Question about Garden
How do I put in a new pull string - Garden
    Brigadier General:
  • 3,917 Answers
Hi
Please check the bellow link…
http://www.kichline.com/chuck/fixit/mowers/rope.html
Unscrew the coil housing for the rope using a socket set or screwdriver. Do not tip the mower over on its side when working on it because this can often cause oil and gas to leak out. Check out the coil wheel. Depending on where the rope broke, you might have some rope left on the coil wheel. You can feed the old rope back through its hole and retie the pull handle if you have enough rope to pull start the mower. Next, replace the housing and then screw it back in place. If you do not have enough rope, you will need to replace it with a new one. You can take a wrench and loosen the bolt that holds this in place. When you pull the wheel off, in most cases it will include the winding spring that coils the rope automatically.
Loosen the bolt that holds the coil pulley in place. When you take off the coil pulley, the coil spring will come off with it in most cases. Cut off the old rope using a knife. To remember which way the rope was coiled, make an arrow with a marker.Pull the new rope through the hole and tie a knot about the same size as the old rope because you do not want the new knot to catch on something when the coil pulley coils and uncoil. Wrap the new rope in the direction of the arrow you drew. Next, bolt the coil pulley back in place. To make sure it is working properly, unplug the spark plug- this allows you to pull on the rope to make sure it coils and uncoils correctly.
Pull the end of the rope through the hole in the housing. Tie the old pull handle to the end of the new rope. If the rope is too long, you might need to cut off the extra length and discard it. Place the house into its spot and screw or bolt it back on. Finally, put the spark plug wire back into place.
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Posted on Jul 09, 2010
I got a 1989 big bear it pulls to the right i put new tie rid ends and upper and lower balk joints in pulled cv axel it seems to be ok steering bearings seem fine also anyine have any ideas
Try aiming the handle bar straight and pull some kite string across the rear wheel , lightly touching the sidewalls of the tire. With the length of the string pulled across the front tire, adjust the outer tie rod so as to make front tire lightly touch the string. That should square the front tire to the back tire. Once the front and rear are squared, adjust tie rod in 1 turn for a slight negative toe. Do both sides while making sure to keep the handle bar straight during string and adjustment. That should help.
May 25, 2017 | Cars & Trucks
Tip
How to string an electric guitar
I'm writing this tutorial to help new guitarists string their electric guitars.<br /><br />The first step is to purchase some strings from your nearest music store, depending on the type of music you want to play the string gage will be different. If you want to play heavier music such as metal then I suggest using a heavier gage of string. If you want to play calmer music such as indie, or maybe soft rock I suggest a lighter gage.<br /><br />Next make sure and remove <span style="font-weight: bold;">ALL</span> existing strings. The best way to take off the old strings is to simply loosen them up then cut them right in the middle with wire cutters. Then just pull the left end through the tuning knobs, and the right end through the back of the guitar (Note where the strings come out of the back).<br /><br />After you have removed all the strings its time to put on the new ones. Start with the string closest to the top of the guitar. On your string package you can reference by color which string is which. Find your string then run the sharp end through the back of the guitar in the hole relative to the string you are putting in (These holes in the back are the same holes the old strings came out of). Run the string all the way through so that it is pulled tightly into the back. Now place the sharp end of the string through its relative tuning knob at the top of the guitar. You should pull enough through so that when you pull the string up off the neck there is a gap of about one foot. Now turn the tuning knob clockwise until the string is relatively tight against the neck and it has wrapped around the knob 3-5 times. Now cut the excess string that is coming out of the tuning knob but leave about 1 inch in case you want to lower the tuning. <br /><br />Do the same thing for all your strings, then tune them with either a digital tuner or by ear if you can. You can purchase a cheap digital tuner for around $20 at your nearest music store.<br /><br />Enjoy!!
on May 16, 2011 | Yamaha Electric Guitar
I Have a Weed Eater Model W25CFK I need to put new string on it ...It doesn&#39;t have a spool you use two individual pieces of line and I can&#39;t remember how to do it and can&#39;t fi
There are a couple of different heads that doesn't have a spool on 1 you pull the left over pieces of old string out from under the and the push the new short pieces into the front of the head, another you line up two arrows and then put a long piece of string throw the head eqail on both sides and then wind the head to pull the string in, another you take off and feed the line down inside.
Oct 13, 2014 | Garden
Troy bilt trimmer
Did you put the right amount of string back in the trimmer? If you put back too much it will tangle up.
Sep 07, 2014 | Garden
Putting new pull string on Craftsman trimmer
it does screw on take a channel lock to grab the clutch and turn left to remove it
Aug 01, 2010 | Craftsman 25cc Gas Line Trimmer
Replace pull string (how to put string on after taking cover off)
Basically, pull the string through the winding hole and knot it off insuring no more than .25" tail on the knot and pull tight. :)
Jul 22, 2010 | Poulan/Weed Eater No. Te475 952711797 17"...
Pull string came off as I was trying to start it.
there should be three or four screws to the top of the mower where the string goes, after purchasing new pull string make sure you wind the spring when you re string, so that when you put the cover back on it will be spring loaded and in proper working condition
Oct 17, 2009 | Ariens Garden
I need to fix athe pull string on my toro push behind mower. it has an 195cc tecumseh motor. the string broke and i can't find anything on toro about how to fix it without buying the whole assembly.
remove bolts from cover and remove the cover. Should be able to access the assembly for the pull rope. Go to a local mower repair shop buy some new line. The old line should just be knotted up on the spring loaded wheel in there. You put a new piece on put in a new knot, put some turns on the assembly to basically wing the spring so it snaps back when pulled, put line through whole and attach to pull handle.
Jul 11, 2009 | Garden
How to change the string
If it is a duel line trimmer then:
Cut two separate pieces of string, about 7 ft. each.
Stick the end of the line in the hole on the inside of spool.
Wind clockwise onto spool, putting the line that is closest to the ground on first.
Once you have winded this piece on, lock the last 4 inches of line through the slits on spool.
Repeat process for second piece of line, locking the last 4 inches in slot opposite the other locked in piece.
Put the spool on the trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the locked position.
If it is a single line trimmer, just wind a single piece of string clockwise onto spool.
Jim
Jun 29, 2009 | Homelite Mighty Lite Lawn Trimmer
Pull string
Oppen the tray and change or put new suply of string
Vitally
Jun 02, 2009 | Troy Bilt Tb70ss Gas Trimmer
Garden Logo
69 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
