Question about Kobe CH7930SQ Kitchen Hood
Replace light bulbs in a kobe hood top - Kobe CH7930SQ Kitchen Hood
  • 8,197 Answers
On link below on page 20 will tell you how to replace the bulb.
SQB
-EN-FR-SP-091208.pdf">http://www.koberangehoods.com/pdf/manaul-CH-179-SQB-EN-FR-SP-091208.pdf
Good Luck and please rate 4 thumbs up for the free answer.
Posted on Jul 05, 2010
Recent rain storm, water came out from failed baffle, the power did not trip the circuit, but the unit no longer power's up?
Depending how the unit is installed..you may have a ground fault type outlet up in the cabinet someplace. Maybe on top of the cabinets. This will cut power to the unit without tripping the breaker. Just find the outlet & reset the GFI outlet. Fix the leak.
Mar 01, 2016 | Kobe Brillia CHX191 Series 30-inch Under...
The electrical system shorted out when a light bulb broke while changing it. The circuit breaker did not trip. None of the electrical system works. Is there a fuse to replace? Do I need to replace the...
you need to replace the light fitting holder as this is the reason the system failed.As to why the circuit breaker failed that is a mater for an electricion,because i would suspect a majour fault on the home electrical system.adrian.
Mar 15, 2011 | Kobe IN2636SQB Stainless Steel 32" Kitchen...
Need to replace headlight?
  • Open the hood of your Crossfire to gain access to the headlight assemblies. Press down on the tab on top of the light assembly cover. Remove the cover and set it aside.
  • 2 Pull the electrical connection free of the bulb socket. Press the spring clamps securing the bulb into the light assembly. Pull the bulb straight out of position.
  • 3 Insert the new bulb in the same position. Ensure that the spring clamps secure the bulb. Press the electrical connection into place.
  • 4 Replace the light assembly cover and press it into position until it clicks, securing it in place. Repeat the same process on the opposite headlight if required. Close the hood and test the headlight I would replace them both sides if i were you
  • Dec 02, 2010 | 2004 Chrysler Crossfire
    I need to find out the light bulbs relacements for a zephyr rangehood, model venezia
    Check out the zephyr Site. The halogen bulbs they use are very unique. Have two clients that have Zephyr hoods and took me a while to locate replacement bulbs. Could not find them at the local lighting stores nor hardware stores. I believe it is a 35 watt halogen (sort of an MR-16 size) with an entended base.
    Oct 19, 2010 | Kobe Rangehoods CH-100 Series - 36" Wide x...
    How do I replace bulb in headlamp?
    HI if you open the hood and look at the top of the core support you will see two philip head screws about each headlight assembly. if you remove these ( they are quite long ) you will be able to lift up and away from the grill area with the light assembly.
    Aug 27, 2010 | 2000 Dodge Stratus
    My existing duct is a 4x10, the KOBE CH2230SQ does provide the 4x10 ducting option, but 1. it does not have any spout to catch the duct opening; 2. the vent plate has a thickness, but my cabinet is...
    You should be able to purchase the 4x10 hood boot from Lowe's or Home Depot. As for the cabinet mount, maybe you can cut a bigger hole. I have modified fittings to fit small spaces but most heat and air installers can make you fittings for small confined spaces. I have found them to be quite reasonable too! Hope this helps.
    Aug 12, 2010 | Kobe CH2230SQ Kitchen Hood
    The range-top light blew and now replacement bulbs
    My Whirlpool/Roper microwave/hood combo has the same problem. I replaced the bulb twice, checked the bulb and it works, but not in the microwave. I wrote to Whirlpool asking about the problem. Haven't heard from them yet.
    Apr 02, 2010 | Whirlpool MH1150XMQ Microwave Oven
    A local small contractor installed our Kobe RA3830SQ Range Hood a few days ago. We have not been too impressed with the efficiency of the fan. Today I noticed that it seems to blow out instead of sucking...
    Hoods should blow out from the chimney, its defianately not a wiring problem. If it is blowing down towards your cooker instead of sucking up then you should contact Range as it could be a manufacturing fault.
    Dec 06, 2009 | Kobe RA3836SQ Under Cabinet Range Hood
    Control Panel Breaks Down
    is your control panel is under the hood? if so, every time you use your stove turn the hood on, the reason is, the heat from the stove burner is melting it, but if you have your hood on, it will pull away some of the heat. you can try to put your hand at the control panel with the front burners on, then you will feel the heat from the stove.
    Oct 16, 2007 | Kobe CH7936SQ Kitchen Hood
    Kobe CH7930SQ Kitchen Hood Logo
    1,231 people viewed this question
    Top Kobe Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    paulcarew
    Are you a Kobe Kitchen Range Expert? Answer questions, earn points and help others
