Question about Air Tools & Compressors
Eng. oil with coolant
ENGINE OIL MIXING WITH COOLANT WHAT TO DO
  • 3 Answers
Firstly Clean all the tank and Reagen fill the oil because the system have so many problem if r u running that condition's
Posted on Jul 06, 2010
Engine oil leaking into coolant system on a 1997 mercedes benz c280
Have a compression test done on the engine to eliminate gasket problems . Check that the oil is engine oil and not transmission oil from a broken oil cooler in the radiator.. If you are sure that it is engine oil check that you have an engine oil cooler on the engine in which case it will be a gasket or corrosion in that unit.
Mar 01, 2014 | 2001 Dodge Ram 1500 Truck 2WD
Engine oil mixing into coolant
The only place, oil and water share a gasket is the cylinder head gasket, oil and water galleries run through the engine block and head via the head gasket. The cylinder pressure will be OK, it's the oil pressure that's putting the oil in the coolant, the gasket has gone between the water and oil galleries or there is an internal crack (unlikely). A coolant pressure test should show it up.
Jan 23, 2014 | 2012 Kia Sorento Base 4dr SUV 2.4L 4-cyl....
Oil mixing water
Hello.
Oil in Coolant means broken engine seals, you lose compression, coolant gets hotter and this may lead to broken coolant pipes due to the pressure that comes from the engine trough the seal that has broken.
Engine service is needed for replacing Cylinder-head gasket.
Hope it helps
Aug 15, 2013 | BMW X Series & X5 1997 >2006
Coolant leaking from R1 bottom of engine
FYI This has just happened to me.
Bike has been stood for a few weeks and i started it. Noticed the temp was unusually high (105-110) so switched off, checked coolant and it was dry.
I topped up and noticed the coolant leaking from what appears to be a hole in the engine sump casing.
Im a fairly fast worker and i managed to remove the entire exhaust system down to the header pipes and drop the oil and remove the sump casing in around an hour.
It might take longer if you don't do much mechanical stuff. (I'm just a hobbyist btw not a mechanic).
It turns out that the hole in the sump casing is actually linked to a coolant overflow pipe internally. So don't worry coolant is NOT mixing with your oil (and therefore oil is NOT mixing with your coolant!)
So obviously there is something more to this than meets the eye.It turns out that on all Pre2006 R1's the Water Pump is internal and if it leaks, You guessed it, It used this overflow pipe to stop the coolant mixing with your oil.
This is where my mechanical knowledge ends and i will be taking my bike to a real mechanic to swap out the water pump for me.
The good thing is, if you already remove your exhaust system and drop all your oil etc this will save around 1-2hours of labour at the garage!When they've fixed, get them to replace the oil and filter and leave them your exhaust if you like to fit and they can run it up and test it before returning to you working:)
Samantha x
May 17, 2012 | Yamaha YZF-R1 Motorcycles
My coolant keeps diaappearing and now my car wont start
Check your oil level and see if the coolant is mixing with your engine oil .
If the coolant is not draining on the floor then it's still in the Engine probably drained into the oil pan.
Mar 25, 2012 | Heating & Cooling
Hi, i have automatic passat 1999 model and recently water happens to get into the gear box and it control board, i experiences a boom sound anytime the gear is changed, the oil has been changed by the...
If no external leak and the transmission fluid colour looks white, the problem belongs to the automatic gearbox oil cooler. The oil cooler has broke mixing the gearbox oil and coolant causing this milkshake. It's a small radiator core type oil / water heat exchanger. It is cracked inside and transmission oil is mixed with engine coolant. Because the transmission oil pressure is greater than engine coolant pressure, the transmission fluid level drops. See also the coolant colour inside recovery coolant reservoir inder bonnet! It could be like this:
The automatic gearbox oil cooler type oil / water heat exchanger (oil cooler):
In the picture above the transmission oil pan was removed for oil filter replacement.
May 05, 2011 | 1999 Volkswagen Passat
Car overheated once. added more coolant. Now coolant level goes down gradually from time to time, but engine oil seems to be rising. no coolant on the ground that I can tell. whats the problem?
have you noticed some coolant in your engine oil? it will make some bubbles/foam in your oil. If so, the engine head might be cracked and your coolant is mixing with your engine oil. That would explain the reason why your coolant goes down and your oil level goes up.
Nov 30, 2010 | Buick Rendezvous Cars & Trucks
Transmission fluid level need regular top up and there is no external leak.Fluid color looks white.
(In the picture above the transmission oil pan was removed for oil filter replacement).
Oct 29, 2010 | 2005 Audi A4
Engine oil is mixing with coolant
You need to find it, and not run it, as coolant in the oil destroys things fast. Pressure test your coolant system to find a leak. You might be looking at head gasket, or even water pump seal area to start.
Jun 22, 2010 | 2005 Honda CRF 250 R
I have 2001 325 bmw the problem is leaking coolant i change de reservoir coolant tank and cap but still loose coolant,the engine does not came hot but need refill coolant whats will be the problem and the...
your coolant and oil engine is mixing you have bad head gasket thats why you have smoke you need gasket work this is were coolant is going mixing with motor oil look at ur oil and it is loke milk white
Feb 20, 2010 | 2001 BMW 325
Air Tools & Compressors Logo
35 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
