I disconnected my TV from Comcast cable and hooked it up to an antenna. I got lots of static. I did play with the control some. Nothing changed. I hooked up cable again. Now I get a picture and sound, but the picture has an overlay of a pattern. Not even the DVD player can show a movie correctly.
  • 10,594 Answers
Model number and brand of tv info are very important to diagnose problem, let me know model number and brand of your tv to help you out.
Thanks.
Posted on Jul 05, 2010
No Sound from Fisher Box TV
I think your problem is with the scart socket . It most likely to be a dry joint on the pin where the sound goes in to the tv. you have to take back cover off the tv and turn the chassis over to do the dry joints if you can do it yourself otherwise get an engineer to do it. Good luck.
Aug 24, 2014 | Fisher Televison & Video
I hooked up the new digital box Comcast sent, but it has no audio. I disconnected the box and tried it by itself and it still has no audio. I went through the menu manually as the remote for the TV does...
I suspect you mean by disconnecting the box and running it by itself you mean you tried to run audio from your TV by itself? Somehow you need to go through the menu on your TV setup to see if the audio output isn't either turned off or muted. THere may also be a switch on the back of your TV near your output jacks which gives a option of Speaker on or off. If the speakers are on and your TV audio works I would suspect a issue with either your patchcords or the Cable Box. I am not familiar with the Comcast Digital Cable box (I have analog). But you may want to refer to the manual or to them to see if something in the menu may turn on audio for that as well.
After doing all that (whew)... and if nothing works you may have a issue with the TV amp. If nothing is hooked up to the tv (as if you were just watching "On Air" with an antenna and no stereo connected can you hear audio?
Let me know.
Kindly, DAVID
Mar 09, 2011 | RCA F27676BC TV
Help. I got a used TruTech t200d for my nine year old. we were able to hook up and play on playstation 2, but are unable to get the tv to pick up the comcast channels. we do not have the trutech remote...
U able to go into the tv Menu?Yes,goto SETUP changes Pick CABLE and scan for channels for the Comcast CABLE channels.Or Try website like Remotes.com to buy an original tv remote.
Mar 04, 2011 | TruTech T2000D TV
We just got this tv from family member. They had not been using, they have no manual. We can't figure out how to program for channels using cable. I have the numbers stored and nothing but static. What...
My guess is bthe tuner is analog and you can't decode anything either by way of antenna or cable. You either need a converter for the antenna or a settop box for cable.
Nov 27, 2010 | Televison & Video
Can't hook up Comcast cable box into tv. It is an HD comcast cable box and I am trying to hook it up to my childrens princess tv/dvd combo. I can't figure it out. Please help.
I assume this TV has no Audio In and Video In, from your Cable box there's an antenna out or cable out, connect that to your TV's antenna in, and make sure that your TV is tuned in to channel 3 or 4, try those two channels. You can only change channel thru your box, your TV channel is alway's on channel 3 or 4.
Jun 26, 2010 | Disney Princess TV/DVD Combo
Vizio l37 When I try to scan the channels automatically the TV can find all the ones that comes from the comcast cable (62) but when stars to scan the digital ones freeze make me cancel the process and...
you cann not hook an antenna and cable to a splitter together and expect it to work
the only way that will work , if your tv had two tunners Try doing a scan with cable
only on the cable setting
Nov 03, 2009 | Vizio L37 Television
Static jumping picture
sounds like bad connection or bad tuner in the tv - have you tried playing a DVD or VCR tape ( if available ) - more info would be needed to help you further -such as - are you on cable, cable box, satelite or antenna and do you hook up to your TV using the a/v or RF(cable) input.
Oct 18, 2009 | Sony FD Trinitron WEGA KV-20FS120 20" TV
TV was fine, now just static but works with DVD
Try using AV cable the same way you do when you hook up the DVD (- hook the cable box in place of the DVD) This will determine if you have problem with the tuner of the tv.
Oct 04, 2009 | Televison & Video
Took toshiba off comcast control and now ct-90157 won't work
We found the manual at home and was able to program the t.v. to recognize all the channels from cable and store them.
Jan 26, 2009 | Toshiba CT-90157 Remote Control
Televison & Video Logo
15 people viewed this question
Top Televison & Video Experts
