Question about Apple MacBook Pro Laptop Computer with Intel Duo Core 15.4 Inch PC Notebook
I get an error message in Toast. On my MacBook Pro the message reads 'Sense Key = MEDIUM ERROR' and 'Sense code = 0x73, 0x03'. Is this a dirty lens?
  • 45 Answers
It can be dirty lens/ drying laser or glitch in software.. Clean your lens, check for laser adn reinstall drivers for toast. If still does not work then provided me your os version, toaster brand - hardware and software name.
Posted on Jul 05, 2010
70017 error
The error code 80070017 indicates a read error in one of the installation files. This may be caused by a corrupt installation medium (dirty, scratched or otherwise defective DVD; image burn process went wrong in case you created the DVD yourself from an image; defective memory if installation from USB stick).
The file may also got faulty on download; try to download the installation image again.
If the error persists, clean your DVD burner, use quality media and lower the burn speed.
Mar 13, 2014 | Microsoft Video Game Consoles & Games
SENSE CODE = 0X73,0X03
According to this, it seems to be dirty lense, or the drive doesn't like the media.
Sep 29, 2013 | Apple Part MB576Z/A,"
MATSHITA DVD-R UJ-85J error in burning
cud be poor quality disks you are using, depends
macs are quite reliable so I cant blame the drive itself
toast isnt part of mac and there are reliablity issues from it.
Jun 04, 2010 | Apple 17 MacBook Pro Notebook Computer ...
I inserted a blank disk into my mini mac. It did not come up on my desktop. I can't discharge it....How?
When you install Toast, one of the install questions is whether you want Toast to recognize blank CD's or DVD's when they are inserted. If this was set to yes, then I believe this could override the OS acknowledgement and Toast will take over.
One way to check is to open up Disk Utility (Applications > Utilities > Disk Utility) once you insert a blank disc, if you see the blank disc, try using Disk Utility to mount it, than it will should show on your desktop.
If you want the OS to mount the disc all the time, check your Toast settings.
Check both the preferences in Toast but also under System Prefs-->CDs and DVDs...there is an option there to choose what the computer should do when a blank DVD is inserted. Probably Toast set that System Pref to "Open Toast" based on your install configuration.
The Finder Pref you refer to only determines if CDs and DVDs recognized by the Finder show up on the Desktop. This is only a display preference, not really a determination of whether the Finder is the primary app that will recognize a blank disc. The CDs and DVDs panel in the System Preferences is where you need to go.
if that doesnt solve ur issue... i wud recommend u to reset ur pram and smc.....
Resetting PRAM and NVRAM
  1. Shut down the computer.
  2. Locate the following keys on the keyboard: Command, Option, P, and R. You will need to hold these keys down simultaneously in step 4.
  3. Turn on the computer.
  4. Press and hold the Command-Option-P-R keys. You must press this key combination before the gray screen appears.
  5. Hold the keys down until the computer restarts and you hear the startup sound for the second time.
  6. Release the keys.
Your computer's PRAM and the NVRAM are reset to the default values. The clock settings may be reset to a default date on some models.
Resetting PMU on PowerBook or iBook computers In some troubleshooting situations, if resetting PRAM does not resolve an issue, resetting the PMU may be the next appropriate step. For information on when this is appropriate and for instructions on how to reset the PMU in your PowerBook computer, see Resetting PowerBook and iBook Power Management Unit (PMU).
Additional Information Resetting NVRAM in Open Firmware If your computer is Open Firmware-based (Power PC) and you are unable to reset NVRAM as described above, you may alternatively reset the NVRAM and Open Firmware settings using the steps in the Solution section of Message “To continue booting, type 'mac-boot' and press return”.
In some cases, an Open Firmware-based computer may not respond to the keyboard commands noted above, and may not allow starting up into Open Firmware by pressing and holding the Command, Option, O, and F keys during startup. If you are unable to get to an Open Firmware prompt (and your computer supports doing so), try powering on the computer with the power button held down continuously—as if you were doing a firmware update. This should force the computer into Open Firmware, allowing the steps in the article noted above to be used.
Contents of PRAM Some Macintosh computers may not have all the settings described below. For Mac OS X information, refer to Mac OS X: What's Stored in PRAM?
  • Status of AppleTalk
  • Serial Port Configuration and Port definition
  • Alarm clock setting
  • Application font
  • Serial printer location
  • Autokey rate
  • Autokey delay
  • Speaker volume
  • Attention (beep) sound
  • Double-click time
  • Caret blink time (insertion point rate)
  • Mouse scaling (mouse speed)
  • Startup disk
  • Menu blink count
  • Monitor depth
  • 32-bit addressing
  • Virtual memory
  • RAM disk
  • Disk cache
with respect to ur SMC...
