Question about Weber Genesis Silver C Grill
My Weber genesis silver c does not heat up as it used to. Now it barely gets above 200 degrees far. What do you think the problem is? I am getting flames from all 3 burners and still I get to 200 max. My e-mail is "to2bad26@aol.com Thank you
Did you de-activate the excess flow safety device, as suggested on the troubleshooting page in the owners' guide? Turn control knobs to OFF and disconnect the regulator from the tank. Turn burner control knobs to HIGH, and wait 1 minute. Turn knobs off, reconnect regulator and SLOWLY turn the tank valve on. Light according to instructions. Worked like a charm, took no time, didn't get dirty, didn't spend a dime. Good luck! The Midnight Molar.
Posted on Aug 12, 2010
  • 140 Answers
Sounds like you need to clean your grill, check your regulator and replace that!
Posted on Jul 07, 2010
4 Suggested Answers
SOURCE: Weber won't get very hot
Safety valve needs reset.
  • Close the LP tank valve
  • Turn all burner control knobs to the OFF position
  • Open the grill lid
  • Turn the LP tank valve until it is completely open
  • Wait several seconds
  • Turn the front burner to the HI/Start position
  • Press the igniter until the burner is lit.
  • Turn remaining burners to High
  • Close the lid.
  • The grill should preheat to 500-550 degrees in 10-15 minutes
I called Weber and the rep walked me through the reset. All grills made after 1996 have this bypass valve.
Posted on Aug 31, 2009
SOURCE: Back burner won't light on my Weber Genesis Silver A Gas Grill
Only front burner lights (out of three) and it only has flame comming out of half of the tube.
Posted on Apr 30, 2010
  • 221 Answers
SOURCE: My weber genesis silver starts up, but doesn't get
Try these steps in order.
  1. Turn off the gas at the propane tank
  2. Disconnect the gas line from the tank
  3. Open the grill lid
  4. Turn all control valves to high
  5. Wait for about a minute
  6. Turn all control valves to off
  7. Reconnect the gas line to the tank
  8. SLOWLY turn on the gas at the tank
  9. Light the grill normally
  10. Your grill should now heat normally
Posted on Sep 09, 2010
Testimonial: "This didthe trick. Thanks so much!"
Weber genesis silver B won't get hotter than 450
Yes diaphram could be split causing vent to pass gas .
Aug 08, 2012 | Weber Genesis Silver B Grill
I have a weber genesis grill. It did not heat up above 425 degrees at first and now it does not go above 300. This is with the searer on as well. Does this make sense to you? It is hooked up to a...
Was your grill originally set up for Natural Gas or did to convert it from Propane to Natural Gas? If so, where did you get the conversion kit? It may have been missing some vital parts.
If it was not a conversion, did the grill come with a natural gas regulator already installed?
Please advise... Thanks
Jul 18, 2011 | Weber Genesis Silver B Grill
My weber grill won't heat up beyond 200 degrees - why>
Your problem could be or probably is with the regulator...not enough gaspressure...
Propane, LP, or Natural Gas Regulator Problems
heatman101 ,,./,./
May 28, 2011 | Weber Genesis Silver B Grill
Grill won't heat up above 200 DEGREES with a nearly full tank
Try replacing the regulator and hose, not very expensive and fairly easy to do. If that doesn't help, let me know.
Jul 11, 2010 | Weber Genesis Silver B Grill
Grill won't heat up
i would make sure the valve on the tank is open all the way counter clockwise
Apr 24, 2010 | Weber Genesis Silver A Grill
Silver C 2000 Model heats to 420 degrees with all 3 burners on Low. Normal? Weber support service has given me conflicting information. With 2 burners on Low it heats to 310-320 degrees.
That's fairly common with the lid closed and a day that is not too cool. Keep in mind that a gas flame is about 800F. Try using only one burner on low or between on and high to get a lower temperature. This is a grill, not a smoker or slow cooker.
It will run cooler with a large amount of food.
Feb 08, 2010 | Weber Genesis Silver C Grill
Weber BBQ does not get hotter than 300 degrees
Might be easy! diconnect hose from tank ..and re-connect... this has worked for me in the past
Mar 15, 2009 | Weber Genesis Silver B Grill
Uneven heat from burners
I'm experiencing the same problem, the left side has the least heat, and it seems to be getting way worse over time.  Has anyone found a solution for this yet?
Oct 17, 2007 | Weber Genesis Silver B Grill
Weber Genesis Silver C Grill Logo
499 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
