Question about E-Machines eMachines Desktop PC
How to turn on on board speakers in the bios - E-Machines eMachines Desktop PC
    Genius:
  • 1,189 Answers
Hi, click on the "Start Button," in the (right pane) Control Panel, next in the category listings, select Hardware and Sound, open, and click on the "Manage Sound Devices. The Sound window will open; click on the "Playback" button, there should be a Speakers Icon, click on it, look below to find the "Properties button, click to open, in the next window there will be (4) four buttons "General, Level... First click on the "General" button, in the top of the window there will be a "Driver" button, select to "Update Driver," just click on it, the [Drivers] will be updated. You can go back and configure Speaker Level etc... Next if you have a "MIC" do the same for the [Micriphone] as you done for "Speakers" in the [Recording] category. Note: "Remember to click on the "Apply and OK buttons afterward to make sure the changes take effect." "Restart the computer to finalize the changes." "Rating the solution on it helpfulness, lets me know if you resolved the the problem or you need further assistance, thank you."
Posted on Jul 05, 2010
    Genius:
  • 1,970 Answers
Mcdevito75 here, To turn on sound or make sure sound is on in your computer try this, --- click start, then control panel, then audio speech devices, un-check the mute box and check the place volunm icon in tray box.
No display when starting after installing in new machine. I bought TWO ECS MCP61M-M3 motherboards for my kids for Christmas and have the same problem with BOTH. This is in a completely new computer build....
First thing I would do is try using the monitor on another working computer to see if it works. If so, you have eliminated that as an issue.
Kind of hard to fathom that you got two fubar mo bo's but as they stay in the street, sh-- happens. However, The lack of a beep means that the bios is not posting. When you turn on a computer, the bios does a check of internal components and environment - if all is ok, it beeps and then has the hard drive install the operating system into the computer's memory. And if something is wrong, the bios will usually give out certain beeps that are coded such as when you have bad memory, no memory, etc. But you are getting zippo, and no video at all on your monitor - this is one of the few times you wish you had the blue screen of ***** because with that at least you know your hardware is ok but your software has an issue.
The conditions you have reported would seem to indicate that the bios chips on both units are corrupted and not working. U might also make sure that the memory chips are good. A bad chip, not a missing chip, will sometimes prevent the mo bo from booting up.
If you also remove all the memory and turn on the witch, if the bios is working it will beep like crazy. If nada, bios is dead.
If boards are new as you indicate I would return for exchange.
Mar 03, 2017 | EliteGroup ECS MCP61MM3 (V10) AM3 NVIDIA...
Cmos battery on dell inspiron 4100 model PP01L
Reserve Battery Removing the Reserve Battery notice.gif NOTICE: The reserve battery provides power to the computer's RTC and NVRAM when the computer is turned off. Removing the battery causes the computer to lose the date and time information as well as all user-specified parameters in the BIOS. If possible, make a copy of this information before you remove the reserve battery. notice.gif NOTICE: Disconnect the computer and any attached devices from electrical outlets, and remove any installed batteries. notice.gif NOTICE: To avoid ESD, ground yourself by using a wrist grounding strap or by touching an unpainted metal surface on the computer. notice.gif NOTICE: Read "Preparing to Work Inside the Computer" before performing the following procedure.
  1. Remove the hard drive.
  2. Remove the keyboard.
  3. Disconnect the reserve battery cable from the system board connector.
  4. Pry the reserve battery free from the system board. The reserve battery is attached to the system board with a piece of adhesive tape.
  5. Remove any remnants of the adhesive tape from the system board.
reserve battery
speaker connector
Replacing the Reserve Battery
  1. Connect the reserve battery cable to the system board connector.
  2. Position the reserve battery above the speaker connector on the system board.
  3. Update the BIOS using a flash BIOS update program floppy disk or CD. For instructions on how to flash the BIOS, see "Flashing the BIOS."
this information was found on the following page which might be useful to you in the future.
http://support.dell.com/support/edocs/systems/ins4100/en/sm_en/remove.htm#1090379
Sep 30, 2009 | Computers & Internet
Dell Inspiron 5100 integrated speakers cannot turn on.
