Sometimes when turning on my Toshiba 32AV500U 32" lcd tv the screen will stay blank. I have to turn it off and turn it back on several times before I see something on the screen. Is this a malfunction of the tv or can this be fixed?
I have the same problem. I'm guessing that it is an issue with the power board. I had a similar issue with my Sony KV36HS500 and I installed new chips on the D board to correct the problem.
Posted on Oct 22, 2010
Toshiba 32AV500u turns on and the screen is lit, but I cannot get into the menu or change inputs. Do I just need to change the main board?
Are you sure you are using the remote control it came with?
Buttons on the front of TV usually go bad as no one uses them.
Nov 29, 2015 | Toshiba 32AV500U 32 in. LCD HDTV
My toshiba 32av500u wont turn on
Please check the power outlet. Try changing to a different power outlet. Look for jammed on/off switch on remote or on control panel of TV. If nothing works, better refer it to a qualified service technician.
Jul 19, 2012 | Toshiba 32AV500U 32 in. LCD HDTV
My toshiba 32av500u has no picture completely blak only power little lit in front . turns on green no kind of sound
I have the same problem with the black screen and no sound. Also the green light turns on and off while hitting the power button. Although if i turn it on then off multiple times it eventually turns on and works perfect... Could you do the same thing before it finally quit all together or did yours just happen over night?
-Kenny
Aug 04, 2011 | Toshiba 32AV500U 32 in. LCD HDTV
My toshiba 32 inch lcd tv has green ,red,and purple squigly lines on the screen Model # is 32AV500U
Change Your Regulator on your Color Mixer check the choke beside it the little yellow trasfomator beside.... It maybe damage too....
Sep 21, 2010 | Toshiba 32AV500U 32 in. LCD HDTV
Black screen, no picture
Something wrong with the Inverter boards. Part# 75012523 cost approx $150.
Apr 29, 2010 | Toshiba 32AV500U 32 in. LCD HDTV
I have a Toshiba 32av500u HD LCD TV.NO picture
Its a backlight problem. Common with this model. Under warranty? If not, then its a service shop repair.
Mar 26, 2010 | Toshiba 32AV500U 32 in. LCD HDTV
My Toshiba 32AV500U - the picture went blank.
This problem usually happens when the lamp runs out, verify how old is your TV, lamps have a life spend of aprox. 3 years, most likely you would have to replace the bulb so your TV can start running again!!
Mar 17, 2010 | Toshiba 32AV500U 32 in. LCD HDTV
I have a 32" Toshiba Regza, within the last week, the screen goes blank but still have audio. If I turn the TV off and back on the picture comes back, sometimes the picture stays but other times the...
i know your problem. its an inverter loose connection from CCFL to inverter output. back of your LCD inside the TV. try to remove and re-connect again. be sure no power and AC is unplugged. romsky79@yahoo.com
May 28, 2009 | Toshiba Regza 32LV67U 32 in. LCD HDTV
Televison & Video Logo
118 people viewed this question
Top Televison & Video Experts
Electro Med Services...
