Question about Maxtor OneTouch III Mini Edition 120GB External USB 2.0 Portable 120 GB IDE Hard Drive
BROKEN PLUG? The connector on the back of my Maxtor hard drive snapped off and fell inside the unit. Is there any way to transfer thedata to another external hard drive??
    President:
  • 2,600 Answers
You can buy another external housing and then just swap the hard drive itself over to the new housing. The housing only cost in the 30 buck range if not cheaper. If you need to get the data off, you can also buy an EIDE/SATA to USB adapter that will allow the connection between an unhoused hard drive and a computer. CompUSA sells them for around 20-25 bucks.
Posted on Jul 06, 2010
Hi there we purchased a maxtor basics 500gb hard drive about 3 years ago. we have had children in that time and unfortunetly our two year old daughter dropped it. we have taken it to a service store but...
If it is the external hard drive enclosure that is broken then yes. But if it is the hard drive itself that is broken then no.
From what happened I'm thinking that it is the external hard drive enclosure that is broken. That being said, you can easily buy one without the hard drive online. When doing this be sure you know what kind of hard drive is in your Maxtor enclosure. This is important because you need to be sure that your hard drive and enclosure are compatible. Check to see if it uses SATA, ATA, or PATA connectors and then buy the corresponding external hard drive enclosure.
Once you have bought your new empty external hard drive enclosure, it is simply a matter of opening up your Maxtor enclosure and moving the hard drive inside to your newly purchased enclosure and connecting it to your computer.
To avoid problems like this in the future, look into "cloud based storage" to back up all of your data securely online.
Mar 29, 2011 | Maxtor Personal Storage 3200 (U01E200) 200...
How to take the outer casing off a maxtor one touch external hard drive
  • Feel along the back and bottom side of your Maxtor external hard drive. Depending on the specific model of hard drive you have the unit may have screws or plastic latches inside the case. Pull of the warranty sticker and check to see if the screws are located underneath it if you don't see any screws anywhere else. Pull out the rubber stoppers at the bottom of the external hard drive case and check if the screws are located underneath. Remove the screws if your model of Maxtor external hard drive has them. Insert a thin and flat object such as a flat head screwdriver between the seams of the two sides of the case if there are no visible screws. Run the flat object around the length of the external hard drive case until it hits a plastic latch. Wiggle the object up and down until the latch disengages. Continue sliding the screwdriver along the sides until all the latches are disengaged. Pull the two sides of the Maxtor external hard drive case apart to reveal the actual hard drive enclosure inside. Remove the screws holding the hard drive into its metal cage. Pull the existing hard drive unit out the metal cage and replace it with the new hard drive. Reassemble the unit and plug it back into your computer.
Oct 27, 2010 | Computers & Internet
Maxtor 3200 was working fine. Suddenly my
Try connecting it to another computer.
If it is not detected, then either the disk-drive "inside" the unit is dead, or the "adapter" (USB-to-Disk-Drive) inside the unit is dead.
If the latter, disassemble the case, remove the disk-drive, and attach it as an "internal" hard-drive to your computer.
Nov 01, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor one touch 2 300gig wont switch on
Yes, this is a known Maxtor issue. They draw a lot of current, hence the 2 usb connectors. Devices that pull a lot of current need good connections.
Yes, the electronics inside the drive can go bad and they can be sent in for repair. Before doing that, though, try the following:
Make sure that the drive is plugged into usb ports that connect _directly_ to the motherboard (the ones one the back of the computer). Also, try to use usb 2.x ports instead of usb1.x
Try plugging the drive into another computer.
Aug 27, 2008 | LaCie d2 Extreme (300793U) 500 GB Hard...
Maxtor external back
plug in your external drive, and note it,s letter ( assigned device name ) i.e F/G/H et,c.
open your c:/ drive. highlight which items you want to copy over.
left click to highlight. then right click/Options/scroll Down Send to DriveF/G/H
And transfer, this should transfer what you want from 1 drive to another. But Don,t try to copy Windows. you.ll have errors as some of the sys files, will be in use whilst transfering.
mike @ compurepair.
Feb 20, 2008 | Maxtor Hard Drive
Transfering data from Maxtor to a new computer
It's a USB Hard drive, so you should plug the USB port into one computer, put your information on it, then plug the USB port into the other computer. Browse the Hard Drive for your data. It's like a larger flash drive.
Feb 10, 2008 | Maxtor One-touch III Mini 40 GB USB 2.0...
Maxtor Personal Storage - beeping noise
consult the authorized service cenetr of amxtor as they can recover data from damged hard disk . carefull while connecting to pc . as it can damage pc if circuits are broken
Dec 03, 2007 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor One Touch External HDD not being recognized by PC
Try to use other running usb connector or check the HDD inside the external if is plug it will.
Nov 01, 2007 | Maxtor OneTouch USB (A01B120) 120 GB Hard...
Maxtor OneTouch III Mini Edition 120GB External USB 2.0 Portable 120 GB IDE Hard Drive Logo
149 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
