Question about Panasonic NN-T993SF Microwave Oven
Start button does not work
Everything seems to working on the microwave. You can set the time, power level,ect but when you press the start button nothing happens. Model looks like the NNSD767B only in stainlees steel. This is the second one we got and both had the same problem
  • 518 Answers
The switch contacts are not making so switch is u/s
Posted on Jul 05, 2010
Why Kenmore microwave oven (model 80089700) start/enter button not working while all other buttons works fine?
Safety system locking out the start switch. Door not closed, mode and timer not set etc.
Apr 10, 2017 | Kenmore Microwave Ovens
How do I change the power level?
Usually, power level is selectable using the keypad.
Jan 03, 2016 | Samsung 1.8 Cu. Ft. Over-the-Range...
How do I set the power level
Enter the cooking time. Press the Power Level button until the desired level is displayed - Level 1 = 100%, Level 2 = 90%, ... Level 10 = 10%.). Press Start button.
Dec 10, 2015 | Sharp Carousel R530EST Microwave Oven
Unable to adjust power level, the power level button on the control panel does not respond.
Try pressing and adjusting the power level before setting the cook time, or maybe before pressing start. Worked on my Panasonic
Dec 12, 2013 | Microwave Ovens
Everything works fine, except my food is still cold
Check the "power" level setting.
Most microwaves allow adjusting the power level from 1 to 10 (or 10 to 100 on some models). 10 (or 100) is the highest/quickest setting.
I can check mine by entering a time...then before pushing "start"....push the "power" button....and change the level if I want.
Mar 23, 2013 | Microwave Ovens
Microwave oven touch pad problem
The keypad very well could be worn from use and be working intermittently. Replacing the keypad (and the keypad face if it is a separate piece) is the most logical solution.
Aug 22, 2012 | GE Microwave Ovens
How to set microwave 50%
You have to put the cook time in first and then you press the power level button (just below the number 7 on the keypad) and put the power level in. The choices are 1 through 10. Fifty percent is probably power level 5. Once you have put in the power level, just push the Start button and it will start cooking.
May 11, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
How do you set the power level? The model number is: JVM1730DM1WW The serial number is: MM901698B
Assuming your touch pad is working properly, press Time Cook (for cooking) or Time Defrost (for defrosting) and then type in the length of time that you want the microwave to operate. Then press Power Level and type in a number from 1-10. Finally press Start. Depending on the GE microwave, the Power Level button may be above 2 or to the left of 0. (I've seen both keypad designs depending on when and where the microwave was manufactured.) If you press Power Level before setting the cooking time, the unit will reset when you press Time Cook or Time Defrost.
GE has the manuals for some of their microwaves on their site. See http://www.geappliances.com/service_and_support/literature/ and enter the model number in the search engine.
I hope this helps.
Mar 02, 2011 | GE Microwave Ovens
How do I adjust the power levelthen start the
Press "Power" until you get to the level you want. Then enter the # of minutes on the keypad (CANNOT use express cook times.) An alternating runnig hum will let you know the setting is working.
Nov 08, 2009 | Hotpoint RVM1635 Microwave Oven
R-209BK Sharp Microwave buttons inoperable
I had this problem too:
it turns out that it (apparently) just needed some 'warm-up' time!
After being plugged in for about 15 to 30 minutes,
the buttons suddenly "came to life"...
Note that when it's flashing 88:88 you are supposed to _start_ with the 'Stop/Clear' button. After that, set the clock (press "Clock", enter the time with the number pad, then press Clock again).
Hope that helps.
Sep 01, 2009 | Sharp R-1502 Microwave Oven
Panasonic NN-T993SF Microwave Oven Logo
675 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
