Question about Singer 7462 Mechanical Sewing Machine
After quilting I can not get the machine to sew normal sewing eg two layers of cotton. Also the stitches aare tiny and I have tried several solutions BUT not fixing the problem Materiel will not move from starting point.
  • Singer Master
  • 1,388 Answers
Are the feeddogs raised ?
Also remove needleplate & check for lint buildup between the feedog teeth, as there is a lot of lint in quilting, and it will form felt between the feeddogs and needleplate
Posted on Apr 24, 2008
HV sapphire 930 not feeding properly
When stitching together a quilt sandwich, it is recommended to use a walking foot on your machine. The walking foot moves the upper fabric in conjunction with the feed dogs. Sometimes, if the quilt sandwich is not too thick, a roller foot can also help but may not be sufficient for a quilt sandwich.
What is Walking Foot Sewing Tips for Beginners
How To Use Walking Foot
How to Use Roller Foot
You may also check the presser foot pressure on your machine. This regulates the amount of pressure the presser foot applies to the fabric and the feed dogs. If the pressure is too strong, it will tend to push the upper layers of fabric, creating a bubble look. If the pressure is too loose, there is not enough pressure for the feed dogs to physically pull entire quilt sandwich under the presser foot.
(The pressure is adjustable depending on the types of fabric and thicknesses being sewn.)
http://www.sewdaily.com/how-to-sew/sewing-machine-basics/the-best-kept-secret-on-your-sewing-machine
http://makeitsew.biz/presser-foot-pressure
Oct 01, 2016 | Sewing Machines
Why do stitches bunch when using walking foot on 3 layers of quilting fabric?
make sure that the thread tensions are correct for the thickness of material
remember that only the bottom foot walks and draws the material through so it may need a help and be pulled as it sews.
I find that women in sewing shops just love to talk about problems and how they can help so find a shop and discuss any problems with them
May 08, 2015 | Brother PC420-PRW Project Runway...
12 wt thread
12 wt thread generally will not work well in the bobbin...
"Aurifil 12wt Thread
Aurifil 12 wt thread is ideal for hand quilting, big stitch hand quilting and machine quilting. 12 weight thread creates a more defined and often primitive look. It's great for designs that use a longer stitch length if using a machine. When machine quilting with 12 wt thread, use 40 wt in the bobbin, increase your stitch length, lower your tension, use Topstitch size 90 needles and stitch slowly."
May 08, 2017 | Bernina Activa 140
I have a janome 1600P, it will not sew without either the top thread breaking or the bobin thread breaking. It will sew for about a quarter of an inch and then the thread breaks, I have changed the bo
My experiences with thread breaking with machine on a quilting frame make me look at the upper tension being set too high, the needle being worn or movement of the machine is too fast. Reduce the upper tension first, then sew in straight lines at first. See if you can sew slowly, in straight lines and reduce the upper tension until the thread stops breaking. If so, try some 1-2 inch circles, again going slowly. If the needle thread is pulling to the back, you will need to increase the upper tension again until the stitches meet in the middle of the fabric. If you can't locate a balanced spot where the needle thread is not pulling to the back side and thread doesn't break, try taking the machine off of the frame and sewing on a table. If it won't sew this way, it needs some professional help. If it does, you will probably save a lot of time taking it in for service, making sure to explain to the repair center that you have problems on a quilting frame, not while sewing normally. When the machine is adjusted to sew normally on a table and you move it to the frame, you will probably need to reduce the tension by 1-2 complete turns of the tension knob.
Nov 17, 2011 | Sewing Machines
My zig zag stitch is puckering fabric. I even went to the multiple zig zag, same problem. I decreased tension. What should I have double. Note: this was on single layer, along edge of fabric so I could...
Check the bobbin tension too. It could be too tight. Make sure you are using the right size needle for the material as well. Sheer, thin fabric needs a smaller needle, thicker material requires bigger needles. Bobbin tension is the typical problem as most think to adjust the top tension but don't check the bobbin tension.
Is your quilt peices cotton? Cotton shouldn't cause as much trouble sewing along the edge but don't use too long of a stitch length else it will seem to gather up. Puckering side to side however is a tension problem usually. With sheerer fabrics that cause a problem sometimes you can put thin paper underneath, sew through both and then pull the paper off after sewing. (thin like the iron on type interfacing type fabric but like paper).
Mar 25, 2011 | Janome Sewing Machines
5932 knotting every other inch
Try oiling the hook if you haven't recently.
Check you needle plate and hook for damage, they may need to be buffed or sanded smooth.
Check your upper tension discs for lint and double check your upper thread path (proper threading).
There are other things like hook timing, needle clearance or broken check spring that may be wrong but you need a technician for those things.
best of luck!
Jan 28, 2009 | Singer 5050 Mechanical Sewing Machine
Difficulty sewing quilt blocks
Try using a "walking foot" presser foot. It has feed dogs on the top to help all the layers go through evenly. A generic brand usually fits most all machines. :)
Jan 17, 2009 | Kenmore 15212 Mechanical Sewing Machine
I have a White 955 machine and I am trying to quilt with it. It works just fine when I am sewing just one piece of material to another but when I want to sew the layers of the quilt together the stitches...
I know this is strange, but make sure the pressure foot is down. When I quilt sometimes, after getting the bulk under the needle, I forget to put the pressure foot down or it get's knocked back up by the quilt and causes the same problem. Good luck.
Jan 04, 2009 | White Sewing 955 Mechanical Sewing Machine
Brother sewing machine
Sounds like the feed is your problem. Most likely you need a different foot. Check the bottom of the foot - it should be quite smooth to allow the dog feed to move the denser layers along smoothly. Hope this helps.
Feb 07, 2008 | Sewing Machines
Singer 7462 Mechanical Sewing Machine Logo
43 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
