Question about Western Digital My Book Essential 1TB External USB 2.0 Hard Drive
Wd usb port is broken
Usb port on external drive is broken
  • 3 Answers
You can buy a new one and install it yourself. I had the same problem but I fixed it myself. Here is the link.
http://www.centrix-intl.com/details.asp?productid=9501
Its only 10 bucks. I hope this helps!!!!
Posted on Dec 10, 2010
2 Suggested Answers
  • 31 Answers
SOURCE: WD External HD not recognized after working for 5 years...
repartion it with disk management
Posted on Mar 26, 2010
My WD Elements SE External drive does not have its driver recognized on boot, but does only after repluging its USB 2.0 connection. How do I get the driver recognized on boot? Why does replugging work
I guess it's some kind of a problem with the way your USB port works. I have an external WD too, connected to a USB 3.0 port and definitivly it's not detected at boot, just after windows startup as a USB device.
After some initial wondering about this problem, I decided no to worry more because I use external drive for data backup and if it is not detected by BIOS makes no difference.
It might be a problem of an outdated BIOS or the USB port's driver. In my case, boths, BIOS and USB 3.0 are rather old.
You can do some reading about issue if you do a ggogle search for issue
USB 3 0 external Hard Drive not detected after Intel Communities
External USB 3 0 HDD is not detected in Windows after boot Help
Aug 06, 2015 | DMCOM Western Digital Wd Elements Se 1 Tb...
How do I fix my external hardrive usb port? (the one on the drive)
Check this YouTube video for opening the case https://www.youtube.com/watch?v=ITObQxytdH4. It just pries open; some comments there recommend using fingernails or a guitar pick. Once the drive is out of the case, you should be able to see how the USB port was held in place. Perhaps just snaps back in place. If fastening parts are broken and the drive is out of warranty, I would try epoxy. If in warranty, WD should fix it for you.
Oct 21, 2014 | Western Digital My Passport Essential...
USB port not working
You can purchase another identical External Drive and swap the HDD inside it to recover your data or simply install the removed drive into a Desktop computer as a secondary drive to recover if the problem is actually the USB port.
Dec 21, 2012 | Western Digital WD Elements Desktop...
Hi i`ve just bought the wd elements 320gb yesterday. the problem is that i put the usb in and the light on the product is on but thats all. its not installing and i cant find it on my computer.
The obvious question first is the drive connected with the provided AC adapter?
Are you connecting it directly to a USB port or powered USB Hub? This is not important in external hard drives but it does on portable HD. But just in case keep this in mind.
Other thing is that you have to install the WD Smartware software.
If nothing works, try it on another computer.
If it works, must be a USB port problem.
God Bless You!
Feb 05, 2011 | Western Digital Elements powered by WD 320...
My new WD 320 GB external drive won't detect in my pc and laptop? pls help....
Hello there,
Please try to plug it into another USB port. There is a chance that your port could be faulty. If its not with the port, try to assign the drive letter if you are using windows. You have to right click on the My Computer icon, select Manage. Once on Computer Management, select Disk Management. Locate your WD drive and right click again. Finally, click on the Assign Drive Letter and follow the wizard.
Dec 26, 2010 | Western Digital Elements powered by WD 320...
Passport 160GB External USB 2.0 Hard Drive - Black: I have a wd 160g external hard drive and everytime...
right click START ,choose properties,choose taskbar then customize ,and select power surge...and select ALWAYS HIDE
this way you get rid of the pop-up message and just don't worry about it :))
Or
Delete all the USB ports in the devices manager,
then restart the computer to let XP install all the USB ports again. Then go to the first USB port and right click on it and go to properties. Then on the advance tab click on do not show warnings
Jan 19, 2018 | Western Digital Passport 160GB External...
Cant install wd external hard drive
Try usjng a different USB cable and a different port. Are you certain you are using a USB 2.0 port or is this an older machine with USB 1.0? If so, a newer 2.0 device might not work.
Oct 10, 2009 | Western Digital Wd Passport, Portable USB...
My usb ports are limited to 500mA each one and the WD external HD needs at least 1000mA. How can I solve that?
You might need to install a new USB card, one with 1000 mA, to provide the power necesary for your WD external drive. Check the WD manual to see whether there is a way to use two USB ports when jumpering them to see if you can provide the power yourself.
Also check the WD web site.
Jun 26, 2009 | Western Digital Passport 120GB External...
I have a WD passport 320gb, at first it worked one of my usb. then all of sudden, it stop recognizing my WD Passport with one usd port, so i plug it in another usb then it works. and after a couple of days...
Are you using an external power supply for the disk? If not, you might be overloading the USB port. It should not happen, but USB ports are limited in the amount of power they can output. Especially laptops might face such problems.
Do other USB devices still work on those USB ports? If so then the port is at least not broken.
Sometimes you can uninstall and reinstall the USB hubs and controller devices in the Device Manager to fix USB problems.
For other ideas on troubleshooting external hard disk issues, you can check: www.devicedriverfinder.com/blog/device-errors/external-hard-drive-troubleshooting
Jun 13, 2009 | Western Digital Passport WDXML800UE...
Western Digital My Book Essential 1TB External USB 2.0 Hard Drive Logo
700 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
