Question about Bosch SHU5315UC Dishwasher
Drain pump running when unit starts but no water to appliance
Our drainage system beyind the dishwasher became clogged. The dishwasher tried to empty the rinse water but the water wouldn't drain due to the blockage. Now that we have the blockage removed from our drain pipes, the dishwasher did drain the water. but now it won't let water into the dishwasher to start the wash cycle.and it sounds like it is still trying to empty the rinse water tank.
  • Bosch Expert
  • 414 Answers
The machine probably has water in the base (not visibly in the machine, but in the base where the conponents are). Pull the machine out, sit the front on a large towel and holding the back of the d/w pull it towards you. Any water trapped in the base will drain out. It may be a fair amount as the flood safety switch will activate on approx 1.5 ltrs. Once you've cleared the water run a prewash or quickwash to check d/w. Hope this helps.
Posted on Jul 06, 2010
    Problem Solver:
  • 15 Answers
Had this problem and a forward tilt pulled it out of flood protection mode but I had to manually drain all the water out into a bowl first - just using the drain hose at the back. Then running a cycle with one of those Finish liquid dishwasher cleaners, letting the unit go through a normal cycle and drain into a washing-up bowl cured it.
Posted on Aug 22, 2010
Frigidare dishwasher did not spin
  1. Waste Disposal/Sink trap
    • Empty your food waste disposal unit if your dishwasher's hooked up to one. If it's not empty, the old food inside it will back water up into your machine. Check that your sink trap isn't blocked by unscrewing it from the base of your sink if you don't have a food waste disposal unit. Make sure your dishwasher or any other appliances connected to it are not running when you do so.
    Incomplete Cycle
    • You may have opened your dishwasher's door mid-cycle before it's had a chance to drain. Check the progress indicator on your machine's control panel. The structure of this will differ depending on which Frigidaire model you're using, but it should show the point your machine has reached in its cycle. If this is the cause of the problem, close your dishwasher's door and let it finish.
    Drainage Pipe
    • Inspect the drain pipe that runs from your machine to your waste disposal unit or sink. If this is kinked or has been squashed under another appliance or a base unit, the waste water inside your dishwasher will be unable to escape. Check that water can flow through your waste pipe freely.
    Filter
    • Remove the bottom shelf from inside your machine and take out the plate covering the filter area. If you don't rinse your plates before you put them into your washer, food debris could block your filter and stop water from reaching your drainage pipe. You can unblock your filter with your fingers. Turn off your machine's power before you attempt to do so.
Feb 02, 2012 | Dishwashers
Dirty water backs up into unit
The drain valve needs to be checked , also try cleaning the drain hose , it could be clogged , leading to improper drainage .
Lemme know if this helps
Mandeep
Apr 20, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Dishwasher stuck on drain cycle
Hello, If your dishwasher is stuck in the drain cycle there could be two reasons for the unit doing this. The first reason is you could have something clogged in the drain line or blocking the drain pumps impellar. If the unit is not able to empty the water out of the unit the drain pump will continue to try and empty the water. The second reason would be if you had a leak condition in which if you did have a leak the drain pump would continue trying to empty the unit to prevent the unit from leaking water outside of the unit. I would first remove where the drain line connects to your drain and inspect this area first if you do not find any blockages in this area you would have to de-install the unit from under the counter and check the oppisite end of the drain line to where it attaches to the drain pump itself. If you still found no blockages you would then remove and inspect the drain pump assuring that the impellar of the drain pump is spining and that there is nothing clogging the pump as well. If you have any further questions message me back. I await your reply
Thank you
Rick
Nov 28, 2011 | Danby DDW1805W Designer Series...
I have a Whirlpool dishwasher ADP951 that is not draining the water. I think the draining pump is broken. How much would it be to get a new pump and and get it fix?
If you use powder detergents or other "hard" detergent based products. They probably have backed up and clogged your dishwasher's drainage system.
**WARNING** Unplug any appliance before attempting to repair.
Step 1. Remove back panel from washer. (Use 1/4 or 3/8" screw bit & cordless screwdriver)
Step 2. Remove hose from pump. (Use channel locks or large pliars)
Step 3. Disassemble pump and remove clog or blockage from pump and hose.
Reverse process and plug in dishwasher and select a drain cycle if available.
Note: Do not use powder detergents if possible. They WILL clog any washer appliance.
