Water will fill with water, but will not spin the water out, will extract water,you can hear the motor running. rhondah704@aol.com
  • 975 Answers
Sounds like the DRAIN MOTOR PUMP is clogged , you need to open the front panel or back panel depending on the model to
access a little motor thats attached to the drain hose , take the motor out , check and clean for any debri thats blocking the impellers , that will do the trick ( hopefully )
Posted on Apr 18, 2008
I have a GE spave maker Laundry that fills up with water than stops!
GE Washer Not Agitating Repair Guide
www.appliance-repair-it.com/GE-washer.html
If your washer will not agitate or spin take a look at this page GE Washer Not ... If the washer fills up with water then doesn't do anything at all and you do not hear ... if this were the problem, the water would not stop running, over-filling the tub.
GE washer spin cycle not working - ApplianceBlog
www.applianceblog.com/.../217-GE-washer-spin-cycle-not-working
Mar 12, 2005 - 10 posts - ‎3 authors
I have a GE "Spacemaker Laundry" (Stackable) model number ... Today it filled withwater initially then stopped working all together when it ... Bad motor, something jammed/seized up holding the motor back from running?
Jan 10, 2016 | GE Spacemaker Washer and Dryer Electric...
What is pump out for & how does it work
does your machine have a rinse cycle that requires the dirty water to leave the machine and then to have clean water fill the machine that then rinses the colthing of detergent and dirty water that then needs to be pumped out. Then does it have a spin cycle that extracts the water out of the items and needs to pump out excess water do clothes have water extracted out of them ?
A pump connected to a motor via a belt spins the pump turbine and pumps out the water.
Aug 06, 2015 | Washing Machines
Lg front loader when during the cycle is the bleach dispenced
bleach? do u mean detergent? normally machines run pump/then start to fill.water will pass through drawer then they heat /wash/drain/spin then refil for rinse conditioner/spin rinse drain fast spin end pretty much
Aug 08, 2014 | LG WM2101HW Front Load Washer, White, 4.0...
If it fills with water but won't wash, is it the timer
hi mary,i just wrote and asked you for the model number,if this is a regular top load washer it could be the timer as long as you don't hear the motor running,if you do hear the motor running you could have a broken motor coupling because the drain pump is on the motor shaft so it will drain,
http://www.youtube.com/watch?v=9K1KHEogf3c
if you don't hear the motor it could be the timer,when it should agitate try tapping on the timer and see if it works,it has points in it and they can get stuck together or burn out and have no contact like you're saying but it's just a guess without seeing it but if the timer is advancing through with no agitation it could be the timer,did you try any other cycles
Apr 02, 2013 | Washing Machines
Water will fill but wont do anything else
Does the water turn off when filled? If so can hear a motor humming or running? If so you have power to the washer.
Can you turn the timer ahead manually a step at a time? Then if you don't hear the motor running the timer may not be working or sending signals to motor to start. . But If the motor starts a spin cycle then the timer is just not running itself probably dut to not getting power.
All this is difficult without the diagrams. There are so many interlocks and safety switches that you wont know about.
Jun 26, 2011 | Whirlpool Washing Machines
Whirlpool washing machine LA5310XPWO wont agitate -- what would cause this and how can it be repaired?
Is this a top or front loader? If it is a top loader do you hear the motor run? If you do the first thing to check is the rubber driver between the motor and the transmission. One way to chek if the motor runs is to fill it with water and put it into spin. If it pumps the water out that means the motor runs. If the rubber driver is broke (happens often) it will neither wash nor spin.
May 20, 2011 | Whirlpool Washing Machines
D@aol.comthe water come in the washer but the washer do not agitate or spin the water out
If the motor is running and not agitating or spinning, then the problem is a broken motor coupler. If the machine fills with water and then it is silent, then you will need to replace the lid switch.
Feb 26, 2011 | Roper Washing Machines
Washing machine stopped and says "sud". What does that mean?
SUDS DETECTION
During Drain Routine
During the Drain Routine, the water level is checked continuously. Normal drain will occur until the
pressure switch senses no water in the wash tub and there is no foam (suds). The drain pump will
operate an additional 15 seconds after the pressure switch reports no water or foam.
If the drain routine operates for four (4) minutes and the pressure switch senses any foam (suds) in
the wash tub, the Central Control Unit will start the "Kill-Foam" Routine. (See description of this
Routine below.) After the Kill-foam Routine is concluded, the Drain Routine will restart. If, after
four (4) minutes the pressure switch still senses foam in the wash tub, the Central Control Unit will
go into Failure Mode. The digital display will show, F02.
During Spin (Extract) Routine
During the Spin/Extract Routine the water level is checked continuously. If, during this routine, the
pressure switch senses the presence of foam (suds) in the wash tub, the Central Control Unit will
stop the drive motor and the basket will stop spinning. The electronic control will count the number
of spin repetitions that are attempted due to foam (suds). There are a maximum of three (3)
attempts for each Spin/Extract Routine.
Kill-Foam Routine
1. The Remaining Time counter is stopped.
2. The digital display shows Sud.
3. The Drain Pump is turned OFF.
4. The Central Control Unit will fill the wash tub with 1 gal. (4 L) of cold water.
5. While the tub is filling the basket will tumble 1 sec. ON/15 Sec. OFF.
6. Once the tub is filled, the drive motor will turn OFF and the basket will rest without any
movement for five (5) minutes.
7. After the five (5) minute rest, the remaining time counter will restart and the digital display
will show the remaining time left in the routine.
NOTE: If the Kill-Foam routine was initiated during a Spin/Extract Routine, the tumbling action
will be reduced to a cycle of 3 sec. ON/13 sec. OFF. If, at the end of either the Drain or Spin/
Extract Routines, a suds condition still remains, the digital display will show Sud.
Sud will also be displayed for a short period at the end of a cycle, if a Suds condition was
detected during the cycle. This will alert the consumer to reduce the amount of detergent in
subsequent uses.
Oct 07, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Will not fill with water or agitate but will spin.
The problem might be due to the motor is trying to run and can't or does'nt start or the motor is running but the belt broke and so it is not transfering any power.You will need to take a look and see which is the case.
Motors and belts can be challenging to repair so be warned if you are attempting the fix yourself. It does depend on the machine some are harder than others....
Mar 28, 2010 | Maytag Washing Machines
Will fill water but agitator wont run.
Thats very agitating.There is a motor that runs the agitater,its either going out or you have lost the drive,a little spendy to have fixed.
Hope this helped.Let me know by rating me
For more help go to live chat.
lenwest
Jan 31, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing Machines Logo
Top Washing Machines Experts
