Question about Vacuums
Elna 500 Club sewing machine - no power when foot control is pressed
2 Suggested Answers
SOURCE: Elna Top 300 sewing machine.
isoj:
I have this machine. I use it for my heavy sewing, as it will go through anything. I would be happy to copy the manual and send it to you for copy costs. Just let me know. I would love to know what knowledge you have gained about this machine. It does not appear to be an easy machine to find info on, may not have produced a lot? I had no idea it was not a European produced machine.
Lisa
Posted on Aug 04, 2008
7467S sewing machine beeps four time and won't let me sew
Hi! Probably too late to help the original asker, but I have this same machine and was having the exact same problem. 4 beep error message, but mine would not sew at all. Found this question through a google search, but no answer. But I figured it out! I had left the buttonhole lever down!! (Facepalm) I hope this is helpful to future googlers with a similar problem.
Feb 05, 2014 | Singer 7467S Confidence Stylist Electric...
What year is my singer sewing machine? AH251729? how do I purchase parts for it, like the zig zag attachment?
The Singer vintage machine site indicates that the AH251729 was made in 1947 in Elizabeth, NJ. For details see http://www.singermachines.co.uk/faq/tell-sewing-machine-age-from-two-letter-serial-number/ .
Look on the front of your sewing machine and locate the model number of the machine. Go to http://www.singerco.com/support/replacement-parts-chart and locate your model number. (Use the drop down menu and locate the group. Press Go and then find the pdf with the correct model parts list.) You can look up the exact part number and order them from the Singer Service Center online.
Alternatively, you may be able to find them at any Singer Authorized retailer. Just look at your machine and determine the type of shank that connects foot to the machine. (High Shank and Slant are common Singer foot designs on older machines.) Get a zigzag foot for Singer machines with that design. (If they don't have that, you can probably get a current foot and an adapter. We got an overedge foot and the high slant foot adapter for my Singer sewing machine (purchased in 1969) in the 1980s.)
I hope this helps.
(Singer parts are generally available. I saw throat plates for some Featherweight machines this morning at a quilt show.)
Sep 04, 2011 | Singer Vacuums
Cant thread cotton correctly resulting in top cotton bunching around bobbin on my elna carina su sewing machine
Hi. Correct threading of your machine is absolutely essential for flawless function. I would suggest starting fresh, removing upper thread completely. For correct function, every threading point needs to be passed in the correct order. Every hole or thread guide should have thread going through it. Use a tweezer and pass the end of the cotton through each point, paying special attention to the tension discs and take-up lever. Double check to make sure you have light but firm tension on the thread (having lowered the presser foot, because tension is released when foot is up). Rotate the hand wheel slowly in it's normal direction to check function before attempting to sew.
Aug 20, 2011 | Vacuums
When you turn the sewing machine on it constantly keeps on going almost like you have your foot on the pedal all the time the machine is a contessa 410 model
the foot pedal controls the voltage to the machine. If it is running to fast then the foot control is bad
Apr 18, 2011 | Vacuums
Where can I get my Elna machine fixed? It is quite an old model and the zigzag function is broken. I am in the Toronto Downtown region.
Here is the email address for Great Western Sewing Machine Services in Toronto: brian@gwsms.com
He was the service manager for Elna, Toronto for many years.
Also, Norm Sewing Machine provides on-site servicing. Here is there phone: 416-993-4466
Hope this helps. If it does, I'd appreciate your vote. Thanks,
Handie Andie
Apr 06, 2011 | Vacuums
Manual for elna diva sewing machine
You can find a free download of the manual for the Elna 9000 which is almost exactly the same as the Diva.
http://pdfdatabase.com/search/manual-elna-9000-pdf.html
Let me know if you have any other questions. Thanks.
Mar 21, 2011 | Vacuums
I have an Elna 745 serger/overlock machine. Whenever I'm doing a double cover stitch hem, when I'm at the end, the thread release lever does not release the thread. To release it, I have to cut the...
There are two methods to release the cover stitch with sufficient slack in the thread. Since you are using the thread release lever, did you set the Brown tension dial to zero? Before changing the tension, you have to first lower the needles to their lowest position in the fabric with the hand wheel and then turn the hand wheel backwards to bring the needles to the highest point in the cycle.
The other method may work better for you. Bring the needles to the highest point in the cycle and lift the presser foot. Then slide a thin object (a sewing ruler, for example) between the presser foot and the feed dogs and pull the needle thread towards you. Cut the needle threads Then pull the fabric away from you before cutting the looper threads.
Both of these options are described on page 98 of the manual, which is available from Elna. The current link to the manual is http://www.elnausa.com/data/files/2_users/55/Inst_Book_745_%28E-F-G-I%29.pdf . Pictures for the second method are available here: https://www.seamwork.com/issues/2015/06/coverstitch-machines . (Ending the double cover stitch hem is the same as that for the single cover stitch.)
I hope this helps.
Nov 27, 2017 | Vacuums
Elna Top 300 sewing machine. I need manual to operate this machine. I have already found out that Elna contracted with Tiwan(excuse my spelling) to make there machine between 1989-1991. I want to know...
isoj:
Lisa
Mar 27, 2008 | Vacuums
Vacuums Logo
137 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
