Question about Home
Mira Elite st shower cutting out
I have had a Mira Elite st pump shower for 1year and the power cuts out intermitently.
Power cuts out when having a shower also when not in use. Electrician has checked the wiring fuse box and isolator switch and says everything is secure. Domestic shower engineer has checked shower and said 100% certain no fault with the shower. Does anyone have any idea what could be causing the problem ?
  • 171 Answers
SOURCE: mira cold feed only power shower
Hi davecross,
I'm Harvey, the Master Plumber.
Your question is:
water pressure not great would a external pump help. Depends on your situation. If you live in a house with a well pump then turn up the pressure. If you have city water and the pressure is lacking then either install a house pump after the meter or if it is just the shower you're worried about then a booster pump on the shower line is the ticket. Be aware that useing the booster may reduce the pressure at the other faucets in the house while it's being used. The house pump will not exhibit this. You will likely need a local pro to help you with installation. Feel free contact me again!
Please give me a rating here at before you sign off
Thank you, Harvey, your Master Plumber
Posted on Sep 10, 2008
  • 34 Answers
SOURCE: shower goes cold after 5 mins
Sounds like you have got some elements out in the unit or you need to turn the heat up.
Posted on Feb 05, 2009
  • 34 Answers
SOURCE: does not stay hot long goes cold after 5 mins in my mira shower
This sounds like the elements or you just may need to turn the heat up. If it under two years old call the manu on the warranty. They make a good product so they should help you. I would check the heat setting first, though I doubt it is going to be the prob.
  • 659 Answers
SOURCE: Cannot locate the thermal cut out in the shower unit
Most of the time, these are an auto reset type. But I would recommend calling the manufacture. They usually have an 800 number for you to call. Or you might be able to find the info on their website and or possibly download the installation and user manual for it.
Posted on Mar 30, 2009
SOURCE: My Triton Millenium shower just
there is a cut out unit on top of the element *** unit which is to prevent damage to elements if the water supply fails but i have 3 of these fail down to use have checked the triton spares and the only show it with the element unit cost over £100 you can bi pass it with out any problems just make sure always turned off at pull cord when not in use or phone to see if you can just buy the cut out if you cant its shame on them good luck spares number 08449800745
Posted on Jan 24, 2011
My mira elite 2 shower is leaking,The flow and tempt is ok. but the leak has got worse and it is cold water the leak is not from the hose that is connected to the shower head. It only leak when its on
Please use plumbers white tape wrapped in a clockwise diection. Tighten and let us know Geraldine. Thank you and send us a picture if you can. Best of luck leave feedback
Jul 13, 2016 | Home
Hot water not coming through on a mira thermostatik 722 shower
Shower Doctor TV: How to Service Mira 722 & Mira 723 ...
? 15:26
Jul 5, 2013 - Uploaded by The Shower Doctor
George services a cartridge inside a Mira 723 shower. ... Until I watched this, I was stuck with a half dismantled valve, no waterin the house and a .... Fresca Verona Stainless SteelThermostatic Shower Massage Panel ...
Shower Doctor TV: How to replace a Mira Excel cartridge ...
? 5:29
Jul 1, 2013 - Uploaded by The Shower Doctor
George replaces cartridge inside a Mira Excel shower. ... Hi, I have this model of shower and turning the temperature selector to the hot side turns the ... I just got the place so cannot rule out incorrect shower installation but Im not sure if its ... to those with a booster pump in the loft how to turn off the water.
Fault Diagnosis: Support - Mira
Jan 01, 2016 | Home
My mira elite 2 shower wont heat the water. i have checked the heating elements and they are good
Check the thermal cutouts as well, and that the water pressure is high enough to operate the pressure switch, which should then operate microswitches to swith the elements on.
Aug 03, 2014 | Home
My Mira sports shower comes on but cuts out after a few seconds
Take shower head off. soak it in a container of vinegar overnight the flush, with water, then reinstall.
Jul 27, 2014 | Home
Mira sport shower
Sounds as if the internal pump has gone ,replace shower unit. Mira still make the sport and is available from a good plumbers merchant
Dec 22, 2017 | Home
Pride elite traveler keeps cutting out 9 beeps
it could be the connection between the rear section and the front half. take back section off and see if connection has melted as I have repaired lots with this fault.
Dec 13, 2013 | Pride Mobility Products GoGo Elite...
I have a Mira Vie electric shower, the pull cord no longer lights up, and therefore my shower won't run. I've checked the fuse box and nothing is labelled, it's an old style fuse box. Ther
Buy a current tester( under a tender) and test if supply is going to pull cord (remove the 2screws on cover of pull cord. )Ifyou have power then it's you pull cord that needs replaced if not its mains fuse
Sep 26, 2012 | Home
My mira sport shower is only 2 years old just over and is leaking from the shower head I have taken the head off, is it the washer or do I need a new shower head? Sorry I am unable to give you the brand....
firstly clean all the shower holes with a needle tip. you can also apply some descaler on the shower. Cut an old cycle tube piece round to the size of shower head. Make a hole in the centre of the cutted piece.Apply some grease on the patch & place it between the shower & head. Tight it up.If there is not enough space for rubber just apply grease on the head & tight it.
Aug 13, 2010 | Home
No water coming out of shower
First you should check the screens st the ends of the hose to be sure they are not clogged. The shower head as well. Otherwise it could be the water control valve, solenoid or thermal cut off.
Mar 02, 2009 | Home
Triton Millenium Power Shower
generally if the flow sensor notices no water through the pump it will auto matically shut the pump down. so it could be the flow sensor is bad or the pump is not working like it should. now it depends on how old the pump is. i would start with the flow sensor.
Aug 30, 2008 | Home
Home Logo
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
