Question about Kichler Lighting 300106OBB Ceiling Fan
New Kichler fan remote control in family room affects older fan in bedroom and vice versa. How do I get it to only control fan in family room?
3 Suggested Answers
  • 257 Answers
SOURCE: We have 2 Hunter ceiling fans with remotes. We can
The remote might have wrong orders. Get the battery out and insert it back and see if the problem solved.
Do you set the dip switchs correctly on the fan and on the remote? Numbers set must be matched. Otherwise, the fan won't work either.
Posted on Aug 12, 2009
  • 3640 Answers
SOURCE: i have a kichler ceiling fan operated by a remote
there should be a switch to reverse it, on the fan itself. have a good day !!
Posted on Jun 05, 2011
2nd remote paired to two fans.
close the door and turn off power to that room and then try again
May 24, 2015 | Televison & Video
Kichler ferron 60" why ceiling fan will only move very slowly remote does not appear to be working
If your Kichler ceiling fan appears to have lost touch with the remote, try the usual routine of removing batteries from the remote, pressing all buttons to eliminate a stuck button as the cause, then reinstalling the old batteries (or new batteries) and testing operation. If no luck, disconnect power at the source, not the fan, pause briefly (to "reset" the fan control) and reconnect power to test operation. If still no luck, the remote receiver in the fan or the remote itself may be defective.
Aug 31, 2014 | Kichler Dryers
How to reverse kichler ceiling fan, UC7206T
Stock Kichler ceiling fan c. 2006, works with replacement remote control 337001WH hand-held unit from Amazon 2013. Started running backwards when two remotes were activated at the same time by accident. Random button pushing on two remotes simultaneously got it to go back to forward. (Apparently original remote hand-held transmitter had forward/reverse setting, but the substitute 337001WH transmitter doesn't. When two transmitters run at the same time, the fwd/rev code may be decoded in the collisions at the receiver. Thank goodness!)
Jun 13, 2012 | Kichler Lighting 300105CTO Ceiling Fan
We have Hunter fans through out our home. The one in the family room has a remote control, can the bedroom one be converted to remote control?
yes they can they sell them at all home depot stores just need to take them apart to put it in good luck
Jul 29, 2011 | Hunter Ceiling Fan - 2053
The two TV are synced. Do I unconnect them? I have one TV in the living room, one TV in the bedroom. Whenever the TV in the bedroom is on, it is on whatever channel is on in the living room. Both remotes...
If you have a dual tuner it is in sigle mode. Go to the front panel on the receiver and press the mode button. This may be behind a push open door based on the receiver you have. If this does not work let me know. Thanks for using Fix Ya.
Aug 15, 2009 | DISH Network IR Remote Control
We have 2 Hunter ceiling fans with remotes. We can get the one in the bedroom to work great but the one in the living room now will not turn on the fan or light. Also when we are trying to get the living...
Aug 11, 2009 | Hunter 52" Ceiling Fan With Light And...
Simultaneous fans
USE A DIFFERENT DIP CODE TO THE SECOND RECEIVER AND REMOTE
Jun 01, 2008 | Hunter 21617 Palermo Brushed Nickel...
Should be controllng one box. is controlling 2 boxes
Unfortunately, there is no solution for this issue.  The remote control sends out an infrared signal, which can be picked up as far as 40' away from the device.  And to make things worse, the signal will reflect off any surface such as glass, mirrors, or even brightly painted walls.
The only way to solve the problem is to block the path of the beam to the other room.  This may require closing a door or drawing heavy drapes closed.
Mar 03, 2008 | Logitech Harmony 880 LCD Remote Control
Kichler Lighting 300106OBB Ceiling Fan Logo
65 people viewed this question
Top Kichler Dryers Experts
Dan Webster
Dan Webster
Are you a Kichler Dryer Expert? Answer questions, earn points and help others
