Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Can't find hot folders in port tab of printer property page
Hi,there,
I was trying to setup a printer's port to a hot folder so the file and be dropped into it and be picked up by other apps. This is XP sp3. But I can't find it only STANDARD TCP/IP AND LOCAL are available. Other computers have this port type. Should I install this type of port from WinXP disk?
Thanks a lot.
Alex
  • 748 Answers
There's no such thing in plain Windows XP as a 'hotfolder port'. There's a special "FILE:" port which redirects the output to a file (and asks for the filename every time).
If your other machines have such port, it means it has been created together with an installation of some specific printer (or virtual printer) driver. You must establish what the driver is and install it on your machine as well.
Posted on Jul 05, 2010
Keep getting error 2075 when i try to use the kodak aio Home Center
To resolve this error code:
  1. Close Home Center Software.
  2. Go to Start>Computer.
  3. Show hidden files and folders:
    • Select Tools>Folder Options.
      NOTE: If the Tools menu is not available on the menu bar, press the <Alt> key on the keyboard, and then a menu bar with the Tools menu will appear.
    • Select the View tab.
    • In the Advanced Settings, select Show hidden files or folders.
    • Select Apply.
    • Click OK.
  4. • right click on the Kodak icon on your desktop and select properties. •Then on the general tab select find target.
  5. Right-click AiOHomeCenter.exe.config and select delete to remove the file.
  6. Hide hidden files and folders:
    • In the Advanced Settings, select Do not show hidden files or folders.
    • Select Apply.
    • Click OK.
  7. Run Home Center Software to run as an administrator:
    • Right-click the Home Center icon, then select properties.
    • Select the Run this program as an administrator check box in the compatibility mode.
    • Click OK.
  8. Open Home Center Software and print or scan a job.
May 10, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Tip
How to get your Dell 964 AIO printer to work correctly in Windows 7
Read through all the steps and get a good understanding of process before starting.
Step 1:
Perform manual Un-installation of OLD printer drivers Click Start > Devices And Printers, right-click on the Dell AIO 964 printer icon, and click on Remove This Device.
Step 2: Unplug the USB cable from the computer.
Step 3: Download the ZIP file R166225.ZIP from the Dell website here:
http://support.us.dell.com/support/downloads/download.aspx?c=us&l=en&s=gen&releaseid=R166225&formatcnt=2&libid=0&typeid=-1&dateid=-1&formatid=-1&fileid=224455
Step 4:
Extract all the files from R166225.ZIP intoa separate folder by themselves. Remember the location of the folder for later use. It would be best to create a new folder and extract the files to that folder to make it easier.
Step 5: Navigate to the directory you extracted the files to, locate SETUP.EXE, and run it. This will run the Dell Clean-Up Utility, which removes old printer drivers/files from your system.You may need to navigate to a sub-folder named "CleanUp_Utility" under the folder that you just created in order to run SETUP.EXE.
Step 6: Reboot the computer when prompted.
Step 7: Download the self-extracting file R146813.EXE here:
http://support.us.dell.com/support/downloads/download.aspx?c=us&l=en&s=gen&releaseid=R146813&formatcnt=1&libid=0&fileid=195111
Step 8:
Navigate to the file R146813.EXE, right-click the file name, click Properties, click the Compatibility Tab, and check off the following check boxes: Runthis program in compatibility mode for: (then select Windows VistaService Pack 2), and Run this program as an administrator.
Step 9:
Right-click SETUP.EXE, click Run as Administrator, and run SETUP.EXE.You might be able to get away with just running the executable withoutthis step, but I included it for redundancy and for safety's sake.
Step 10: Re-connect the USB cable to your computer when prompted by the Setup Utility. A small warning: when I did this step, Windows detected my printer and installed its own native drivers forthe printer, and a dialog box popped up attempting to print analignment page. I ignored this dialog box entirely. If this happens,you will be prompted by the Setup Utility to update the driver, which is what you want to do. Continue to run the Setup Utility as normal.
Step 11: Reboot the computer again.
Step 12:
After starting up Windows 7 and logging in, Click Start > Devices and Printers, double-click the printer icon. Click Customize your Printer, then the Ports Tab. Check off "Enable bidirectional support."
Step 13:
Verify that the printer is communicating with the operating system by printing a test page. You can go back to Customize your Printer and click Print Test Page.
Step 14:
If it still doesn't work try and reboot and try printing test page again.
Thank you and enjoy the tip.
-LeeTheDeuce
on Jan 30, 2010 | Office Equipment & Supplies
I HAVE ONE IRC 3200 AND I DONT KNOW WHAT DRIVER INSTALL FOR SCAN AND PRINT, I HAVE WIN XP
Go to http://www.usa.canon.com
Select Downloads
Select Office/Production
On next page from the dropdown select Office/Production products again
Next page Select Networked Office Systems/Copiers
Next Page select Color ImageRunner Series
Next Page Select Color ImageRunner Series
From List select Color Image Runner Irc-3200
From the choices select the driver needed. PCL or PS (postscript)
Select either Setup or INF.
If Setup or INF file. Download the zipped file. Create a folder on desktop or downloads. Call it Canon Copier or whatever. Download the zipped file to this folder. Go to the folder you downloaded the zipped file to and double click on the file. When Win-Zip started and asks where you want the file un-zipped to enter a period (.) this will unzip the file to the folder you created.
