My wash machine doesn't dry! - Washing Machines
  • 975 Answers
Need more information , do you mean it STOPS at the RINSE cycle ?? water still fill up ??
Posted on Apr 18, 2008
My beko wb 6004 ns doesn't spinning to dry the clothes
the issue is in the timer . have a qualified technician change it with a new one . thanks .
Jun 14, 2013 | Washing Machines
Hotpoint aquarius washer/dryer not drying
this is the stat (Tod) for short it has over loaded and is no longer working this is under the lid on top but its not an easy fix it involves taking the top drying compartment apart to get at it big job if you not mechanically minded OK but that's the problem
Oct 21, 2012 | Washing Machines
Washing/dryer machine will not spin and when drying selected attempts to wash
check this possiblities:
It doesn't pump or spin
frozen pulley or broken belt
It pumps, but doesn't spin
lid switch defective
It spins only with the lid closed
prevent to open the lid, test the switch see the diagram
May 11, 2012 | Washing Machines
Hoover vhd sensor dry 59 minute programme not working
"Rapid W&D 59 Min.
When you only have a few items to wash and dry in a hurry, this 59 minute cycle is the ideal time saver! Suitable for a light 1,5 kg load size (e.g. 4 shirts) or slightly dirty fabrics, this cycle will wash, rinse, spin and dry your garments in under an hour.
We recommend that you reduce the detergent dosage when using this programme to avoid wastage".
If the other cycles work without issue, it in not faulty.
Check the wash weight.
Sep 20, 2017 | Hoover Washing Machines
Hello! We have Ariston AML 125. We've been using it for 5 years now and before we didn't have any problem. But just a couple of days, the drying program doesn't work properly. The washing...
Sorry but you have not mentioned whether you were able to check the function of the drain motor itself- it could be blocked/jammed which would account for the machine not stopping (still trying to drain but being unsuccessful). Soaked clothes take ages to dry in a dryer!
Following are my complete and hopefully 'coverall' pre-typed guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Aug 27, 2011 | Washing Machines
"Clean" light keeps flashing. Machine doesn't
Hello & Welcome to FixYa
Flashing light is reset by pressing two buttons in sequence 3-4 times, to reset your dishwasher press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
Please get back to me if you have any other questions.
Kevin
Jul 15, 2011 | Kenmore Dishwashers
I have a L G and it does not spin dry the wash load How can this be fixed
Do you mean it doesn't spin at all...or it doesn't spin fast enough to dry the clothes?
If it will not spin at all you may have a loose belt or broken belt.
If it does not spin fast enough, you may have a loose belt or too latge a load.
Jun 26, 2011 | Washing Machines
Where is the lint collector on LG 7.5g model WD 1049C Front Loader washing machine.
The combo washer/dryer doesn't have a lint collector. Air is circulated through a condensate tube and is washed down during each drying cycle.
Jun 16, 2011 | Washing Machines
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
