Question about Siemens Simatic S5 HMI Monitor
CPU will not reboot
Will not go into run mode, red led stop mode stay on. Green led goes on for a breif second then goes out
  • 518 Answers
Computer not starting up,theres a bios reset button,try that,does the monitor show anything atall,if not check cable to monitor
Posted on Jul 05, 2010
Nissan pulsar 1987 n13 the ECM light came one and the car cut out and won't start again and I need to know where the ECM is
Hi, the computer is under the passenger's seat. Code extraction procedure is pasted below.
READING CODES Modes will not switch while the engine is running. The ECM automatically switches to MODE I when the ignition is switchedOFF.
1984-90 Vehicles With Dual LED System
The self-diagnostic system has 5 modes. To switch modes, switch the ignition ON and use a screwdriver to turn the mode select switch through the access port on the ECM. The inspection lights will begin to flash. When the desired mode has been entered, turn the screwdriver fully counterclockwise. The red LED and green LED perform different functions in different modes.
Mode I-
This is the normal vehicle operating mode. The green LED will indicate loop status. If the green LED is not blinking when the engine is running, the vehicle is in open loop, or the HO 2 S, O 2 S, or sensor circuit has a malfunction. If the green LED is blinking, the vehicle is in closed loop. If a malfunction takes place, the red LED and the MIL will glow, indicating a malfunction has occurred.
Mode II-
Both the red LED and green LED are used to monitor mixture ratio feedback control. The green LED will function as described in MODE I. If vehicle is in open loop, the red LED and green LED will remain on or off. In order for results to be valid, vehicle must be in closed loop. In closed loop, the red LED remains off if the system is running rich, comes on if the system is running lean, and blinks at the same time with the green LED if system is within 5% of the exact air/fuel ratio.
Mode III
-When this mode is accessed, the codes stored in the ECM's memory will be flashed by the green LED and red LED on the side of the ECM. The red LED will light first. This is the first digit of the trouble code; the green LED will flash next, showing the second digit of the code. For example: 2 flashes of the red LED followed by 1 flash of the green LED corresponds to Code 21.
Mode IV-
This mode is used for checking the throttle plate (TP) switch, starter, and vehicle speed switch status. When the TP switch or starter switch is activated, the red LED will briefly flash as the status changes. For VSS status, the green LED will remain off when vehicle speed is less than 12 mph (19 km/h) and come on when vehicle speed is greater than 12 mph (19 km/h).
Mode V-
This mode represents a real-time diagnostic test of the crank angle sensor, ignition signal and the mass airflow signal. The malfunction code will be displayed only when the malfunction occurs and will not be stored in memory. The output code will appear as a single or short string of pulses. Count the number of pulses for the malfunction code.
1 pulse-CMP sensor signal lost or noise in signal 2 pulses-MAF Sensor signal abnormal 3 pulses-Fuel pump circuit shorted or open 4 pulses-Ignition signal lost
Apr 19, 2011 | 1987 Nissan Pulsar
How to unlock motorola 3G A1000
Try this: Might work.
Connect the phone to a powered Clip. Phone display should give "USB cable connected" message.
Press UNLOCK button on the Clip.
Phone reloads. Within 5-10 seconds phone display gives "Waiting for PST" message.
Press 1 and 2 keys simultaneously in upper part of the handset. The phone enters boot mode (if you don't press these two keys during "Waiting for PST" message, the Clip will give red E/G led and you will have to start with step 1 again).
After 1 and 2 keys have been pressed E/G green led will blink and the phone reboots. Meanwhile E/G will give frequent green blinking and phone will turn on.
Do not disconnect cell phone from Smart-Clip while green led indicator blinks!
Green E/G led glows. The cell phone is unlocked.
Axxx/Exxx/Vxxx unlocking noteDon't unplug cable right after phone reboot, wait until E/G led stops blinking!
good luck.
kc
Mar 11, 2011 | Motorola Cell Phones
I am not sure if this is a problem with power supply. Yesterday suddenly my machine stopped working. I wasnt using it. It just shut off. Now when I started the cpu, I see one green LED on the mother...
the problem is in your motherboard..this most cause unregulated flow of power from the source electric..but if the green led is off so its the processor.try to test it with a motherboard tester..or get another board that same spec with the you have,and transfer the processsor if it is working
Feb 10, 2011 | Cooler Master RS-400-PSAR-J3 400W ATX12V...
Hi, My SONY CPD G420 monitor has suddenly stopped working - the front led is blinking amber. After power cycling the LED stays green for a few seconds before going back to blinking amber. I have verified...
just unplug the signal cable and see if it shows a warning! if it shows then the monitor is in some working condition! this problem mainly is not the monitors problem its the systems problem, it seem as if the system is in standby when u on it right??? it happens when the processor doesn't get supply or it refuses to come on! you will see that the red hdd load led will not light when u start the CPU; just open the CPU and unplug the smps from the board and blow the pins to clean them up and re-fix it and see it will work. if still it doesn't work try some other smps it will work! reply and revert back for more help with a vote!
Jul 24, 2010 | Sony CPD G420 19" CRT Monitor
Tv won't turn on
yes but you have to open the tv
Mar 01, 2009 | Loewe Aconda ACO9303 30" TV
Compaq Presario 4400us
Either the new power supply you purchased is not functioning correctly. But, assuming it is now that you are getting some form of power to your PC, it is very likely the motherboard. Whatever fried your old power supply (or it could have just been the power supply itself) most likely fried your motherboard in the process. Probably not the CPU since the MB can't even post.
Jun 21, 2007 | Compaq (388746-001)...
Computers & Internet Logo
272 people viewed this question
Top Siemens Computers & Internet Experts
Prashant M
Prashant M
john smith
Are you a Siemens Computer and Internet Expert? Answer questions, earn points and help others