Once the file is un-zipped if you downloaded the setup file run setup exe.
At somepoint in the setup process you will be asked which port you want to use. You will need the IP Address of the copier ( which can be obtained by pressing the additional Functions key on the copier, selecting report settings, selecting Network and print report. If the IP address needs to changed select additional functions again, Select System settings Key, Network settings key, TCP/IP settings, Check or Set IP Address here or select DHCP to get new address. Repower the copier if any changes are made.
At the which port to use select New Port, select Standard TCP/IP port and create new port. Enter IP address in the new port window.
If using INF file after INF is unzipped. Go to Printers folder and select create New Printer. Follow Printer Wizard. Create New Standard TCP/IP port. When the Wizard Asks for Driver, select have Disk and browse to the folder you created and click the unzipped file and continue clicking until the file installs.
Mar 20, 2010 | Canon imageRUNNER C3200 Copier
Canon laser shot lbp 1120 drivers wont work on windows 7
I just recently fixed the problem for my LBP-1120, so I thought I'd share to make life a little eaier (in case you are still experiencing the same problem).
Step 1: Uninstall any previous attempts to give you a clean slate to work with.
Step 2: Go to http://driverscollection.com/?H=LBP-1120&By=Canon
You want to download the CAPT Driver R1.10 V1.10
(It's 1.61Mb)
Direct Link: http://driverscollection.com/?file_cid=4185122914590a75abbdee86fed
Add the little cypher code, and click download.
Step 3: Run the file, it will extract to the same folder.
Step 4: Simply Start> Devices & Printers > Add Printer
Add Local Printer (I'm assuming USB001)
Have disk > Browse (Go to folder)
Alternatively, if your current Printer list shows "Canon Capt Printer" already, right click, go to Properties and try Updating the driver by using the folder/files you downloaded.
That should work now. Happy Printing! :-)
Mar 01, 2010 | Canon Office Equipment & Supplies
My Officejet 6310xi All in One will not print anything
Hi
First Check the Hardware connections
1) Check the power connection
2) check the USB Connection
Second Check the Software connectivity and Drivers
1) Checked by click Start
2) click Control Panel
3)
then double-click Printers and Faxes
4) The Printers and Faxes folder opens
5) Look for a black check mark next to the product icon
6) Right-click the icon for your product and then click Properties . The printer Properties window opens.
7) Click the Ports tab.
8) Look for view the Ports column to the left.
9) There should be a check mark next to the DOT4 port or the USB00?
10)
under the Printer column - make sure the product listed matches your product.
11) Restart the computer, and then try the print job again.
Try printing the TEST Page - Ctrl+P - go to printer preferences and print a test page
Jan 12, 2010 | HP Office Equipment & Supplies
I get an error message saying the printer is offline. It is connected through a router wich is broadcasting fine.
Hi
To resolve the issue which says "Printer Offline" we need to Add a Port.
So I request you to perform below steps.
1. Print a network configuration page from the printer front panel.
A. Press the Setup button.
B. Press the arrow buttons to select Network and then press OK .
C. Press the arrow buttons to select Print Network Configuration Page and then press OK. The Network Configuration Page prints.
2. Note the IP address on the printer.
3. Please open the printers folder located in the control panel
4. Right click on the icon and select properties
5. Select ports tab and click on create new Port button.
6. Select the Ports tab, and then click Add Port. Select the standard TCP/IP Port and create a new port. Type the IP address of the Printer and proceed with the onscreen instructions.
Now try printing.
I am sure this will resolve the issue.
Thanks,
Roger
Oct 10, 2009 | HP Photosmart C6280 Printer
My printer went offline; once I placed it back online it will not print
Hi
As you have not provided me any information about the setup and also no information about the unit. However I will still like to perofrm few troubleshooting steps.
If your printer is a HP and is connected in network then I request you to perform below steps.
Now try printing.
Yours,
Roger
Oct 03, 2009 | Office Equipment & Supplies
I am trying to uninstall my Lexmark X4270, but an error message keeps telling me it is in use and cant be uninstalled until the print job is done,, but I know it is not in use,. How do I uninstall it?
you will need to go into your printers folder find the ip address of the device ensure it doesnt have any jobs in que, uncheck the ip address and change to LPT1 then go into file at the top of your printer folder server properties Ports, find the ip address of the printer and delete it then hit the drives tab at the top of the server properties page and delete the driver for the printer also, this should resolve your issues.
if this answers your query please rate me accordingly.
thanks
Jul 16, 2009 | Office Equipment & Supplies
Printing Backwards like a mirror image
You need to change the printer properties.
You can do this a few ways:
  • Click File , Print , then click the Properties button.
  • Click File , Print Setup , then click the Properties button.
  • Click File , Print , Setup , then click the Properties button.
  • Click Print , Properties , then click Printer Assistant .
  • Click the Taskbar Printer icon.
  • Right-click the applicable 3740 icon in the Printers folder, then click the Printer Preferences button.
Click on the "Basics" tab.
The 3rd option under "orientation" will say "mirror image".
Make sure this is un-checked.
Mar 24, 2008 | HP DeskJet 3740 InkJet Printer
I need a new port
remove old router software, and it should open that port..then start from the beginning on installation of new router, then connect your printer.
check your computers warranty here 4 FREE
Mar 16, 2008 | HP Photosmart C6180 All-In-One InkJet...
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
60 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