Confirm that your BIOS does not have a "Mute PC Speaker" option. Confirm that you have not muted your PC Speaker in your OS. Remove the Palm rest via screws on the bottom of the machine, Remove Keyboard, Confirm that your speakers have not become disconnected/loose in anyway. Speakers are generally connected to the system board below the area of the touch pad.
Apr 13, 2009 | Dell Inspiron 5100 System Board (...
AMI BIOS (8/23/07) DOES NOT FINISH BOOT ON NEW ECS G31T-M
Greetings,
What I would like you to do is take off any additional cards that you have on the board (If any) All I want you to have hooked to the board is 1 stick of ram, the processor, keyboard, mouse, monitor, and power supply.If you have attached any of the USB connectors for your case disconnect them. (Do you have a processor fan or heatsink attached to the processor? If you do not make sure that you have one attached and that it is working.) Turn on the computer and enter the bios setup if you can get there and load the default settings. Save and exit the bios.
After doing these steps please tell me what it says on the screen when it freezes. Please be patient once it gets to the point where it normally freezes give it a minute to see if it goes anywhere.
Please be aware that these boards ar notorious for being DOA (Dead On Arrival) I personally have had 3 Elitegroup boards that were DOA when I got them (They came free with my processors when I boutght them new from Frys Electronics)
Let me know the result and what you see on the screen and I can assist in further troubleshooting.
Dec 30, 2008 | ASUS P5LD2 Motherboard
New asus m3n72-d motherboard bios will not post
If you don't already have a case speaker hooked up to the board, you might want to connect one since there isn't an on board speaker and you will not hear error beeps otherwise.
Also, if you have another non-phenom AM2 processor handy you should really update the BIOS to latest release. Many late model Phenoms will not work on motherboards that have earlier BIOS releases and you will not be able to post. You should then choose "Set Optimized Defaults" and save the bios without any changes then shut down (not reset). When you power on again it should post and you should be able to get into the BIOS.
A third thing you can try (after you get a case speaker hooked up) is using a cheap pair of ddr2-6400 RAM to get the board to post so you can get into BIOS and change the voltage to the correct settings for your RAM if it requires a higher voltage than the bios expects.
Aug 23, 2008 | Intel Motherboard
No Beep but boot up fine
possibly the on board speaker is disabled in the BIOS ?-
May 16, 2008 | Intel D865GBF Motherboard
I have speakers on my pc screen and i have plug in speakers but none of them work can you help me
Check you system BIOS and make sure that your on-board or add-on board is selected. Also make sure that your external speakers have power to them..accordianman
Apr 30, 2008 | Audio Players & Recorders
915PL-A2: no post, no beep, no keyboard lights
You may have a short between the board & the case. (check it).
Even if this means removing the board. That clicking you hear through the speakers suggest a short. Make sure your using (Stand offs) which keeps your board off the case's mounting surface. Check the back plate so the tabs are touching the ports comming off the board for good ground.
Double check the you have fully connected both the main power ATX_ 20 pin power connector & the auxiliary 4-pin power
connector. pg. 10. Connecting 20/24-pin power cable Remove & re-seat. If your PSU has a 20 pin connector make sure you connect the cable from the correct end.
Without POST you will not get video to load. Reset your bios
pg. 9 in your manual. Re-enter your bios and setup the bios settings for your board.
Let me know if this helps you reach POST?
Mar 14, 2008 | EliteGroup (ECS 915PL-A2) Motherboard
Just purchased this motherboard, can't get bios to boot
just be sure...
take out everything, except the the power cable and the little speaker. try to turn it on. there will beep sounds. if not, the problem is the board. if there's sound, check connections.
also tell me the model of it, if possible.
after turning it on, check the power and hd leds, if they are on, or blinking.
check if hd and dvd are both jumpered as master. try removing both, just to try to get the bios working.
and one last thing, check it there's a intrusion jumper on board, if yes turn it off.
Dec 02, 2007 | EliteGroup 945GZT-M (V1.0) Motherboard
E-Machines eMachines Desktop PC Logo
166 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
