Question about Sharp R-319FW Microwave Oven
Have a Sharp Carousel Microwave oven model # R-409AK in which the clock/ timer digital display has become faint and can not read the time. The microwave works fine otherwise. What part do I need to order in order to fix this?
3 Suggested Answers
  • 8909 Answers
SOURCE: I also have a Sharp Carousel Microwave oven model
It is a display panel you require and you should be able to get a manual at the same time.
Try http://www.sharpdirect.co.uk/support/spares-and-accessories/page/spares/
Hope it is helpfull
Posted on Feb 27, 2011
Testimonial: "Thanks. I will take your advise and have hopes I will get results."
MicrowaveSvc
  • 9047 Answers
First of all, your owner's manual is part number IB-R405BK and you can get it at the Sears Parts Direct Web site or Encompass here.
For the display problem, you can purchase and replace the control unit / PCB control which is part number CPWBFB002MRU0. You can order that from those sources above for $91.49 or $83.04 respectively.
However, in most cases, they can be repaired for only $39.95 postpaid. See details here, where you can also get free help with disassembly.
Posted on Mar 12, 2011
I cannot reset clock
Touch Timer/Clock pad and number 2 pad.
Enter the correct time of day by touching the numbers in sequence.
Touch Timer/Clock pad again.
Aug 15, 2015 | Sharp Carousel R530EST Microwave Oven
What part do I need for clock/timer display for sharp carousel r1601?
You probably need the control board, and that is going to be an expensive repair.
May 22, 2015 | Sharp Microwave Ovens
Sharp Carousel R530BK microwave won't cook unless light pressure is kept on the door button.
There are door switches and one of them is evidently out of adjustment or the little actuator arm on it is.
Nov 27, 2013 | Sharp R530EWT Countertop Microwave Oven...
I also have a Sharp Carousel Microwave oven model # R-409AK in which the clock/ timer digital display has become faint and can not read the time. The microwave part works fine otherwise. What part do I...
Hope it is helpfull
Feb 27, 2011 | Sharp R-319FW Microwave Oven
Cant set the clock
hi
In most brandsof microwave oven, you set the clock by one of these combinations of key presses:
Clock > time digits > Clock
Clock > Clear > time digits > Clock
Clock > time digits > Start
If that doesn't work, please reply back with your brand and full model number.
All the best and do rate this answer if u r satisfied.
thankyou
May 10, 2009 | Microwave Ovens
Sharp Carousel Microwave Model R520-LK timer will run but carousel doesn't turn and food doesn't heat.
I also have the Sharp Carosoul oven, symptoms - fan runs, controls are fine but the turntable stopped turning and it did not heat. It was not the switches, fuse, but in fact a sagging door that misaligned with the door switches. The true cause was a warn top hinge. As a temporary fix, I adjusted the bottom hinge (3 screws underneath), straightened the door, and now it works again.
Dec 16, 2008 | Sharp Microwave Ovens
Assuming the unit works ok other than the display, you have a problem common to many Sharp models.
Check with www.microwavedisplay.com - lots of info on this issue and they offer a repair service for the boards at a very reasonable price.
Jul 10, 2008 | Sharp Microwave Ovens
No heating, no clock, no timer, otherwise fine!
One of your door interlock switches is defective . I would suggest having it repaired by a qualified repair tech in your area.
Oct 04, 2007 | Sharp R-1500 Microwave Oven
Sharp R-319FW Microwave Oven Logo
340 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
