Question about Canon PC-940 Black and White Copier
I had a paper jam. Got the paper out, but now
I had a paper jam. Got the paper out, but now can't get rid of the paper jam symbol...and won't work. There is no paper remaining in the copier. Could there be a reset button somewhere?
  • 903 Answers
Some printers won't reset the jam condition until you open a specific door or cover -- even if you've gotten the jam out, they think it's still there until you open that cover. Try opening and closing all of the machines doors and access points, and even pull out the paper tray and push it back in.
If the jam condition still isn't cleared, turn the machine off and back on with the main power switch.
Posted on Jul 06, 2010
My workforce WF-3540 displays "PAPER JAM". I can find no jam
This sounds weird but I will post it since is solved this problem for me. Despite following all the instructions I could not get rid of the "paper jam" message on my WF3540 . In desperation I tried changing the yellow ink cartridge (which was low) and after the printer went through all its "new cartridge" routine - lo and behold the paper jam message was gone and the printer worked!
Sep 25, 2013 | Epson Workforce 1100 InkJet Plotter...
A warning sign has appeared on the printer, which says: 'Paper is jammed in the printer. Turn off the printer, open the scanner unit, and remove the paper. See your documention'. But There is no paper...
either a sensor broke
or
a small tiny piece of paper is stuck
after removing a jam if the paper tears a small piece of paper can cause the jam error message
Jan 19, 2011 | Office Equipment & Supplies
What does the "heart beat" symbol/light mean?
I assume you mean the symbol that has a pair blackened circles and then a pulse up and then down below the starting line before returning to the starting line.
That is the paper jam symbol. If the continue light is on (steady) and the paper jam light is on, then you have a paper jam. Press Continue twice to see any secondary error message (this will show where the problem is).
See the manual for the list of the lights that show where the jam is occurring. Different groups of lights will be lit. The manual is available as a PDF at the bottom of this page: http://support.lexmark.com/index?locale=EN&page=product&userlocale=EN . An example: if the Continue, Toner Low and Paper Jam are all on, then the jam is in the fuser area under the print cartridge assembly. For a paper jam, even a small corner of torn paper could be in the mechanism.
In all cases, you should check the entire paper path. When you pull out any paper, grip it so that you can gently pull the sheet straight out. Remove all paper from the output tray. Then remove the paper tray if you are using it. Pull any paper from this area. Press down on the green duplex flap and remove any paper from there Reinsert the paper tray. Open the front door of the printer and remove the print cartridge assembly. Lift the green flap and remove any paper from the area. NOTE: the fuser and the fuser area may be hot. Open the rear exit door and remove any paper from that area. Use a flashlight to check for small pieces of paper that may be stuck. Once all the paper is removed, reinstall the print cartridge assembly and close all the doors. Press Continue to reset the printer.
The page that jammed may be reprinted.
I hope this helps.
(please note that frequent paper jams may be a sign of excess humidity in the paper. Put less paper in the tray at each refill and keep the remaining paper in a dry location. If the paper jam light is coming on when no paper jam is present, one or more of the paper jam sensors may be bad. Contact Lexmark for more information.)
Nov 30, 2010 | Lexmark E250dn Laser Printer
Symbol lit up but don't know what symbol means, I don't have manuel - begins with 2 dots :
The symbol with the 2 dots and what looks like a jagged line is the paper jam indicator. Open the paper tray and or front and back access doors to find and remove the paper jam. I the light still does not clear try turning the printer off then on to reset the jam indication.
Aug 20, 2010 | Lexmark E260 Laser Printer
My laser jet just stopped printing. the symbol
indicate paper jam light but not paper jam in it , some times it it works what shall i do
Dec 16, 2009 | HP LaserJet P2015dn Printer
Orange warning symbol on my Canon PC745.
have a look for a piece of paper stuck over a sensor or a sensor flag broken or stuck, thats why it still thinks it has a paper jam in it
Sep 27, 2009 | Canon imageRUNNER 5000 Copier
Rear Paper Jam - No paper present.
Look for a small piece of paper that may be stuck in the switch indicating a paper jam.
Jun 01, 2009 | Canon PIXMA MP610 InkJet Printer
Error symbol
it is a jam after clearing paper from tray you have to open top cover to reset or paper may be under cartridge. gl
May 27, 2008 | HP LaserJet 5p Printer
Canon PC-940 Black and White Copier Logo
189 people viewed this question
old marine
old marine