The System Management Controller is an integrated circuit (computer chip) that is on the logic board of the computer. As the name implies, it is responsible for power management of the computer. It controls backlighting, hard disk spin down, sleep and wake, some charging aspects, trackpad control, and some input/output as it relates to the computer sleeping.
Over time, the settings in the System Management Controller may become unusable, which can result in operational anomalies with the computer. Examples include not turning on, not waking from sleep, not charging the battery, or not recognizing the AC Adapter, among others.
Resetting the SMC is not intended for resolution of a stall or situation in which the computer is unresponsive. An SMC reset should not be necessary except as a last resort in cases where a hardware issue with the power management system is suspected. Performing an SMC reset resets the hardware power management functions.
For most situations, a restart is sufficient. If the computer has stopped responding, try each one of these steps, one by one. Test between each step to see if it has worked. If one step works, don't worry about the next one. You should only reset the SMC if you've tried all of the steps listed here and the computer still isn't working.
  1. Force Quit (Option-Command-Escape)
  2. Restart (Control-Command-Power)
  3. Force Shut Down (press the power button for 10 seconds)
Only perform an SMC reset on the computer if none of the above steps resolved the situation. If this is the case, see below for instructions on locating the reset button or key combination for your model of computer. If your computer is earlier than the models listed here, see "Resetting PowerBook and iBook Power Management Unit (PMU)" or "PowerBook: Resetting Power Management Unit (PMU)".
MacBook (13 inch, Late 2008), MacBook Pro (15-inch, Early 2008), and MacBook Pro (17-inch, Early 2008)
  1. If the computer is on, turn it off.
  2. Disconnect the AC adapter and remove the computer's battery.
  3. Press and hold the power button for 5 seconds and then release the button.
  4. Reconnect the battery and AC Adapter.
  5. Press the power button to restart the computer
Note: Starting with MacBook Pro (Late 2008) and MacBook (Late 2008) models, you may instead use the reset method for MacBook Air (below) to reset the SMC. All earlier models of MacBook and MacBook Pro must use the method described above, which involves removing the battery.
MacBook Air and MacBook Pro (Late 2008 and later)
  1. If the computer is on, turn it off by choosing Shutdown from the Apple () menu.
  2. Connect the power adapter to a working power source.
  3. On the built-in keyboard, press (left) Shift-Control-Option along with the power button once.
  4. Wait 5 seconds and press the power button to start the computer.
Note: You must use the keys on the left side of the built-in keyboard.
You should only perform an SMC reset when the MacBook Air or MacBook Pro (17-inch, Early 2009) has been properly shutdown. This prevents issues from occurring to the file system.
While the power adapter does not need to be connected to reset the SMC, it may be necessary in situations where the battery needs charging or if the computer has been without power for an extended period of time. You can also visually check the SMC reset by observing the LED on the adapter. It will momentarily turn off as the SMC resets.
Jul 16, 2009 | Computers & Internet
The drive reported an error: sense key-medium error sense ode= 0x0c write error iomega 48x24x48x cd/rw usb burner
this is almost certainly a dirty lens on the writer. clean it with a lens cleaning disk.
May 07, 2009 | Iomega (32885) CD-RW Burner
New Mac ibook
I would suggest that you take it to the apple store and they should be able to fix it for you.
Jan 10, 2009 | Pacific Digital (U30274) DVD±RW...
TDK CD-RW Burner Sense Key Error
You may try this dvd creator for mac, I always use it to burn music and dvd, it works pretty well for me
http://macdvdcreator.mac-dvd.com
Mar 28, 2008 | Computers & Internet
DVD write fails
Restart your computer, when computer chimes during restart, press and HOLD these keys: "Apple+Option+P+R". Continue to hold all four keys and wait for the computer to chime three more times, there is a small interval between each chime as it is resetting the video memory and something else.
After the 3rd chime, you can release the keys and start up as normal, test your DVD burner again and see if it's working.
If you are still having problems I suggest you then test the drive with Verbatim or Apple media. It very well could be that the drive's firmware doesn't support the brand of media you are using.
You can see user reports about your media by inserting a blank DVD and choosing Disc Info from the Recorder menu in Popcorn/Toast. In the window that appears there is a link that takes you to a videohelp.com site where people submit user comments about different brands of media.
If you insert a disc, and here it make a "churning " type sound, it machine may be calibrating the laser. YOur computer may also be under the APPLECARE warranty. If have attempted to fully troubleshoot the issue to no avail, your machine may be eligible for a replacement.
I know it might sound a bit wierd, but stranger solutions have solved problems ... please keep us updated with your progress..
Jan 13, 2008 | Apple MacBook Pro Notebook
DVD write problem and hardware test error code
I hope this works for you it did for me when I updated all my firmware.
http://docs.info.apple.com/article.html?artnum=88275
Jan 13, 2008 | Apple Power Mac G5 Desktop
Apple MacBook Pro Laptop Computer with Intel Duo Core 15.4 Inch PC Notebook Logo
119 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
