Question about E-Machines T5082 PC Desktop
Had to replace motherboard. New one only had one
Had to replace motherboard. New one only had one ide input and power plugins from front of computer are different. Can't tell where to plug in everything from front
  • 518 Answers
There should be a paper with the new board showing which plugs go where
Posted on Jul 05, 2010
ABIT-BD711
Okay,.......that was DU-MB!
Lemme see,.......oh yeah!
Letters and words! !O_O!
(Wondered where my glasses were!)
http://images.search.yahoo.com/images/view;_ylt=A2KJkCAV3j9QW2cAUAOJzbkF;_ylu=X3oDMTBlMTQ4cGxyBHNlYwNzcgRzbGsDaW1n?back=http%3A%2F%2Fimages.search.yahoo.com%2Fsearch%2Fimages%3Fp%3Dabit%2Bbd711%26fr%3Dmoz35%26fr2%3Dpiv-web%26tab%3Dorganic%26ri%3D2&w=600&h=444&imgurl=www.ixbt.com%2Fmainboard%2Fimages%2Froundup-i845e%2Fbd7ii-raid-board.jpg&rurl=http%3A%2F%2Fixbtlabs.com%2Farticles2%2Froundupmobo%2Fabit-bd7ii-raid-i845e.html&size=111.5+KB&name=Abit+BD7II-RAID+%28i845E%29+Mainboard&p=abit+bd711&oid=14ba8ece461cfe2b401fe4f974d4c0b7&fr2=piv-web&fr=moz35&tt=Abit%2BBD7II-RAID%2B%2528i845E%2529%2BMainboard&b=0&ni=56&no=2&ts=&tab=organic&sigr=124cn6s7j&sigb=12vbgaaru&sigi=120054ob4&.crumb=J6iwC7bwOtM
Motherboard photo, and detailed info below it. Scroll down.
Looking at the motherboard installed in the computer case:
1) To the right of the Ram Memory slots, and in the upper right corner, is the 20-pin ATX main power cable connector, on the motherboard.
Whitish connector with two columns of 10 socket holes.
A 20-pin ATX main power cable plugs in here,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20
Note the Lock on the side of the power cable's connector, (Middle photo, and right photo), and the Tab on the motherboard connector, (Left photo)
When the power cable is plugged in correctly, the hooked end of the Lock on the power cable's connector, will be hooked over the Tab on the motherboard connector.
2) Look at the bottom Left corner of the Processor socket. Note the three cylindrical objects. (Radial Aluminum Electrolytic Capacitors)
Note the whitish square 4-socket hole connector below them.
This is where the 4-pin ATX +12 Volt power cable goes. It also has a Lock, just like the 20-pin ATX main power cable connector,
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
This is power for your Intel Pentium 4 processor.
3) To the Right of the Ram Memory slots, and located below the whitish 20-pin ATX main power cable connector, are the two IDE connectors. (Turquoise Blue)
One is for an IDE (PATA) harddrive, and one is for an IDE(PATA) optical drive. (CD/DVD drive)
The one on the outside near the edge of the motherboard, has IDE1 next to it.
It is for the Harddrive.
The one closer to the middle of the motherboard is IDE2.
It is for the optical drive. (Or drives { 2 } )
NOTE*
One side of those rectangular connectors has a cutout in the middle.
(Square U-shape cutout)
This is where the Locating Lug, on the flat ribbon IDE cable's connector, goes to.
It aligns Number 1 pin in the connector, with Number 1 wire, in the flat ribbon IDE cable.
IF, there is NO Locating Lug on the flat ribbon IDE cable;
On one side of the flat ribbon IDE cable is a thin RED stripe.
This stripe denotes the side that Number 1 wire is on,
http://en.wikipedia.org/wiki/File:Nappe.svg
Looking at the rectangular IDE1 and IDE2 connectors, Number 1 pin is at the BOTTOM of those connectors.
(Motherboard installed in computer case)
On an IDE harddrive, Number 1 pin is ALWAYS towards the 4-pin power connector.
Same with an optical drive.
4) Since this is a motherboard, that has a RAID option for using multiple harddrives, I'm guessing the two Yellow rectangular connectors, below the two rectangular Turquoise Blue IDE connectors, is for more IDE harddrives.
http://en.wikipedia.org/wiki/RAID
5) Below the two Yellow IDE harddrive connectors is a Black rectangular connector.
This has 34 pins, and is for a Floppy Drive, IF a Floppy drive is used.
6) Below the Black Floppy Drive connector on the motherboard, is the Front Panel header.
The front of your computer is the Front Panel.
The area of contact pins on the motherboard, that the main wires from the Front Panel go to, is the Front Panel header.
What is needed here is a Front Panel header pinout.
Dunno. Photo isn't clear enough.
Looks like a Black rectangular strip of plastic, with 8 pins in a row.
4 pins, 3 spaces, 1 pin, 1 space, 3 pins.
Looking closely, (And you may need a bright light, and a magnifying glass), what are the abbreviations next to the pins, on the outside edge of the motherboard?
