Question about Toshiba 37HL66 37 in. LCD HDTV
LCD HDTV resolution issue. The Toshiba 37HL66 is a 1080i HDTV yet I cannot use any resolution higher than 1024 x 768 on my PC. Could this be a driver problem and if so, where can I find updated drivers?
  • 11,361 Answers
Trying to use PC sigle but not seen screen
likely you have set the resolution higher than the monitor can handle, try lower resolution like 1024 X 768
Oct 16, 2014 | RCA L42FHD37 42 in. LCD HDTV
Resolution issues with samsung b2230
did you installed your graphics driver if not install it first and you can change your resolution may be your system don't have that capacity you have to buy a graphics card that will fit to your system config and instal drivers it will work. hope that it will help you thanks
Feb 14, 2014 | Samsung B2230 LCD Monitor
Poor quality when connecting TOSHIBA laptop to LG LCD screen
It seems the LCD screen has a higher resolution the laptop Video Card cannot supply such image quality.
Aug 29, 2012 | Toshiba Computers & Internet
Where i can exchange resolution of picture
Not sure what you mean. If you mean change the display resolution then depending on the device you have to tell your device the resolution. Like for the Xbox there is a section in the configuration where you can tell it to use a lower or higher resolution. On a pc it's as simple as changing the resolution like normal.
Mar 25, 2011 | LG 42LG30 42 in. LCD HDTV
When i scroll down, the screen goes wavey
Sounds like a graphics driver issue or a screen resolution conflict between the graphics chip and the lcd panel. Try going to the Toshiba support/drivers site, the link is below and put in your model and what OS you have and it will give you a list of available drivers. Search for the graphics driver and download and run the latest offered.
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp#
Jan 18, 2010 | Toshiba Satellite A100-S8111TD Notebook
Black/blank lcd screen after 2 seconds
try this - boot into "safe mode" - (this loads just minimal drivers). Reboot and press F8 while it's booting - it will ask if you want to boot into safe mode - say yes - if the screen works with the low resolution inherent drivers, it's probably a driver issue, or if you have a video card, it may not be able to work at the higher resolutions (which could be a card issue)
This should help you narrow down if the screen actually works, or if it's a graphics card and/or driver issue.
If it works - try reloading the driver for your graphics card (if you don't have a graphics card - try reloading both the chipset driver and the video driver from the manufacturer)
let me know if this works...
(I had a Toshiba Tecra laptop that did the exact thing - you could see the Windows boot menu, and once it completed boot up, the screen would go black - if you started it in safe mode (crummy resolution) it worked but of course the graphics are unacceptable at that resolution)
Turns out this is common with those, it was the graphic card built into the motherboard that's shot....
Oct 21, 2009 | Dell D1728D-LS VS17X Monitor
Dynex 19 LCD
I went over the specs of the TV.
The max input for the VGA is 1360x768 at 60Hz. Anything higher will make the TV go bonkers.
I would try to get the resolution at 1360x768, then change the frequency to 60Hz.
May 29, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
Dell Inspiron 2200 maximum display resolution
The display limit is determined by the LCD design. IN this case, you have an XGA LCD resolution 1024 x 768 pixels. This is a hard wired resolution and can only be changed by exchanging the XGA LCD for a higher resolution one (SXGA or higher, likeky not an available option for an Inspitorn 2200)
http://compreviews.about.com/od/multimedia/a/LCDSpecs.htm
Apr 19, 2009 | Dell Inspiron 2200 Notebook
Dynex 19 LCD
Yes, the current video driver is not configured for the higher resolutions supported by the Dynex TV/monitor. I ran into this same problem setting up my system. The solution is simple and only requires that you uninstall your current video driver and reinstall with the latest version driver for your systems VGA. You should be able to run the monitor at a resolution of 1440 x 900 with Color Quality at 32 bit Highest. Hope this helps.
Jan 11, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
Toshiba 37HL66 37 in. LCD HDTV Logo
126 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
