Question about E-Machines eMachines Monitor E15T4
My monitor has gotten really dark. How to fix?
My monitor has gotten very dark. It was fine until one day I turned it on and suddenly it was not as bright as it usually was. I have it tilted down as far as possible so I can see what's on the screen. I have tried adjusting the brightness and contrast, wiggling the wires, unplugging the monitor and leaving the computer off for a few days. Nothing has helped. Can this be fixed or do I need a new monitor? It is about 6 years old. Thanks.
  • 2,404 Answers
Try another monitor on your computer. If the other monitor works fine, then you know the video card is good and the monitor is definitely bad.
If the monitor is the culprit then the only option is to replace it because that would mean the screen itself is going bad and there is no replacement screen for that monitor.
Posted on Jul 05, 2010
Samsung 21.5 LCD monitor suddenly turned dark. Can this be fixed or should I just trash it?
Your monitor has symptoms of power supply failure. The age of the monitor and the cost of repair will influence your decision whether to repair it or dump it
Feb 25, 2013 | Computers & Internet
HP L2208w monitor problem. First it worked good, but then suddenly this happened!! When i turn on my PC, monitor works fine, but after a while (sometimes a minute, sometimes a few seconds) it gets very...
Step 1: Attach LCD screen to another known-working computer (keep in mind to plug into a reliable powerstrip). Check to see if the process can be repeated. If not, then check your computer settings (Power management, etc.). If the issue can be duplicated, then..you, my friend, are experiencing an inverter failure. OK. Moving on. Buy and inverter and replace it. Not a good option for you? Might as well get a new unit. You missed several Black Friday deals but hey, some are still on sale tomorrow.
Nov 28, 2010 | HP L2208W Monitor
My brightness control does not work just turned on and can not hardly see anything it is up and running what now
Have you tested it with an external monitor?
I would say you either have a damaged inverter board or screen baclight lamp. Usually the inverter board fails in one of the following ways:
1. When you turn on the laptop, the screen lights up for a short period of time and then goes dark. You still can see an image but it is very dark, almost invisible and definitely not usable. When you restart the laptop, the screen lights up and then goes dark again. The laptop works fine with an external monitor.
2. Your laptop turns on but the screen remains dark all the time. You still can see a very dim image outline. The laptop works fine with an external monitor.
3. The laptop screen works fine for hours or even days, but sometimes it goes very dark as it mentioned above. When you restart the laptop, the screen works fine again.
Inverter failure symptoms are very similar to backlight lamp failure symptoms and in most cases you cannot tell which one is causing the problem until you replace either the inverter board or the backlight lamp. From my personal experience, inverter boards fail more often than backlight lamps. If you have to guess, replace the inverter first.
Mar 24, 2010 | Dell Inspiron 1545 Notebook
Acer AL1916 LCD monitor is getting darker!!
sounds like backlight is failing,contact acer and see if its under warranty.
Mar 04, 2009 | Acer AL1916B 19" LCD Monitor
Zenith z44sz80 Dark picture
i have same problem. i replaced lamp but picture is still dark.
Aug 22, 2008 | Toshiba 46H83 46" Rear Projection...
My e153fpb monitor went dark
Try resetting the monitor to default settings by getting your manual out. It will guide you through the process. If that does'nt work then check for any updated drivers.
Apr 24, 2008 | Dell E172FP 17" LCD Flat Panel Monitor
MAG Innovision LT1919WDb flat screen goes black
I had the same problem. I contact the manufactuer and they refused to fix it. They said it would cost an additional $100 to have it fixed. I have not even had it a year. I thought products sold in America were suppose to last longer than a year? What has happened to companies standing behind there products. Beware of this monitor!!! DO NOT BUY IT!!! LT1919WDB
Jan 30, 2008 | Computers & Internet
Olivia multi-media TV/monitor
Not really. Repairs are right about $150 - $250. Resistor Kit, Caps., maybe other parts, and labor charges.
Jun 27, 2007 | Olevia MN-20LCDTV-SN 20 in. EDTV-Ready...
L13V36 Dark Screen, picture can be seen in bright light.
welcome to fixya
it sounds like the back light on both monitors are going bad
it might be better to call a repair man and get him to look at it see if it is going to be worth fixing i think it might be better then buying a new one at the prices now days
i hope this helps out have a nice day:)
Aug 08, 2006 | Zenith L13V36 13" Flat Panel LCD Monitor
E-Machines eMachines Monitor E15T4 Logo
155 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
