Question about Cycling
I have an Airdyne Evo Comp that set up for a while and now has a bad rubber drive belt. Found the belt at Sportsmith, but can't figure out how to remove the rear pedal(s)and plastic cage to replace it. Thanks for any information.
  • John Haltom Jul 05, 2010
    The user manual only details such things as preventative maintenance and offers Schwinn warranty repair for those who are still within limits. Thank you for looking.
  • John Haltom Jul 07, 2010
    Thank you, I Think I found a way through the bottom of the bike to get at the belt without removing the pedals (which have nothing to do with the belt). Thanks for your assistance. John
  • 942 Answers
I do understand you have a bad rubber belt. To disengage the belt, try to remove the front end of the belt by lifting the upper part of it. If it did not work, try to lift the lower part of the belt and then push both the front & rear pedal counterclockwise so that the belt will loosen up. In that way, you may replace the belt. If you still need to remove the rear pedal and plastic cage, you may do so by unscrewing the rear pedal screw located at the side of it. Once the screw removed, the plastic cage would be removed easily...
Posted on Jul 06, 2010
  • John Haltom Jul 06, 2010
    Thank you for your solution. I have removed the H6 screws that hold the pedals and the shaft, but can not get them to budge. I even tried to remove the compression washer(Not sure if that is what it is called...) from the inside of the pedal. Right now I'm looking at a pedal with no screw, a square shaft inside of it, but no way to free it up to slide it off. Also, getting to thebelt from the front cage is a problem since I can't get the cage out of the way. It's unscrewed, moves freely, I just haven''t got the cage freed from the handlebars. Is there a trick to doing that?
    President:
  • 1,561 Answers
I advice you check the user manual that came with your device, the user manual will guide and give you details on how to go about the replacement on the device.
Take care.
Posted on Jul 05, 2010
What kind of batteries does the schwinn Airdyne take its about 22 yrs old?
Most computer console batteries for Airdynes are AA, you'll have to open up the console/meter housing in the back to replace them. I will be attaching a link to a diagram of the housing. Hope this helps, sincerely SportSmith..
http://www.sportsmith.net/images/product_support/schwinn/service_manuals/Airdyne%20Evolution%20electronic%20trouble%20shooting.pdf
May 21, 2015 | Schwinn Cycling
Tip
Identifying Your Schwinn Airdyne
How To Identify the Model of a Schwinn Airdyne Exercise Bike
  • We'd like to share some characteristics of the Schwinn Airdyne bikes that can be used to help you identify the model of your Airdyne bike.
What size/type fan does it have? Is it a spoke fan like a bicycle wheel or short wide blade fan?
Does your Airdyne bike have two chains or a chain and a belt?
  • AD3, AD4 bikes have two chains.
  • AD Pro/Comp and AD Evolution Pro/Comp bikes have a chain and a belt.
How do the crank arms attach to the Airdyne, by wedge pin or bolt?
  • AD3, AD4 and certain AD Pro/Comp crank arms attach by wedge pin.
  • Certain AD Pro/Comp bikes have crank arms that attach by bolt.
  • AD Evolution Pro/Comp bikes have crank arms that attach by bolt.
How To Identify the Model of Schwinn Airdyne Bike
on Mar 11, 2015 | Schwinn Original Airdyne
Changed battery, need to restore time and distance to alter
To properly reset your mini computer to the specific mode you need please see Pg 8 - Pg 14 of this Airdyne manual from SportSmith I will be attaching a link of. Hope this helps.
http://www.sportsmith.net/images/product_support/schwinn/owners_manuals/AD4_Airdyne%20Evolution%20Comp%20Owners%20Manual.pdf
Apr 29, 2015 | Schwinn Original Airdyne
Replacement batteries for Schwinn Airdyne AD3?
It should just be 2 AA batteries. Remove the battery door on the back of the computer to expose the batteries. Remove and replace. Computer Graphite Airdyne Big Fan Schwinn 92823 SPORTSMITH net
May 16, 2014 | Schwinn 430 Elliptical Trainer
Squeaking belt on airdyne bike
I love my Schwinn Evo Comp AirDyne. After 2 years it suddenly developed a bad squeak and about .5" of increased play in the pedals (ie the pedal could rotate back and forth about .5" before turning the fan). Both these symptoms were caused by a broken spring in the chain tensioner. (Schwinn pn 13000371. See part 80 in blowup 5 of http://www.fitnessrepairparts.com/diagram/114 ~$9).
To replace this:
  1. disconnect the right hand (as you sit on it) connecting arm (ie the piece that connects the pedal to the big handle) from the lever arm (ie the big handle you pull back and forth) by removing the connecting bolt with an Allen head wrench and an adjustable wrench. Note the order of the three internal washers as you remove the connecting bolt. Rotate the connecting arm towards the back of the bike to get it out of the way.
  2. remove the four phillips head bolts that hold down large right hand plastic cover. With the connecting arm out of the way this cover can be pulled far enough out to gain access to the chain tensioner.
  3. remove the broken spring and replace it. I fashioned a similar spring with less tension which seems to work as a kluge. The original spring broke at the outermost loop, so I might have been able to reuse it by just bending down another loop.
  4. could lube the chain while you are in there, but you can also lube it anytime from the other side
  5. put it all back together
Jan 21, 2014 | Schwinn Airdyne Evolution Comp
Pedal / Chain shaft(?) problem
Sounds like you will need new bearings,check manufactures website for parts and instructions.shouldnt be a hard fix.
Nov 29, 2013 | Schwinn Airdyne Evo Comp Upright Bike
Belt slipping off pulley of stairmaster
It may be time to replace your belt, but here is something to try before doing so. There should be a set screw on the pulley. You can loosen the set screw and slide the pulley to allow it to better align with the alternator pulley. Give this a try.
Alternator Drive Belt Timing Type SPORTSMITH net
Poly Alternator Belt for Stairmaster Steppers SM20202 SPORTSMITH net
Sep 30, 2013 | Stairmaster Stepmill 7000 Pt
How to connect schwinn airdyne rpm
you must contact your company supplier for instalation, or read your instr. manual and follow the steps. if you do not have it download from
www.fitness.manualsonline.com
God bless you
Sep 14, 2012 | Schwinn Airdyne Evo Comp Upright Bike
How to tighten chain on schwinn airdyne evo
if you do not have the instruction manual section troubleshooting, download for free in www.fitness.manualsonline.com or www.iconservice.com and proceed the instruction for fix it.
God bless you
Jun 16, 2012 | Schwinn Airdyne Evo Comp Upright Bike
Cycling Logo
49 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
