Question about Vacuums
After being used to **** up quite a bit of flood water on basement carpet, the motor races and nothing seems to work.
  • Hank Borkovitz Jul 05, 2010
    We have a Bissel QuickSteamer. Please make your advice specific to this product. It does not have a rotating brush or belt to drive it.
    After picking up a lot of clean water due to a failure of a sump pump it quit working. The motor just races.
    Thanks!!
    President:
  • 1,561 Answers
First, you'll need to take apart your vacuum cleaner. Vacuums come in two types: the upright vacuum and the canister vacuum. With the upright vacuum, you push the entire thing around to clean. The canister vacuum sits in one spot and you simply move the hose. To take apart an upright vacuum, unplug the vacuum and remove the screws from the handle. Take off the handle and the hose if yours has one. Remove the screws from the bottom and lift off the top cover of the vacuum. For a canister vacuum, unplug it and take off the hose, dust bag and the filter. Simply remove the screws and lift off the lid. If the filter is dirty, make sure to replace it before reassembling the vacuum.
The beater bar is the casing in the front of the vacuum that has the brush inside of it. After taking off the clips at the ends of the beater bar, you should be able to move the drive belt and take the beater bar out. Open it up and see if the brush looks worn down. If it is, replace it. If there is any hair or other debris tangled around it, cut it loose with scissors. This debris can keep it from turning properly and may fix your problem. Reinstall the piece and the drive belt and see if it works.
Another common problem is the drive belt of the vacuum cleaner. To remove the drive belt, you'll only need to remove one of the clips from the beater bar and loosen the drive belt until it is free of the beater bar and the motor. If it looks worn, cracked, or broken, buy a new drive belt. Install it around the beater bar and the motor like the original was before you took it out. Note that the new drive belt will not have been stretched out yet and may look like it's a different size than the old, stretched drive belt.
Finally, inspect the attachments of the vacuum before trying it. Use a stick or a long, thin pole to push any objects out of the hose attachments. Wash and thoroughly dry the various hoses and attachments to clear them of dirt and debris. Make sure they are completely dry before using the vacuum to prevent getting shocked. Once the vacuum is reassembled, do a short test run. If you're still having a problem sucking up dirt or getting the attachments to work properly, call a professional to fix it. If it is cheaper, you may want to buy a new one instead.
Take care.
Posted on Jul 05, 2010
    Have you specific information to the Bissel Quicksteamer? It has no belt for its fixed non-rotating brush!
Vacuum motor noise and smell
If the ball was stuck and you sucked water into the motor it could cause it to smell like it's burning if it ruined the motor
Jan 10, 2014 | Shop Vac Vacuums
Water in henry hoover motor HVR 200A
Chris, I hate to be the bearer of bad news, but you've already guessed it. You need a new machine. Personally, if I were you, I'd check into the small shop vac's, type of vacuum. Craftsman has a good one that I've been using for, wow, more years than I can remember now. I had it a long time I know that. I actually picked up a spare one at a garage sale last summer and put it up on a shelf for one my old one finally bites the bullet, but so far, it's still going strong. The wet/dry vac's have a float system in them that actually plug the bottom of the air chamber where the vac draws it's air from, when the water gets too high in the tank. The motor starts to race faster than normal and that's the tipoff that it's full. Dump out the tank and go at it again. Better luck this time.
Nov 10, 2013 | Numatic Henry Bagged Canister Vacuum
Instruction manual for hoover swish carpet cleaner
my hoover swish dosent seem to **** up much of the water out of the carpet carpet is still quite wet and bot much water is sucked up for the amount of water that goes in the water dispenser
Nov 26, 2010 | Vacuums
Carpet not getting moist
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
eyrye
Mar 09, 2010 | Bissell 8910 ProHeat Clear View Upright...
Ridgid 16.5 gallon motor running with no suction
When you use the shop vac for cleaning up water you must remove the filter.
The filter is for dust particles not for water
I would replace your filter and dump the water out from the shop vac, Also after each time you vacuum up water dump it out of shop vac.
I hope this helped you happy new year!
Jun 30, 2009 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
Bought house. Inherited shop/vac. A bit old, but
If you are going to use the wet vac to remove water, be sure to remove the bag inside the canister first. Also, some wet vacs have an internal float that has to be installed, but that may not be the case with yours.
May 16, 2009 | Shop Vac 584-06-00 Canister Wet/Dry Vacuum
Brush motor quit
The beater bar belt is broken.
Nov 18, 2008 | Bissell 1697-7 Powersteamer Pro Deluxe...
Dirty water blowing out of hole in top of unit... help!!!
perhaps your husband took the water stop(float) ball out of it . that stops the unit from over filling with water .
Mar 09, 2017 | Shop Vac 401-04-62 Original Wet/Dry Vacuum
Power brush motor seems too weak
This machine needs a new belt. The belt is stretched into position and even if it is not used, will fatigue over time. This can occur as the machine is in storage waiting to be sold. If you check the bristle on the roller, you will observe that it extends out the bottom of the powerhead quite far and is very stiff. This causes the brush to engage the carpet very aggressively and puts considerable strain on the belt. A tired belt will fail very quickly under these conditions. You should take it to a warranty depot and have the belt changed.
This machine also has variable speed motor in the main unit. This is so you can adjust how heavily the powerhead brushes the carpet. If it is set too high, on certain carpets, the suction will pull the powerhead down too hard and this will bogg the roller and cause the belt to fail prematurely.
Feb 02, 2008 | Hoover S3765-040 WindTunnel Bagless...
Powerhead woes
You should not use this powerhead on any natural or oriental fibre carpet. If you check the brush roller, you will see that the bristle extends out the bottom of the powerhead quite far and that the bristle is very stiff. This is o.k. for synthetic carpets, but will be too aggressive on natural carpet. It will pull material out of the carpet and eventually thin it out. You should use a passive air turbo or a carpet tool for this rug.
As far as the belt is concerned, if it is over a year old, it is due to be replaced. Old belts are stretched and will come off because they are worn out. You might also check to make sure the motor is in place correctly. It is very common that when people want to check the inside of the powerhead, they commonly remove the three screws that secure the motor, thinking that these screws will open the powerhead. If you observe the area between the screws, you will notice that there is a "no screwdriver" warning there. The four screws for the hood are recessed and not as obvious as the motor screws, so this mistake happens quite a bit.
Jan 01, 2008 | Hoover S3755 WindTunnel Bagless Canister...
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
