Question about Panasonic TCP42S2 42 in. TV
Noticable flickering when viewing dark images.
Whenever I'm viewing a dark image in a darkly lit room I can see flickering or flashing in the blacks. It happens on all inputs. The tv displays fine otherwise, but it doers this when I'm viewing in the optimal setting for a plasma. Service center says there is nothing wrong with it and Panasonic won't do anything without the service center admitting there is a problem
Hello, I too experience this exact same problem. In my opinion, any television under 2 grand is probably going to have some slight imperfection as this; I have tried a few different ones myself. To some, it would appear to only be a minor annoyance, but to those who truly can distinguish a good quality picture between a bad one, or to those people, such as myself, who would find something like this to be unacceptable, this is a disheartening situation.
My friend, I have tried many different settings to see which ones might resolve this issue with the blacks in the picture, or at least reduce it to a barely noticeable level and I have found that when I select the CUSTOM picture mode, reduce the contrast to about 60, turn up the brightness to 62, turn OFF blur reduction,x/v/ color on, CATS on, MPEG NR ON, turn Dark level to LIGHT(this is important) add a little bit of extra color for ex. 52, and sharpness to 75, that this produces a pleasing to the eye performance when watching blu ray movies and dvd's. The flickering is reduced to almost nothing, and the picture quality actually appears sharper and more ethereal in certain ways.
The downside to this is that you are lacking some true depth in the picture's darks, but after your eyes adjust and you are watching a good quality movie, you will notice that there still sort of is enough darks there to compensate. Further fine tuning may produce even better results, jsut have to keep playing around with it. But I am now convinced after hearing somebody come forward with the same exact problem i'm having on the same tv, that it is not a defect but just an imperfection that you sometimes have to deal with when you don't spend like 5 grand on a tv. Good luck and happy viewing!
Posted on Sep 14, 2010
Olympus e420 no live view black images
are the photos on the memory card? LCD could be shot or loose.
Mar 12, 2014 | Olympus Cameras
Tip
My camera has spots in the picture
The spots are caused by the flash being SO close to the lens. Anyobject that can reflect the flash reflects it right back at the camera.
This is an image problem with most point and shoot digitals. Watch forreflective surfaces and stand at an angle to them. Turn on more lightsin the room before using flash. Most indoor pictures start way too dark.
Stand at a slight angle to the image orperson you are photographing - don't shoot straight on. (I kneel downand shoot up - makes a good shot too.)
If you are shooting toward the sun lit side of an image, shield the lens from direct sunlight with your hand (Keep your hand out of the picture!)
A professional photographer has the flash way away from the lens for a reason...
on Mar 31, 2010 | Cameras
Olympus Fe-4000 screen is completely black no image available
Stephan is exactly right. I have a FE-4000 and the LCD screen is most likely dead. As Stephan said, the screen should be replaced by a professional.
Cheers to all
dmklunk122
Dec 16, 2009 | Olympus FE-4000 Digital Camera
LCD screen is very dark, Pictures taken are underexposed
CCD FAILURE !
Call Canon for FREE REPAIRS it is a known issue ask them about BAD CCD see this link for service advisory
RATE ME WELL !
Regards
Zohail
Jun 01, 2009 | Canon PowerShot A640 Digital Camera
Dark fuzzy/flickering screen - Cannon PowerShot A75
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Jan 25, 2009 | Canon PowerShot A75 Digital Camera
Projection TV when turned on picture is dark can view slight images until dinning room light is turned on
Try hooking the TV to a different outlet fed by a different breaker. Does the problem go away? If so, the culprit may be a wiring problem in your house that is causing the TV not to get enough power unless the dining room light is on.If in doubt, consult an electrician to make sure both the dining room light and TV outlet circuits are working properly.
Mar 06, 2008 | Mitsubishi WS-55613 55" Rear Projection...
Black image
ig you see an image but its just too dark, try adjusting the settings of brightness and contrast including lighting on the room.
Jan 16, 2008 | Philips J44414
CANON Rebel RTI Outdoor pictures are dark
learning to use light metering correctly can have its challenge.
the manual will guide you on how to set up to read light from the subject. spot metering a dark area will cause general overexposure, or a washed out look. spot metering a bright area will cause a dark image. if you are on spot meter and shoot two people standing together against a bright lit background, your meter will see between them if they are centered, and read all that bright background, setting the camera to a less sensitive combination of aperture / shutter speed, resulting in a dark image. use field averaging meter setting and be sure you are metering the subject and not the background. try shooting a wall that is fairly clear of other colors and uniform it light hitting it, you should have a correctly exposed image. since it works in other modes (at least 1, anyway) then it is unlikely you have an exposure compensation issue. that is the only other non defect issue that would cause your problem.
once you confirm that you have these settings correct and still get a dark image, its time to have it serviced.
good luck
mark
Sep 01, 2007 | Canon EOS 400D / Rebel XTi Digital Camera...
INDOOR PICTURES ARE TOO DARK
try using the night shot it will go slower but it works well for dark pleases
Dec 17, 2006 | Aiptek MPVR Digital Camera
Panasonic TCP42S2 42 in. TV Logo
224 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
