Question about Kitchen Ranges
My Amana ceramic cooktop has one burner that is not working. I can't get the top off to look at the burners. How do you repair one burner on a ceramic cooktop?
  • Anonymous Mar 28, 2014
    Kenmore elite made in 2006. Can this be replaced?
  • 145 Answers
Check your warranty first. Some burners on smooth tops had long warrantys. If not first turn the power off to the unit at the breaker. If this is a in counter cooktop it has to come out of the counter and take all the screws out that hold down the top. Best to unwire from house and move whole unit to big surface to work on.
Posted on Apr 18, 2008
Burners ceramic top stove
FIXYA has no agents and have no idea who can assist you there
Dec 15, 2017 | Creda Cooktops
Clicks but does not does not igite
Hello, thank you for your post. It sound like your saying the burners are not lighting up. Most of the time this is just a simple fix. Next time you turn on your burner notice were the igniter sparks this part of the burner needed to be cleaned. You should be able to take the burner cap off and the burner use a wire brush to clean the surface area so the spark has good contact. Take notice also of the igniter you will need to change it out if you see any cracks around the ceramic housing.
Happy Holidays! Please rate me "4 thumbs" if this information was useful.
Dec 21, 2010 | Amana AKS3040 Gas Cooktop
Amana Glass cooktop 2 out of 4 burners not working
it is not a fuse. as if it shorted it may blow it and then nothing .. the sw to either one burner is at fault replace the sw 's ( both and the cook top should be ok . sw cost around 25 to 40 ea ..
Jul 13, 2010 | Amana AKT3040 Electric Cooktop
Range Ceramic Cooktop 1 burner not working
I would try replacing switch for that burner. But it also could be a defective burner.
Oct 20, 2017 | KitchenAid Kitchen Ranges
I need a dual burner switch for my Amana cooktop model ak2h30hr
Fit two switches. Although this might be as expensive as a new cooktop.
Mar 27, 2010 | Cooktops
Burner light stays on even if burner is off and stays cool
you have the ground wire for that burner on the wrong pin your loosing ground somewhere
so the sensor is reading hot
Sep 26, 2009 | Kitchen Ranges
How do i replace my burner on my jenn air ceramic cook top . it has the down draft feature in the centre
1) turn off power at the breaker. 2) remove hold down screws 3) pop up cooktop out of counter top 4) remove knobs and downdraft grille 5) remove ceramic top (screws around outside and also in side grille opening) 6) unplug burners replace with new burner
Sep 17, 2009 | Jenn-Air JED8430 Electric Cooktop
Miele KM 320 G gas cooktop ignitor
I had a similar problem and discovered that the control knob had fried itself, most likely due to liquid penetration down the shaft of the control knob and into the control knob electronics. Inside is a printed circuit board with resistor, diode and a rheostat. The surface of the board was charred beyond repair.
To trouble shoot the problem, open the cook top and hook the burner in question to one of the known good control knobs. If it ignites, then it is the control knob electronics. If it doesn’t, then there is something wrong with the igniter.
Note: The 2-zone Wok Burner had a different control knob that the other burners.
To open the cook top, do NOT loosen any of the Phillips screws on the sides. Here are the instructions from the user manual:
Disassembly
Shut off gas supply, disconnect the manifold pipe, disconnect the electrical power. Remove pan supports, burner heads and burner rings. Remove control knobs.
In the event that the hob is built in, undo the bracket clamps underneath the work surface. Lift the hob on to the work surface. Unscrew the venturis on the high-speed and super high-speed burners using a 20 mm wrench. Lift and remove the burner rings and burner base plates. Disconnect the wires from the ignition plugs. Keep the wire from dropping into the undertray by inserting it in one of the slots in the burner supports.
Remove the three screws securing the dual ring wok burner. Remove the wok burner base plate. Lift the ceramic tray from the hob.
Note: Each regulator shaft is equipped with a black ring. This ring may cling to the rubber seal in the ceramic tray. Check and remove the rings from the rubber seals.
To order parts, call 1-800-245-8215, 8:30 AM to 5:00 PM EST
Mar 04, 2009 | Miele 35 in. KM326G Gas Cooktop
Remove ceramic cooktop
grouch, kill the power to the cooktop. You are going to have to remove the mounting brackets from undernieth and push the cooktop up. After it's up from it's installation position remove the side and back screws holding the top to the botom. Remove the burner knobs and it should come apart. Sounds like you have a bad burner switch. Catriver..post back
Feb 26, 2007 | Jenn-Air JED8430 Electric Cooktop
Kitchen Ranges Logo
573 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
