Question about Hitachi (DT00431) Projector Lamp for CP-S370W, CP-X380
Iamge from the previous projection from RGB still appears when i switch to Video mode. why is it?
I was projecting from my laptop (powerpoint presentation) for about 3 hours, then when i switched off my laptop, took off the RGB cable and switch the projection to video mode, the (powerpoint) images from my laptop still appears on top of the video images. is there any problem with the lamp? or is it something else? i have tried a few things including switching the whole unit off for a good half an hour before switching it on again on the video mode but the powerpoint image is still there overlapping on top of the video. appreciate your kind assistance. thanks.
  • 563 Answers
Hi There
Looks like your Projector's Mainboard has locked the memory and is stuck.
If you can access the Projector's Menu - Reset the machine and switch it off.
If the problem still occurs , you will have to take your Projector to a Service Centre to have to Mainboard repaired.
This is 100% NOT a lamp issue.
Posted on Apr 18, 2008
My tv screen when on turns yellow then after a while it will switch back to normal colors what can be wrong with it....
Televisions covered: all Projection with yellow picture, but not Projection TVs with a yellowish tint surrounding objects in a nearly normal picture.
Yellow = red + green
normal picture = red + blue + green (RGB). See illustration.
Fig. 1 Additive color mixing in an RGB monitor, or RGB Projection TV.
The circuitry powering your blue output, or the blue light engine itself is starting to fail.
Operating Theory:
The lamp module shines a bright light into the optical unit; there are a series of lens and baffles, and at the top of the light engine, a lens puts the picture into a mirror which is reflected onto the screen; All video and color is processed thru the light engine. Blue most commonly fails first, leaving a yellow picture.
Dec 26, 2011 | Mitsubishi WS-55805 55" Rear Projection...
My dell d630 laptop wont recognize my infocus lp70+ remote control and I can't advance my powerpoint slides with the remote control
Here's what the User's Manual says:
Using the Remote Control
To advance PowerPoint slides with the projector's remote, you
must connect the USB cable on the projector's computer cable to
the computer. See page 8 for more information.
Point the remote control at the projection screen or at the front or
rear of the projector (not at the computer). The range for optimum
operation is about 30 feet. If you point the remote at the
projection screen, the distance to the screen and back to the projector
must be less than or equal to 30 feet. For best results, point
the remote directly at the projector.
If you are displaying presentations in Microsoft® PowerPoint®,
you can use the remote's Previous and Next buttons to navigate
through your presentation while in Slide Show mode.
Jan 26, 2011 | InFocus LP70+ Multimedia Projector
Is it possible to use the rgb input on the sd-643hd5 as a computer monitor input? My laptop has a female 15 pin video out which seems compatible with the tv's input except that they are both female...
O don't see why not. They are both female by default, as we don't want VGA pins poking out of the rear of our laptops to catch on stuff.
Don't forget to tell the laptop to switch to external screen.
Hope this helps.
Nov 23, 2010 | Pioneer SD-643HD5 64" Rear Projection...
Connect laptop to toshiba 50h8250
This requires a converter. If the laptop has a VGA port, use an VGA to component video or VGA to composite video converter. See this site for some examples: http://www.svideo.com/pctocomponent.html . Do not use a VGA to component video cable - these are meant for projectors that use RGB signals.
If the laptop has an HDMI port, you'll need a different type of converter, like this: http://www.hdtvsupply.com/hdmi-to-component-adapter.html . Then set the output to YPbPr.
I hope this helps.
(I doubt your laptop has a video controller that can output a non-RGB signal.)
Nov 14, 2010 | Toshiba 50H82 50" Rear Projection...
I have conected my laptop to a projector using a rgb connection and get the bootup picture from my laptop onto the screen then it dissapears and just shows a blue projected screen. I have tried using Fn...
try to restart your laptop into safe mode with still the projector connected. notice if your safe mode desktop appears projected as exactly as your laptop's desktop screen. if so, you only need to further configure your display settings.
Dec 29, 2009 | Fujitsu Siemens AMILO Pro V2000 Notebook
HD TV - Comcast - Samsung TV - "Component 3 not supported mode"
Hello willardlang,
This is because of the type of Component Video being used. Let me explain We got so use to the term RGB to explain component video we for got that there are two standards for component video and they are not compatible. These two standards are Component Analog Video (Y, R-Y, B-Y) and Component Digital Video (Y/Pb/Pr) or (Y/Cb/Cr)
Now, the problem is they never told us the public which one to use and when, they only told us RGB. Now to complicate things, you have have to figure out which one to use. So here is a helpful yet flawed hint:
If the TV was made after 2003 use Component Digital Video (Y/Pb/Pr) or (Y/Cb/Cr)
If the TV was made before 2003 use Component Analog Video (Y, R-Y, B-Y)
Yes this is flawed but for the most part it's good.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Jul 02, 2009 | Samsung HLN5065W 50" Rear Projection...
My toshiba tlp 261 won't project the image
hi try using the function key to toggle the display output form the laptop.every laptop when connected to an external display like projector works in the multiple diplay mode.in this mode the laptop vga output can be seen in 3 modes------ only laptop screen, only external deipaly(projector) & both laptop & projector.check this & this should work fine
any further help contact shyam +919867355202
Feb 07, 2009 | Toshiba TLP 261 Multimedia Projector
Delay/ whitescreen when projecting video from laptop
1.
Connect the external display port on your laptop computer to the projection system, and then turn on the projector. For information about connecting external devices to your laptop, see the documentation for your laptop computer.
1.
Set the display resolution of your laptop computer to match the resolution of the projector system. First, on your laptop, open the Display Properties dialog box by using the Display icon in Control Panel, and click the Settings tab. Then, in Screen resolution area, move the slider to adjust the display resolution of your laptop. If you don't know which setting to choose, try 800 x 600 pixels; this is a common setting for many projector systems. YOURS sounds like 640x840.
3.
If you have audio in your presentation, connect a cable from your laptop's audio output jack to the audio input jack on the projector, and then test the volume by playing a file that contains sound.
4.
Start the Player on your laptop. If you want to only display the Player on the big screen, and not the desktop background, maximize the Player or set it to play your video using the entire screen (full-screen mode).
Jan 08, 2009 | Dell 3300MP Multimedia Projector
Pioneer Elite Projection PRO-620
the switch is onthe rear to select RGB or video S
May 10, 2008 | Televison & Video
Advent 42" Plasma Tv
It sounds like the tv maybe in RGB mode.
Dec 30, 2007 | Mitsubishi WD-52525 52" Rear Projection...
146 people viewed this question
Top Hitachi Office Equipment & Supplies Experts
jasbo
jasbo
Chris Goulet
Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