HDD = HarDDrive activity LED (Light)
PW = Power On switch
RST = Reset switch
PWLED, or close to that effect = Power On LED.
Post back in a Comment.
IF, it is just a row of single pins going across, I would use an LED light that has two wires on it.
Computer, (Power Supply actually), plugged into power, touch the two wires to the first two pins.
Nothing?
Go on.
When the Power Supply comes on you know you have the Power On switch pins (2)
Now go back through, but do not touch those pins again.
LED light blinks? = HarDDrive activity LED (Light)
LED light stays on? = Power On LED (Light)
Computer restarts? = Restart switch pins
7) To the left of the white long PCI slots, (There are 5 towards the bottom of the motherboard), are two small Black rectangular connectors. Each has 4 pins in it.
The one that has Audio, or CD, or CD-IN, is for the audio cable from the CD/DVD drive.
8) At the Top of the motherboard in-between the Processor socket, and black Ram Memory slots, is an Orangish connector with 3 pins. Should have CPU, or CPU_FAN next to it. This is where the Processor fan plugs in.
9) At the bottom/left, and below the two small black connectors with 4 pins in them, is an Orangish connector with 3 pins.
This should be for the computer case fan.
(SYS_FAN)
Additionally you may want to join this website, and ask them for the Front Panel header pinout, for your Abit BD711 motherboard,
http://www.theraptorpit.com/forum/index.php?/forum/124-abit-motherboard-tech-support-unofficial/
Finding information for an ABIT BD711 motherboard, is about as rare as finding hen's teeth.
I, and I'm sure 100's of people, would be in your debt, if you would post the Front panel header pinout for this motherboard.
Hope I have redeemed myself for the S.N.A.F.U. of the question asked in the Comment, lol!
Regards,
joecoolvette
Aug 30, 2012 | Computers & Internet
Changed ram,cmoc battery now won't boot, power light amber (4000717) mb
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
even something as small as a faulty electrical extension or fan lead can cause you problems
computers need all of the data and electrical current to travel through every working device and to have an end to be able work properly
motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail
check all electrical power input and extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
also check the Cmos battery and computer RAM modules make sure they are securely seated with no dust built up or in the sockets on some motherboards cmos batteries are soldered in
check you CPU make sure its securely seated and has thermal grease
hope this helps
May 28, 2012 | Gateway (4000717) Motherboard
When i turn my computer on the power light on the front flshes about 2 or 3 times then thats it i dont know wut to do about it
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
the leads from your "((MOTHERBOARD TO YOUR HARD DRIVE))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error even something as small as a faulty electrical extension or fan lead can cause this problem:
follow the troubleshooting procedure a computer needs all of the data and electrical current to travel through every working device and to have an end to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail check all electrical power input and extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
also check the Cmos battery and computer ram make sure they are securely seated with no dust built up or in the sockets
hope this helps you
Jul 28, 2011 | EliteGroup 661GX-M Motherboard
When computer is powered up the monitor reads "no signal". You can't manually push any of the buttons on the monitor except for the power button. How do I fix this?
Test all leads that attach to your hard drive including power input and electrical extensions IDE,SATA"
the leads from your "((motherboard to your hard drive))" make sure they have a secure connection and are not faulty or just replace them they might be faulty if its a 40 pin IDE replace it this will be the first to fail a computer needa all current and data to travel to and through evevry working device and and have an end to work ptoperly
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error If your computer came with a motherboard disc the drivers could be on it or you might have a dirty graphics card remove the graphics card and clean the socket
hope this helps
Jul 15, 2011 | Computers & Internet
Some one give me this DVD burner Sony DRU-540A ..would it use IDE or Sata...It did not come with any cable...what cable i need to get?
If you look on the back of the burner, you will notice either a slot with 39 pins or a small black like plugin. The 39 pins would be for an IDE plug, and the little black pin would be for a sata cable. Simply go to the nearest Radio Shack, Best Buy, or computer hardware store and get the appropriate internal cable. Just advise the store attendant in that area to advise you were such cable is.
These are very simply to plug in, simply plug in to the back of the cd-rom, and plug into the motherboard with a similar plugin on the motherboard. Make sure the plugin on the motherboard states it is Sata, on the motherboard it will have something printed near it with Sata1 Sata2 or something similar. Put the CD-ROM in the closest bay, and plug in appropriately.
Dec 04, 2010 | Sony DRU-540A DVD±RW Burner
Hello I have a T2682 and I have taken this computer apart many times and I just got back from Afghanistan and just wanted to see if I could get it going one last time but I forgot what wires plug in where...
The beep you hear is a BIOS Beep Code. The computer's method of informing you something is wrong, and the area to look into for it.
The code is similar to what you may be used to.
(Afghanistan, Army? If so, hello brother/sister. 1st Cav, 13th Sig. Corp)
The BIOS Beep Code is similar to a Morse Code.
Examples:
Two short beeps followed by a long beep, a pause of silence, then the pattern repeats, over, and over.
