Question about Maytag M7Y10F2A Air Conditioner
Window air conditioner not blowing cold air
Used one summer just put back in window and not blowing cold air Maytag model #M7Y10F2C-A
Filters have all been cleaned
  • 24 Answers
SOURCE: Hot air coming out of back
portable air conditioners mainly have two hoses one hose is exhaust thats the one that is blowing hot air. the one pulling is return.. the hot air blowing out should be exhausted to the outside. the blowing air needs a hose and to be laid out a window the back should have model and serial maybe product number. the two holes are either 4 inch or three inch and most portable units other than hand me downs come with a window frame that allows the hot exchanged air to go outside and cooler air to be used for heat exchange.
Posted on May 28, 2009
james3751
  • 614 Answers
SOURCE: window air cond unit, several years old, doesn't blow as cold
The problem with window units and any service tech will tell you it cost more to repair than you can buy at Walmart or home depot. Unless you know someone who can charge it for you. Window units are a sore subject. A 200 dollar window unit might cost 200 dollars to charge system. SORRy rusty
Posted on Jun 14, 2009
SOURCE: I have a Maytag window air conditioner that is leaking out front
The unit has to lean backward to let the water run out. It sounds like it is too level or leaning forward too much. There should be an adjusting screw in back that you can lower and it should work fine.
Posted on Jun 27, 2009
  • 233 Answers
SOURCE: Unit not blowing exhaust!!!
http://safemanuals.com/brand-user-guide-instructions-owner-manual/MAYTAG, this may help you locate the issue. there may have been some degris that is keeping the blower cage from turning, or the cage may be damaged.
Posted on Jul 19, 2009
  • 74 Answers
SOURCE: maytag
Could be several things. Make sure evap coil is clear. Use a garden hose if you need to for the mud in the back. If both coils are (clean evap and condenser) Then it probally is short on refrigerant.
Posted on Jul 29, 2009
AC not blowing cold air
Make sure your filters are clean first. Then you can get the refrigerant charge checked and some added if necessary. I would get some prices first. Its just about as cheap to get a new window unit as it is to get one charged so check around first.
May 26, 2010 | Maytag M3X05F2D Air Conditioner
Maytag-M7Y10F2C Trying to select the most efficient setup mode.
Just set it to auto and set the thermostat as high as you can stand it.It will shut off when it reaches the temp that you set and stay off until needed again
Jul 30, 2009 | Maytag M6Q10F2A Air Conditioner
Window air cond unit, several years old, doesn't blow as cold
Jun 13, 2009 | Maytag M6X06F2A Air Conditioner
My room air conditionar is not blowing out cold air,please help
if the compressor is running then the refrigerant has leaked out and repairs on that are 140usd+ , check the warranty on it.
Phil
Jun 10, 2009 | Heating & Cooling
May 28, 2009 | Maytag NMPEB08F2A Air Conditioner
Soleus MA-9000AH blows hot air
Sounds like the compressor is not running. This model had lots of problems with over heating. It also will never really blow more than a moderate cooling through it. Since you have cleaned all the filters and is still 100 deg, I believe the failure will be the compressor itself or the capacitor.
If you find an oily residue in the drain or on the pipes, it may have simply leaked the refrigerant out. Good Luck!
Jun 18, 2008 | Soleus MA-9000AH Air Conditioner
Problem with GE Zoneline 5200 model
Heat pumps have saftey circuits that prevent liquid flooding of the compressor. Inadequate airflow across the evaporator in cooling can trip this circuit. Have your package unit serviced with particular attention to cleaning the evaporator coil and be sure your filters are clean and changed frequently in the summer months. Hope this helps GL!
Jun 07, 2008 | GE Zoneline AZ38H12DAD Split System Air...
Seems fully operational but not blowing cold air
Sounds like you may have a small leak in the sealed system. If you don't have the receipt, contact the factory and provide them with your model and serial numbers, and if they fall within the warranty manufacture date, you should be able to get any Danby factory authorized service center to repair it for you, in accordance with the factory warranty policy.
Jun 02, 2008 | Danby DAC8003D Air Conditioner
Maytag M7Y10F2A Air Conditioner Logo
70 people viewed this question
Top Maytag Heating & Cooling Experts
Bill Long
Donni Steen
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
