The mouse and the rf Receiver go on but the cursor don't move. It's a model PD725DF
  • 518 Answers
Unplug the mouse lead from computer then refit and it usually actives the curser
Posted on Jul 05, 2010
Microsoft wireless mouse model 1007 , will not work
  • Put in the batteries Find the battery covers and slides it off. Insert the appropriate batteries. The wireless receiver that plugs into the computer runs off the computer's power and needs no batteries.
  • Plug in the receiver to the computer. Usually the receiver will plug into the USB port, but some plug into the mouse port. If all of your USB ports are filled, see if the mouse came with a USB adapter. The adapter fits into the mouse port. Be careful not to accidentally force the mouse adapter into the keyboard port.
  • Connect the mouse once you have it plugged in. The receiver should have a visible button that is easily push able by the average human finger. The mouse will usually have a very small hole with a button inside it that can only be pushed by something like a pencil or paper clip. Push both buttons at the same time with the receiver and the mouse relatively close to each other for about 5 seconds or more.
  • Position the receiver in a place that isn't far away from the mouse. Depending on where you are, you can place it on the monitor, on the tower, on the back of your laptop (if you are installing the mouse to your laptop) or on the desk. The furthest a wireless mouse can get away from the receiver without working very well is about 9 feet (2.7 meters), so keep that in mind.
  • Test your new mouse.
If you plugged into the mouse port, restart your computer manually.
If you plugged it into the USB port you may begin using it.
When the cursor moves when you move the mouse, you have connected the mouse properly. If the cursor doesn't move, try repositioning the receiver. If it still doesn't work, you may need to restart your computer (if you haven
May 16, 2011 | Microsoft Wireless IntelliMouse Explorer
How to install
Plug in the reciever into the computer and make sure the mouse has fresh batteries. Once you are in Windows, press the link button on the receiver. The indicator light should start blinking. Then within two seconds press the link button on the bottom of the mouse, the indicator light should quit blinking. After re-linking the devices move the mouse to see if it moves the cursor. If the cursor does not move, then move the mouse and see if the indicator light on the receiver blinks. If the device does not blink then try re-linking the devices again.
Jan 18, 2011 | GE 97985 Mouse
Keyboard does not type
If all the keys on the keyboard have stopped functioning follow the instructions below to reconnect the keyboard.
This problem is likely to be a lost connection. The connection between the mouse and the USB mini-receiver or the keyboard and the USB mini-receiver can be lost due to several reasons such as:
  • Low batteries
  • Moving the USB mini-receiver from one USB port to another
  • Moving the USB mini-receiver to another computer
  • Plugging the USB mini-receiver into a USB hub or other unsupported device such as a KVM switch (your USB mini-receiver must be plugged directly into your computer)
  • Using your cordless mouse/keyboard on metal surfaces
  • Radio frequency (RF) interference of more powerful wireless devices such as:
    • Wireless speakers
    • Computer power supplies
    • Monitors
    • Cellular telephones
    • Garage door openers
Eliminate any problem sources mentioned above that might be affecting your devices.
Follow the procedures below to reconnect your mouse and keyboard.
  1. Make sure the USB mini-receiver is directly and securely plugged into a working USB port on your computer.
  2. Make sure the mouse is turned on. The on/off indicator on the bottom of the mouse should be green. If the on/off indicator is not illuminated, press and hold the red connect button on the bottom of the mouse until the on/off indicator is green.
    On / Off Indicator
  3. Press and release the red connect button on the underside of the USB mini-receiver. This will broadcast a signal to your mouse. This broadcast will last only a few seconds, so you must perform the next step quickly.
    Red Connect Button
  4. Quickly press the red connect button on the bottom of the mouse for 1 second, then release it. The power indicator will flash briefly and then turn green. The mouse is now connected to the receiver.
    Red Connect Button NOTE: Holding down the red button on the mouse for more than 2 seconds may cause your mouse to turn off instead of connecting. If this occurs, start again at step number 2.
  5. Move your mouse to see if the cursor moves. If the cursor follows the mouse movements, your mouse is now connected.
  6. Press and release the red connect button on the underside of the USB mini-receiver. This will broadcast a signal to your keyboard. This broadcast will last only a few seconds, so you must perform the next step quickly.
    Red Connect Button
  7. Quickly press and release the red connect button on the underside of the keyboard.
    Keyboard Connect Button
  8. You will hear a short beep. The keyboard is now connected to the receiver.
  9. Test your keyboard to see if it is working. If the mouse now works but the keyboard still does not, see Knowledge Base article 9144.
Dec 14, 2010 | Logitech Cordless Desktop MX3200 Laser...
My mouse will not move the cursor
Have you syncronized it with the receiver?
Normally you press a button on receiver then press another button on underside of mouse to sync it.
Apr 14, 2010 | Dynex Wireless Optical Mouse
MS Mouse Optical 2000, scrolls by itself, opens links and moves the cursor all by itself.
Interference from other wireless users was my problem. The signal coming from other offices around me interfered with my mouse/keyboard. I had to switch back to wired mouse/keyboard.
Dec 11, 2009 | Microsoft 2000 Wireless RF Optical Mouse
Why wireless mouse doesn't move the cursor?
Remove the battery of the mouse and install new one and then press connect button from the mouse side and the receiver side also.and use the mouse pad .
Sep 21, 2009 | Computers & Internet
The cursor on my laser wireless mouse won't move
You need to sync the mouse with the USB receiver. They'll be a similar button on the receiver. Push both at the same time.
Apr 07, 2009 | HP Wireless Optical Mouse
Mouse stopped working, but appears ok, batteries ok, can't determine problem
Is the batteries good. If so try,
Normal 0 Press the Receiver button (and the lights will start flashing.
Then if the Keyboard isn't working, press the small RESET/CONNECT button on the back of the board to connect the keyboard to the receiver.
If the MOUSE isn’t working, push the small RESET/CONNECT button on the back of the mouse to connect to the receiver. Then they should work okay.
Hope this helps. Bud
Jun 08, 2008 | Logitech Wheel Mouse Optical
Hope this helps others. My mouse stopped controlling cursor but buttons worked. Problem was it would not work on a black table. Slip a piece of white paper under it and waaala! It works. I'm thinking optical mouse and dark surface might be an issue.
Oct 10, 2007 | Logitech Cordless Mouse
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
