I have a powershred PS 70 and the small gear that drives one of the shredding knives is broken. Where can I get a parts list and secure a replacement gear.
Thanks,
Steve
Comments:
May 02, 2008
- Called number above (Fellows Customer Service) and spoke with Jessica. was advised that a gear kit is no longer avalable for this shredder as it was manufactured in 1996. I don't like to throw stuff away that can easily be fixed. Repair should be included in the Recycle process (Reduce/Reuse/Recycle). Serial number for machine is 070 960412 A 001 00033933. If anyone has another suggestions I am open to hear/read it.
C-220 Motor and/or the cutter rollers seem to be bound up. It stopped in the middle of a stack of...
(More)
C-220 Motor and/or the cutter rollers seem to be bound up. It stopped in the middle of a stack of maybe 6 sheets of letter sized paper. It stopped without making the dreaded feeding-too-much-paper noise It will not budge either forward or reverse. We cleaned out almost every bit of paper that was stuck between the cutter rollers. It makes stalled-motor noises when I try to make it run, both forward and reverse. I can turn the motor by hand a little using the fan on the motor shaft, but it turns very hard. Sometimes (but not always), turning the motor shaft by hand will advance the cutter rollers two or three degrees before it the rollers refuses to move any further.
We shredded a lot of name-stickers we get with charitable solicitations and now the shredder is...
(More)
We shredded a lot of name-stickers we get with charitable solicitations and now the shredder is jammed;i.e., it will shred but won't turn off unless I put it on "off". Can it be cleaned somehow? It is an AS*800CD and has worked well until now. Art Humphreys, Pittsburgh, PA
Shreeder runs forward and backward OK but has a tendency to stop feeding paper through blades and...
(More)
Shreeder runs forward and backward OK but has a tendency to stop feeding paper through blades and just runs without feeding additional paper into blades. Direction makes no difference.
Model SH79005. When turned on shredder does not stop. when inserting a single piece of paper...
(More)
Model SH79005. When turned on shredder does not stop. when inserting a single piece of paper shredder stops. Shredder stays on when turned on, in either direction. Almost like a sensor is backwards. shredder is only 8 months old has hardly been used.
looking to get info for replacement gear for staples paper shredder common problem,someone must...
(More)
looking to get info for replacement gear for staples paper shredder common problem,someone must supply this item
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
