Question about Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer
PROPER WAY TO START TRIMMER. - Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer
    Sniper:
  • 56 Answers
Pump the primer bulb on the carburetor at least 7 times....set choke lever ( the yellow lever on the air cleaner) to the down start position....pull start handle till it fires....let machine run for about 30 to 45 seconds before you open the throttle to give it a chance to warm up....that's it !!! ;-D
Posted on Jul 17, 2010
How do I replace string trimmer string on 4cycle Troy bilt string ttrimmer
verify that you are using the proper diameter trimmer line, if you have the proper line, replace the head of the trimmer
Sep 14, 2014 | Troy Garden
Do you know what the proper Champion part number is for a Toro 51972 weed trimmer is? This was purchased used and it had a RCJ4 Champion plug in it and I just need to verify that this is the correct plug....
that is the correct spark plug for the unit. i work at a power equipment store where we work on homelites. 90% of the time it wont start or run right is usually carb issues . need to get it rebuild or replaced
Aug 25, 2011 | Toro& Electric String Trimmer
Cut line the proper lengh feed thru until both sides are equal start trimming and the line will not feed
You are describing a problem that could be related to the line being too big for your trimmer. It should say what size trimmer line to use in your manual. It may even say on the piece that the line winds around; but you have to look very close
If your line is .080 it may be too big. You should probably use .065
Jim
Aug 06, 2011 | Homelite Mighty Lite Lawn Trimmer
How do I change the oil filter on my troy built 4 cycle trimmer
You do not have one. Like 4-cycle push mower engines, these are splash lubricated. They lack a full-flow/pressure oiling system. When the oil gets dirty, dump it out and refill to proper specifications. Do this every 20 hours on this trimmer and it will stay happy for a long time.
May 06, 2010 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
I have a Ryobi BC 30 trimmer. It runs fine but
Are you using the proper size line? Check the ends of the spool. It will give you the size you need. Also while you are checking, locate the arrow that shows the direction to wind the line. Hope this is of some help...Lee
Oct 05, 2009 | Garden
I have checked spark plug,spark is strong & blue but still willn't start,what could be coursing trimmer not to start? Should I change fuel mixture,flush fuel lines?
have you checked for the PROPER spark plug gap? this is crucial, and if you have spark and fuel, with the proper GAP it WILL run
Sep 04, 2009 | Ryobi Garden
My trimmer stopped working in the middle of trimming my yard. I now can no longer pull start my Ryobi Trimmer (ry30550). Cord seems to be stuck.
Did you have the proper fuel/oil mix? I just had one that had the piston seize in the cylinder. After taking it apart and loosening the piston, I made sure of the mix and now it runs okay. You may have to get some gaskets that will break during dismantle. Hope this helps...Lee
Aug 22, 2009 | Garden
Ryobi weed trimmer
check the fuek lines for hole and leaks, check the fuel filter and clean if necessary. remove the carbuerator and inspect the gasket; it should be soft and flexible, if it seems hard or brittle replace it. clean the carb with carb cleaner sray (available at any local auto parts store) and compressed air. make sure you get inside the small fuel rail holes. also check the primer bulb for pin holes and proper seating/seal. i
Jul 06, 2008 | Ryobi 15" Electric Factory Reconditioned...
Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer Logo
117 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
