.
Ld Long Drain Ld flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets.
Press STOP/CANCEL to clear the display. Thank you for writing to fix ya.
Best regards Richard
Dec 11, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Water won't drain out of washer
Draining problem is very common in Bosch washers. However, it is very easy to fix.
1) Remove the white circular plate, located on the bottom left. Push a small screwdriver or needle through it and simultaneously rotate the plate clockwise.
2) Open the drain valve. Rotate the circular black handle counterclockwise. Beware of residual water.
3) Clean it. Re-assemble in reverse order.
Thanks for contacting fixya.com
Nov 23, 2009 | Washing Machines
Whirlpool Duet fills when off
It's Quite easy.
To test Inlet valve, follow the below guide :-
http://www.acmehowto.com/howto/appliance/washer/check/inletvalve.php
To test the Water level switch/Pressure switch, follow the below guide :-
http://www.acmehowto.com/howto/appliance/washer/check/waterlevel.php
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer drains water immediately
Hi, Does the water drain while the washer is filling? If so, check the end of the drain hose and make sure it is as high as the top of the washer.
If this is not your problem, Please let me know to clarify what is happening.
Thanks
Vic
Jul 15, 2009 | Whirlpool LSR5132PQ Top Load Washer
Whirlpool duet front load washer doesn't get clothes clean.
A FEW THINGS TO TRY FIRST RUN YOUR WASHER EMPTY ON THE HOT WATER SETTING UNLESS YOU HAVE A CLEANING CYCLE THEN USE THAT THERES ALSO SOME NEW PRODUCTS OUT THAT YOU CAN USE TO CLEAN YOUR WASHER OUT BUT FIRST TRY THIS ITS FREE , ALSO CHECK YOUR DRAIN PUMP AND THE DRAIN PUMP FILTER TO MAKE SURE YOU DONT HAVE ANYTHING CLOGGED IN IT LIKE A SOCK AND LASTLY CHECK THE AGITATOR BELT TO MAKE SURE ITS NOT WORN SEND ME A UPDATE WE'LL GET IT FIXED DONT WORRY
Apr 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer won't spin dry
Safety switch is not opening. When you leave lid up you are negating the safety switch which is activated by the door. Easy fix.
Mar 31, 2017 | Whirlpool LSQ8243H
My Whirlpool washer won't agitate or spin . But it does drain the water.
i also had the same problem, and it ended up being the coupler. It was not hard to replace, it cost me about 19.00. I didn't follow full recomende instructions. I tipped the washer backwards. Removed the drain pump and the motor itself. Then I removed the old coupling and placed the new one. The washer is working like new...
Oct 18, 2008 | Whirlpool LSR5132PQ Top Load Washer
Cold water won't come out on Estate washer by Whirlpool? Why?
HI THANKS FOR THE QUESTION . tHE PROBLEM WITH YOUR WASHER IS THAT YOU NEED A NEW WATER VALVE .tHANKS FORTHE QUESTION tHE APPLIANCE DOC
Jun 09, 2008 | GE WHRE5260E Top Load Washer
Drainpipe leaking
Hi Mary, I'm going through similar experiences with my new Whirlpool which I learned to hate. I'm not an expert, however, I learned a thing or two about washers recently. Your problem could be related to one or two things: The drainpipe hose should not be placed more than 8" in length in the drainpipe as it creates a siphon effect. Also, the new washers are designed to spin fast, thus higher water pressure exiting into the drainpipe. If your drainpipe is clogged up for some reason and cannot handle the high water pressure, that may also create a problem. This can be solved by using some Draino in the drainpipe. Hope this helps.
Feb 03, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing Machines Logo
24 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
