Question about Belkin Wireless Play Max Router (F7D4301)
I just purchased this router, because we wanted to use it for printer sharing wireless. The router itself works great, as far as connecting to internet. It doe not see my printer. Printer works fine when I plug into either laptop. What to do?
Http://en-us-support.belkin.com/app/answers/detail/a_id/3796/q/routers
Do you see the printer listed in the "Networked USB devices" section?
Posted on Aug 19, 2010
  • 708 Answers
Goto this page
It may help you ...
Posted on Jul 22, 2010
Can the Dell 3110cn have a wireless connection to a desktop?
Your question does not make sense, but I will try. This is a great printer. You have three options. You can purchase an add in wireless card that plugs into the main board in the printer for a stand alone wireless printer. You can connect an Ethernet cable and run it right into your router, and your router will assign it an address. You can also just hook it up via a USB cable to your desktop, and share it, and your desktop. You will want to establish a Home Group if you have not done this yet, with all home computers on your homegroup using the same password. You can do this with any printer, you just need to share it.
Jul 26, 2014 | Dell 3110cn Laser Printer
How to configure 4 Lan + 1 Printer +internet connections
If all your connections are wired, you can use one of the three following solutions.
1. Purchase a router with more then 4 LAN ports on it.
2. If the printer or any of the computers have a wireless network card, then purchase a wireless router and simply connect 4 LAN cables and 1 WLAN.
3. Purchase a hub. Connect 3 computers to the first 3 LAN ports on the router; connect the hub to the fourth LAN port and then connect the last computer and the printer to the hub. In essence both your computer and the printer will share the same IP address (the IP given to the hub) and they should work.
In any of these situations, connect the internet connection to the WAN port of your router.
Thanks,
Pat
Apr 02, 2010 | ASUS RT-N13U IEEE 802.3/3u IEEE 802.11b/g...
Can i hook my printer to this router Linksys wireless-g 2.4ghz
You want to connect a printer to the network.
If you have Ethernet port on the printer then you can connect it to the router with the ethernet cable. IF it is wireless printer then you will need to connect to the wireless network on the printer. In both the cases you will need to set up your printer as a network printer. If you contact the manufacturer of the printer they will tell you how to do it.
If you do not have ethernet port on the printer and it has only USB port and it is not a wireless printer then you will need a print server. You can purchase a wireless print server and you can set it up so that all the computers will be able to print onthe same printer.
If you have only the USB port and you don't want to use print server, then you can connect your printer to one of your computer. Enable File and printer sharing on all the computer. If you go to microsoft.com and search for file and printer sharing, you will get steps to enable file and printer sharing.
If you want to check the wireless settings of the router, you will need to open the set up page of the router .
Click here for more information about router and networks
Mar 21, 2010 | Linksys Wireless-G WRT54G Router
Can i use Bluetooth USB Adapter to connect PC to wireless router?I purchased a new PC that's connected to a wireless router for internet. I want to connect my old PC to the same wireless router. I don't...
Hi, to connect your computer to the wireless network of the router you need to have a wireless adapter. The bluetooth adapter will not work in this case as the router does not communicate with the bluetooth signals.
Purchase a wireless adapter like NETGEAR WG111
Rate it, if it helps.
Regards
Anand
Aug 03, 2009 | Computers & Internet
Need my laptop to communicate wireless to printer
If the printer does not have a built-in network card/print server then there is a couple of ways to do this.
If you have a desktop computer connected to the wireless router with a LAN cable, then connect the printer to the desktop computer and make this printer a shared printer on your network. This means that the desktop computer and printer needs to be on when you want to print from the laptop.
The other way is to purchase a print server, connect the printer to the print server and connect the print server with a LAN cable to the Wireless router.
If you don't have sufficient network ports on the wireless router then you need to purchase a hub. Then connect the hub and wireless router with a LAN cable and then the print server to the hub and other computers to the hub.
Setting up the wireless printing will depend upon which method you want to adopt and I can advise you when further when you are ready.
Aug 02, 2009 | HP Photosmart 3310 Printer
Sharing of internet connection
You need to purchase a router and two network cables to connect the computers. If your computers do not have ethernet connections then you need a wireless router and two wireless network adapters for the computer. II recommend the Linksys W300N or similar for the router and the Linksys WUSB300N or similar for the network card. There are very simple set up instruction with the router and cards.
May 23, 2009 | Microsoft Computers & Internet
Vista 64 cannot print using USR5461 print server
sir chuck, try NETWORK MAGIC it can fix your problem from PRINTER & file sharing and others. It fix network problems regardless of Operating System , windows, linux, mac etc.
May 04, 2009 | U.S. Robotics USRobotics USR5461 Wireless...
Missing password and printer connection
are you using internet router for your wireless network? you download software for your internet router or if you want reset your internet router this will refresh your router and give the manufacturer original settings with "admin" user without password.
you can also connect your printer to other computer and share it so that other computer on your network cab use it. just open the share printer in the network and windows will install it or go to add printer and look your printer using network.
hope this will help you.
Nov 24, 2008 | Linksys Ultra RangePlus Wireless Routr...
Router MI424WR-D
Hi Steven,
You will not be able to setup this printer wirelessly to your router as it is because the printer has no networking capabilities(ethernet or wi-fi). If you want to share the printer throughout the network you need a wireless/wired print server or just enable file and printer sharing on the computer where the lexmark printer is connected the only downside with the second setup is the computer where the printer is connected must stay powered on all the time in order for the rest of the computers ion your network to print compared to the 1st setup with the a print server which is stand alone.
Mar 06, 2008 | Actiontec (5GE583000-01) Router
Trying to network xp pc to wireless laptop
Right click on the drive you want to share. Ex: C:\Vol-xx = name. In the pop up window click Sharing & Security. This needs done to all the drives you want access too. To share a printer. Everyone must have the printer drivers installed. The Pc that has a direct connection to the printer must also Share the printer on the network. Open Printer & Faxes, highlight the printer you want to share. Click File than click Sharing follow windows instructions.
Small suggestion regards to the wireless side of the network. Suggest you setup security so others close too you can not tap into your network. (common).
Feb 14, 2008 | Linksys Wireless-G WRT54G Router
Belkin Wireless Play Max Router (F7D4301) Logo
105 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
