Question about HP Pavilion F1703 17" LCD Monitor
My hp pavilion f 1730 keeps popping up with auto config screen then goes off after a second or so. It does it intermittent and I cannot find a reason why. At this time it is happening more frequent and I cannot turn it off. I have tried to unplug it restart the pc and checked the select button to see if it was stuck and it is still the same. When it goes into auto config there is a window in the middle of the screen and the rest of the screen darkens a bit. Then it will go off in about a second or so then will pop back on. Sometimes it will pop on and off over and over and sometimes it will be a minute or so. Any help with this will be much appreciated Thank you.
viziks
  • 220 Answers
SOURCE: HP Pavilion F1503 1503 15in Flat. screen blanks out constantly
THis is a problem of the invertor board.If you are technically able you need to disasseble the monitor and resolder components around the red or yellow inverter transformers.
Samir
Posted on Mar 04, 2008
  • 9 Answers
SOURCE: problem on hp monitor
I have a Dell E171FPB monitor that had the same problem with the Main Menu coming up and I thought I would tell you what I did to fix the problem.
1. I shut down the PC.
2. I removed the power cable and video cable from the back of the monitor.
3. I removed the four screws that hold the stand for the monitor and slid the stand off.
4. I then removed the 5 screws that hold the back cover on the monitor.
5. I took two flat blade screw drivers and carefully removed the back cover.
At the bottom of the monitor case, there is a small circuit board the holds the 6 switches for controlling the display.
6. I located the button that calls up the Main Menu. It is the second switch from the left as you are looking at the monitor from the rear.
7. I used a small solder iron and heated up the four prongs in sequence while holding the switch with a pair of needle nose pliers. I had to rotate this process from one prong to the other while all the time applying slight pulling pressure on the switch pulling it away from the circuit board.
8. Once the switch was removed, I put the cover back on and tightened up the five screws.
9. Then I slid the base back in the slot it came from and tightened the four screws.
10. I connected the video and power cable and turned on the PC.
With the switch removed the Main Menu never popped up again and I am so very happy.
Posted on May 30, 2008
  • 10 Answers
SOURCE: The Volume Screen on my monitor keeps popping up
Try putting pressure on the monitor near the buttons. There might be a short or some type of stress pressing the buttons.
Posted on Mar 24, 2009
  • 285 Answers
SOURCE: auto adjustment in progress popping up and
Right click on your desktop, go to properties, and navigate to the settings tab. There, try to set the monitors resolution to the largest available. That should fix your problem. If it doesn't just try some other resolutions until ou find one that works. I hope this helps, Yannick.
Posted on Jun 09, 2009
  • 51 Answers
SOURCE: Volume pop up in the middle of my screen
Sounds like one of the front panel buttons is stuck in - possibly the volume down button. If no buttons work, this could be the reason why. Just a guess. If they all feel OK, it may still be worth pulling the back off, (Without electricuting yourself -DISCONNECT POWER!) remove the PCB board that has the buttons on it, and see if it turns on without the menu. If so, check all buttons, rare but I have seen one that looked fine but with a multimeter it showed it wasnt working. If the screen still displays the menu, Id say there is a bigger problem... HTH
Posted on Jun 15, 2009
Cant display
There might be a problem with the resolution. Check the cover or box of your monitor and find the resolution.
With me the screen goes black when i start any game of higher or lower supported resolution
Sep 23, 2012 | HP 17" 1730 DVI LCD Monitor w/Speakers...
Auto adjustment in progress keeps popping up
Try turning down the brightness on the monitor, sometimes this will fix the issue, if not the problem is in the inverter board and needs a professional to assess it further.
Mar 10, 2012 | HP w1907 LCD Monitor
My auto configuration menu on the monitor keeps popping up and cannot get it to stop what can I do?
auto configuration menu stays on monitor screen constantly while trying to use pc for normaluse.
May 20, 2010 | HP Pavilion F1503 15" LCD Flat Panel...
Hp pavilion a305w won't boot up all the way screen
hi, for select the boot option press F8 on your keyboard.. if your computer have a problem it will pause then it will restart mybe it might have a software or memory problem.. To fix the software problem you only put your recovery disk then start recover.. if the problem still their then you have the hardware problem to fix it you must remove your old memory in the computer then buy a new one...
regards...
Mar 04, 2010 | HP Pavilion a305w (DM181AR) PC Desktop
Screen doesn't come on immediately. Have to press
Checkout your poota power setup configs, just could a malfuction or wrong data entry
If you are talking "New" with a year, take back to point of purchsed with proof of purchase and give them the problem, you want to be online?
Nov 14, 2009 | HP Pavilion dv1000 Notebook
Hp FX 70 monitor keeps shutting off
Sounds like the problem is with the switch itself. No real fix for this.
Both these monitors will work with your desktop without any additional software.
Feb 14, 2009 | HP Pavilion FX70 Monitor
Hp pavilion f1703 problem
Burned out backlight fluorescent backlight.
Jan 04, 2009 | HP Pavilion F1703 17" LCD Monitor
Monitor will not turn off and keeps flashing the words Auto processing
it is not a bad rom. if it was a rom it would constantly act up but it only acts up upon overheating. The solution is difficult but if you open the monitor you can find all of the heatsinks take them of and replace them with bigger ones. or have a fan blowing on it at all time it is active i added bigger heatsinks to my emachine le1799 and it solved this problem of pulling up menu and changing setting by itself and the lack of the ability to turn power of.
Sep 15, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
Screen goes dim intermittently
By defult this is a power saving option. click on yr batt on toolbar to see more options
Dec 05, 2007 | HP Pavilion dv1000 Notebook
HP Pavilion F1703 17" LCD Monitor Logo
104 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