Feb 10, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher turned on accidently and full of water
Close the dishwasher door and run the drain cycle of the dishwasher only....that should empty the appliance. Note that a little bit of water remaining is normal, but if there is a substantial amount of water left, you will need to check the pump inlet screen and the drain hose or sink for any additional clogging.
Apr 02, 2010 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Doesnt drain all the way and smells pretty bad from standing wate
ok if it doesnt drain properly... it means the drain hose isn't carrying it to the drain pipe, or the house's drain lines are backed up.
check these: Drain line/air gap Pump Drain valve and/or solenoid Belt Motor Timer
A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain.
Air gaps are installed in the drainage system to prevent the discharge from the dish washer to enter the sewer system and the contaminated water to drain back into the dishwasher after the pump stops.
When we install a dish washer we loop the discharge hose as high up under the cabinet as we can and secure it with pipe straps.
This creates a air gap so that when the pump stops nothing from the drainage system can flow back into the dish washer.
Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line.
If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
we ll now see how to check the pump
Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support. Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm.Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller.
The drain impeller pushes the water toward the drain port.
if u see any of these parts broken u wud need to replace themnow the next thing to check wud be the drain valveMany dishwashers use a drain valve with an electric solenoid.When electricity flows to the solenoid, the valve opens and diverts the water to the drain.Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly.To access the drain valve remove the lower panel located beneath the door. The panel is usually held in place with two screws either above or below the panel.It may be necessary to first open the door to the dishwasher to reach the screws over the panel, then close the door to remove the panel. Look for a water hose running from the motor or underside of the tub. The hose should lead to the drain valve. now we need to check the motor ... now u might not be required to come uptill this iam giving u instructions just incase
If the motor isn't turning or working, the unit won't drain If the motor hums but doesn't turn, it may need to be replaced.
Some dishwashers are susceptible to getting stuck if you don't run them regularly. If you haven't run the dishwasher for more than a week,you may need to manually spin the motor to free it up. If the motor is defective, you need to replace it. Dishwasher motors just can't be serviced.also refer the following links http://www.acmehowto.com/howto/appliance/dishwasher/check/airgap.php
http://www.acmehowto.com/howto/appliance/dishwasher/check/timermotor.php
regardsiversh
Sep 12, 2009 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
My dishwasher doesnt drain and the drain button is flashing
regardsiversh
Apr 27, 2009 | Miele 24 in. G645SC Plus Free-standing...
SHU43 running constantly
Intrrnal leak into base of appliance will make drain pump run constantly.
If appliance fills then dumps water with drain punp then keeps filling/draining sequence then the flow meter could de faulty.
Call in engineer.
Paul Winn Appliance Services (Cumbria)
Apr 02, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Miele G841 Built in. Intake/Drain light on/flashing and the dishwasher just shuts down.
In the user manual there's a section on how to clean the non-return valve. It's the plastic piece under the wire below the triple filter. Why did you pull out the machine? Did you kink the drain hose? If you don't find a clogged valve, spin the impeller wheel several times. It's under the valve inside the bottom hole where the valve came out.
Now here's the important step- Reset the fault! Power off/on the unit. If the light blinks when you turn it on, Press and hold the start button 4 seconds with the door open. Find the combination of off/on buttons to press to reset the machine in the user manual.
(Note: If the machine runs continuously as soon as you pressed on the power button, then you have water under the unit in the safety pan. Call Miele for help.) Now select the normal wash cycle close the door and start it. The drain motor always runs first. This verifies to the brain how much water is inside the machine when it starts filling. The drain pump runs for half a minute. If you hear it running with no drain check the drain hose especially if it's connected to a disposal. Clean the disposal.. If it's not running at all the light will go on again before filling, call Miele. If the machine fill up with fresh water, the drain works. Watch and listen when the light comes on. Is it filling or did it start circulating? Open the door, are the baskets are dripping wet? Then it filled and circulated. If the light comes on several miutes later then call Miele.
Feb 04, 2008 | Miele 23 in. Novotronic G841 Built-In...
Dishwasher doesn't drain
how do you check to see if the pump is pumping? The drain is not clogged or blocked and the line is not kinked. The garbage disposal is not clogged either.
Oct 06, 2007 | Dishwashers
Bosch SHU5315UC Dishwasher Logo
663 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
