Question about Craftsman Garden
Craftsman 18hp riding mower runs & stalls when engage the blades
I have a Craftsman 18hp riding mower runs & stalls after engaging the blades. Will cut for a brief time about 5-10 minutes then stops. seems hot, allow to cool and you can continue for another 5-10 minutes It's a Sears craftsman II, Model 917-255917 Any thoughts or suggestions?
Had it tuned up and serviced. runs great for the 5-10 minutes. Someone has told me to loosen the belt and that will solve the problem. Open to any and all suggestions.
  • 1,383 Answers
Motor off= deck engaed turn blade should turn motor and belt fairly easy, NO remove the belt from the motor pulley with deck engaged blades should turn freely.
most decks have breaks on the pullies so if the deck is not engaged the break will be on
Posted on Jun 21, 2017
SOURCE: 18hp craftsman riding mower model#917.255913. won't turn left!
You need to get down on the ground and have a look at why it is not turning left. Its as simple as that. A repair will not tell why it is not turning left. Good luck.
Posted on Mar 26, 2009
SOURCE: Craftsman 18.5 riding mower when I engage the
craftsman decks have a positive stop adjustment for the decks. A spring atached to the blade ingadgement arm pulls the tension pully into position if the cable is rusted inside the sleeve it wont put enough pull on the ingadgment pully and thus the blades dont spin full force the belts on the mowers have no adjustments only the pully . second thing is you may want to drop the deck and clean around that pully by scraping any rust off the surface under the pullys slide good luck
Posted on Jun 20, 2009
  • 69 Answers
SOURCE: Blades won't spin on Craftsman II riding mower
get some one to sit on it and holding the brake try engaging the with out getting to close laying down you can see if the linkage is working right....might just be a missed belt wheel.
Posted on Jun 24, 2009
  • 513 Answers
SOURCE: Craftsman riding mower blades will not engage
maybe the safty switch under seat might be starting to go out if that switch doesn't work the blades wont come on at all for safety
Posted on Jun 28, 2009
  • 376 Answers
SOURCE: belt diagram craftsman 917 2733100
Assuming your model number is 917.273100, go to ... Enter the model number, hit search then scroll down to Ground Drive
Posted on Jul 29, 2009
Have a craftsman EZ3 917.272121 mower engine e stalls when blade switch is pulled
If you are sitting on the tractor seat and the engine stalls when engaging the PTO mover blades I would check the switch under the seat.
This seat has a saftey switch to assure that the operator is in a safe location before engaging the the blades. Also if the blades are engaged and the operator leaves the seat the blades will stop. If a young rider with insufficient weight the blades will not engage.
26147998-f1dbbl4o5m3nghfc10hihvyr-4-0.jpg Hope this helps?
Mar 31, 2016 | Craftsman Garden
Engine stalls
could be a stuck pulley or bearing, or debris in the cutting deck. make sure the blades turn freely with mower off and blades dissengaged. If they dont, remove the deck and check all of the pulleys for freeness.
Jun 02, 2014 | Craftsman Garden
I have the Craftsman 20.5 Model 944.609800 42 in mower I can get it to run but when i put it in gear or take my foot off the brake it stalls it also stalls when i engage the mower blades can you help i...
I agree it is the seat switch. This switch will let you start the mower as long as it is in neutral, the brake is set and the mower blades are not engaged. I think it is just two wires, maybe you can jump them together and see if it runs.
Aug 06, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Tractor starts, stalls when blade is engaged, or brake released
you have a safety switch malfunctioning or a transistorized relay not working properly. Go to, this is sears website. It should be able to find and illustrated parts list for your mower.
Sep 28, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Mower stalls when engaging blades
check the safety switch for engager could be bad,, hope this help,, good luck
Aug 08, 2009 | Garden
When I engage the mower blades, the tractor tries to stall name is Keith..and the newer mowers have all kinds of safety switches..and the mowers will shut off..if you put the mower in reverse with the blades i would suspect you have a bad reverse safety switch..i hope this will help..if not please write me back
Jul 09, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
LTX1000 42" 18HP Kohler - Blowing fuse after 2-4 min mowing.
sounds as though you are on the right track
but be sure to check the wiring directly from the electric clutch on the front of the motor back to the switch
a wire could be pinched in the frame and shorting out intermittingly
look around and find those wires and move them around and look for chaffing and tightness
and what you could also do is to unhook the clutch at the connection to it at the front of the motor and engage switch and ride around and see if fuse blows and if not you may have an electric clutch issue
Jun 07, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
148 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
