Question about E-Machines eMachines Monitor E15T4
Blue tinted monitor screen
I have an eMachines computer and the screen went from normal to showing a blue tint today, out of the blue.
Any suggestions on what could be causing this or how to fix it??
  • 1 more comment
  • Anonymous Apr 20, 2008
    Same problem. It actually goes on and off, but it only appears to work when I don't need it to. Often I will walk into the room and it will just turn blue. I have unplugged the cord and blown on it many times, hit the monitor as hard as I can many, many times, and tried leaving it off for several hours. Nothing works, of course.
  • klejwa Jun 18, 2008
    I have the same problem BUT, I hooked up another working monitor to my Emachine computer and it also shows blue. So do you think its the videocard or motherboard. (videocard is integrated)
  • VALLEN291 Jul 25, 2008
    To all concerned, I purchased my E15T4 monitor 07/ 2006. It just started to display with a blue tinge. So far,common responses have not corrected this problem. [ turning off computer , adjusting display w/ monitors menue, checked out cords, power supply, ect. Please advise if possible. Thanks, A.E. Majer
    Problem Solver:
  • 17 Answers
Black and white tracking can vary in color depending on which color that the dispay is not getting enough of or to much of. In the case of it changing when you walk
in to the room, sugust that there is probably a loose connection or poor solder joint on the curicut board of the moniter. I don't suggust that you get inside the moniter and try to fix this due to dagerous voltage potential with in the moniter. Good luck
Posted on May 14, 2008
Tell us which EMachine monitor you are referring to. Some have their own quirks and your problem may be narrowed down better.
Posted on Jun 10, 2008
LG Flatron W2234S 22 purple tint problem
your LCD monitor has bad ccfl lamps or inverter circut..
May 08, 2010 | LG 22" FLATRON LCD Monitor
I unplugged my Acer al1914 monitor from my computer and plugged a different acer al1914 in my computer and now when I transfer the screen from notebook to monitor it has a blue tint on the entire screen. I...
Check the color settings in the on-screen menu. You can choose between "Warm", "Cool" and "User". Maybe you used the "Warm" setting before and somehow it got changed to "Cool".
If this is not the case, you can try the "User" mode and reduce the intensity of the blue channel.
If even black areas show a blue tint, maybe running an auto configuration from the menu helps.
As a last resort, use the "Reset" menu item which resets all settings to factory defaults.
Mar 30, 2010 | Acer AL1914 19" LCD Monitor
Normal screen is white background, but lately I am getting a blue tint that clears up sometimes and sometimes not. Please advise
Try hooking up another knowng working monitor to the computer and see if the blue tint comes back intermittently.
If it still comes up then you know your video card is the culprit. If the blue tint goes away then you know the original monitor is bad.
Aug 04, 2009 | Samsung Syncmaster 730B 17" Flat Panel LCD...
Laptop LCD goes black after a few seconds
Yes, The pink tint is an indication that the backlight is failing. Now the backlight is basically dead, the best way to get back going is to do an Ebay search for your model laptop and get a new screen. Most screens can be purchased for around $50.00 - $70.00 and they are very easy to swap. Email me if you need more info.
Corporate Computer
Aug 03, 2009 | Samsung SyncMaster 940N Flat panel Monitor
My screen suddenly has a blue tint and I can't adjust ! Please advise
it went bad, when you get the blue tint pixels are not right
Jun 24, 2009 | Computers & Internet
Blue color tint on monitor. color is not right.
one thing to look for is the cable from your monitor to your video port remove the cable from the back of the computer and check to make sure there are no bent pins. If possible revovefrom monitor and check thos pins as well
Dec 27, 2008 | E-Machines eMachines Monitor E15T4
Reddish tint on the screen
LG 700e
power suply is dad
resistanc is black not show it ohom
plz help
Dec 21, 2008 | LG Studioworks 700S 17" CRT Monitor
Monitor screen changes from regular color to a green tinted screen?
Is the cable connected securely? You may need to check your video card also. You may be able to disconnect the cable and get a red, green, blue icon on the screen. If that appears normal then there is nothing wrong with the monitor itself, it may be the cord or the video card.
Hope this helps!
May 31, 2008 | Dell 1503FP 15" LCD Monitor
Blue tint on monitor
If you mean you can still see your screen and everything on it, but everything is very blue, then check your video cable from the PC to the monitor.
It will have a broken wire inside and is a common problem. Just wiggle it around in a circle and it should come good. Hold it in that position with something until you can replace the cable.
Apr 18, 2008 | E-Machines eMachines Monitor E15T4
Monitor is blue-evrything has a blue tint-i can see colors,they just have a ble tint
I've found that strange color tints are usually the result of a loose cable connection, either at the computer end of the monitor end.
Try unplugging both ends, and then replugging both nice and securely (might even try reversing the direction of the cable, if it is a simple VGA-VGA cable).
Feb 27, 2008 | Computers & Internet
E-Machines eMachines Monitor E15T4 Logo
265 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
