Question about Kitchen Ranges
My electric range is only 4 years old.and the elements get red on the lowest setting is there a recall????
  • clair99 Aug 26, 2008
    I moved into a brand new house 4 years ago. My electric spectra range came brand new with the house. Just last summer the large burner got red hot on the low setting. I tried turning it off and it would not shut off completely it would go off for a few seconds and come back on red hot again. I had to turn off my range from the elecrtic breaker box to stop the range from coming on and off. I also smelled a terrible rubber burning smell and saw smoke coming out the back of the range. Have anyone ever had this happen?
  • 145 Answers
I don't know of any recall on range switchs. I would check with the manufacturer of the product if you think there might be. It's not uncommon for the switchs to wear out and stick.
Posted on Apr 18, 2008
ONE DOUBLE BURNER ONLY WORKS ON HIGH NO MATTER WHERE I SET IT
Hello Miguel;
My name is Peter. I am a retired field service appliance technician.
There are two electrical components that will cause this problem. The most probable cause is the burner element. Each of your burner elements have a independent temperature sensor. The sensor controls the burner element temperature.
Substitution Part Number: 4453909 Cost: $85.00
This surface element (part number 4453909) is for electric ranges, including Whirlpool electric range model GJC3034RB00.
Unplug the range or shut off the house circuit breakers to disconnect electrical power to the range before replacing the surface element. Wear gloves to protect your hands when replacing surface element on your electric range.
This is a manufacturer substitution. Part may differ in appearance but is a functional equivalent to priorparts including 9759351.
OR:
PART NUMBER: 8523698 Cost: $71.00
The other less likely electrical component is Surface Element Control Switch. Each burner has a independent control switch.
Cost: $46.00
To check the switch: Remove the switch 2 contacts on the left. With a multi-meter, set the meter to the lowest Ohms (Omega Symbol). Put one meter lead on one switch contact and the other meter lead on the other contact. If the switch is good you meter will read "0" Ohms.
Jan 18, 2015 | Whirlpool GR673LXSS - Stainless Steel...
Samsung range element only works on High at all times.
What is the complete model number of the unit?
Dec 09, 2012 | Kitchen Ranges
We have Amana electric stove AER5735QAS that will not heat beyond approx 180-200 degrees when the stove setting on heat is set to 350. The stove is approx 4 years old. Impression is the problem may be...
If the heating element cycles off and on, it's probably not the problem but a thermostat or high limit. The thermostat should have a sensor wire, a part for sensing temperature and should not be placed or located anywhere near the heating element.
Oct 29, 2017 | Amana AER5735QAS Electric Kitchen Range
I'm having trouble with the lower heating element not heating on my GE Electric Range. Its probably 10 + years old. The broiler element heats. Will I be able to replace the element or circuit board? ...
Most of the time it the heating element.
(recheck your model number)
Here is a good source for replacement part
http://www.partstore.com/Content/CategoryPages/Kitchen-Cooktops.aspx
Or directly to GE
https://www.geapplianceparts.com/GEApplianceParts/Dispatcher?REQUEST=LANDINGPAGE&AppliancePart=Cooking%20Products
Dec 24, 2009 | General Electric Stove/Oven/Range Chrome...
I have a 4 yr old kenmore glasstop electric range. Problem exists with the broiler as it comes on when I set the oven to bake.
this is normal
about 8 years ago manufactures started to include the broil element in the preheat cycle to heat the oven faster
it should cycle down once the set temp is reached
Sep 27, 2009 | Kenmore Kitchen Ranges
Burner over-heating
burner control for that element is defective
Aug 13, 2009 | Kitchen Ranges
Large electric burners not working on lowest "LO" setting
Unplug the range and remove the problem elements.
With a flashlight, look inside the element receptacle for burned or disfigured terminals.
If they are damaged they can be replaced.
If the element terminals are OK you have defective switches.
Mar 18, 2009 | Whirlpool RF368LXKS Electric Kitchen Range
Dual element burner on glasstop range...inner element stays on
It is the burner control (behind the knob). The triac in the control has failed. $50 item, 10 minute change. Just make note which wire goes to which terminal.
I doubt that it is the control board, as the board has little to do with the stove top, but rather controls the display and the oven temperature/feedback monitoring.
Hope this helps.
Jan 14, 2009 | Frigidaire FEF366DC Electric Kitchen Range
Frigidaire ES400 oven controls
Contacts are fused.  Get a new one, cut the power and replace it.
Nov 08, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Kitchen Ranges Logo
122 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