One short beep indicates everything is okay.
This is an indication that BIOS has concluded the Ram Memory count, and everything is 5 By.
According to my sources, the eMachines T2682 desktop computer uses an Imperial GV motherboard model, made by TriGem.
The front plastic cover of your computer is the Front Panel.
The area on the motherboard that the cables, (Wires), attach to on the motherboard, is the Front Panel header.
This is the Front panel header pinout, for the TriGem Imperial GV motherboard,
http://www.e4allupgraders.info/dir1/ecase/support/front_panel_support.shtml
On this page I would like you to scroll down to the heading -
Imperial GV Front Panel Motherboard Pinouts
Looking at the pinout;
1) Pin 1 is Not used. NC = No Connection
2) Pins 2 and 3 are for the Power On LED light
[Light Emitting Diode]
Pin 2 is for the Ground wire. (GND) ( - )
Pin 3 is for the LED light power wire. ( + )
3) Pin 4 is not used. NC
4) Pins 5 and 6 are for the Harddrive Activity light. (LED)
HDD is HarDDrive
Pin 5 is for the LED power wire
Pin 6 is for the HarDDrive signal wire
(If after attaching the wires the HDD LED light is dim, reverse the wires)
5) Pins 7 and 8 are for the Power On switch.
Pin 7 is for the Ground wire.
Attaching the Peripheral cables;
1) You have an IDE harddrive. Uses a 40-pin IDE ribbon cable.
(39 actually. One pinhole is blocked off)
There is a Locating Tab on one side of the IDE ribbon cable's connector.
To wit:
http://en.wikipedia.org/wiki/Integrated_Drive_Electronics
Left-click on the blue IDE connector in the photo to the upper right.
At the top middle of the connector you will see two ridges.
This is the Locating Lug.
Now left-click on the IDE connector on the motherboard, shown in the photo to the upper right.
(To the right of the blue IDE connector)
Looking at the blue IDE connector on the motherboard, you will note there is a cutout on one side of the connector.
This is a Locating Slot.
Lining the Locating Lug up to the Locating Slot, puts the pins of the IDE ribbon cable's connector, in the correct position for the pinholes in the motherboard's IDE connector.
IF, your ribbon cable's connector does Not have a Locating Lug;
Look at the outside edge of the ribbon cable. You should see a faint Red stripe.
The Red stripe is always next to Pin 1.
Next to the motherboard's IDE connector should be a printout.
It will state PRI 1, (Stands for Primary 1), or IDE 1.
This is for the Harddrive.
[ If you see PRI 2, or SEC, (Secondary), this is for the optical drive.
(CD/DVD drive). Using this information, you will know the other IDE connector on the motherboard is for the Harddrive ]
That printout is always next to where Pin 1 is.
Therefore on the motherboard, the side of the IDE ribbon cable that has a Red stripe, will go next to the printout.
If your harddrive does not have a Locating Slot on it's IDE connector, Pin 1 is always towards the 4-pin IDE power pins.
To wit:
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
The above is a webpage from Playtool.com, discussing the various power cables used in a PC, and more specifically the standard 4-pin Peripheral power cable.
I linked it to show you a standard 4-pin Peripheral power cable, plugged into an IDE harddrive.
(A Peripheral power cable's connector, has been misnomered as a Molex connector, repeatedly through the years.
This was the name given to the first connector of this design.
It's kind of like referring to an adjustable open-end wrench, as a Crescent wrench )
Here in the photo of the rear view of an IDE harddrive, (Photo to the far left), you will see the 4 power pins.
To the left of the power pins are the Jumper pins.
To the left of the jumper pins, is the IDE interface for the 40-pin IDE ribbon cable.
The Red stripe of the IDE ribbon cable goes towards those 4 power pins.
To be continued in an additional comment.
Sep 19, 2010 | E-Machines eMachines Desktop PC
Aftr 10 mint my pc restart
Check processor cooling fan first.
Jul 28, 2010 | ASUS M2N68-AM SE2 Motherboard
Computer keeps shutting down change operating
replace all leads including IDE and SATA and electrical before replacing a new PSU
Jul 25, 2010 | Foxconn 661FX7MI-RS (661FX7MIS)...
Boot up error
You may have to open your computer and locate the hard drive. Trace the cable to see where it plugs into the motherboard. If there are other slots that it will plug into the motherboard, try plugging the hard drive into those.
If you have SATA plugins, it will be relatively easy to find a new port to plug it into. If you have IDE plugins, you may want to skip my solution and try other things first.
Apr 16, 2009 | Computers & Internet
New Samsung SH-S203 DVD writer with SATA has a plug-in in the back that doesn't seem to match the plug on my SATA cable which goes from my ABIT AW9D-MAX motherboard to my Pioneer burner which also has a...
The power connector is really similar to SATA connector. It's not like IDE/EIDE. It should be a flat connector.
Take acloser look, most of the times both connectors are very close.
Jun 28, 2008 | Computers & Internet
E-Machines T5082 PC Desktop Logo
99 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
