SOURCE: GE Monogram Side by Side 42" Freezer light is lit on front panel.
The defrost timer is what I think you are asking. It is behind a cover near the light, The timer puts the fridge in defrost ever 6 to 8 hours. If the timer is bad it will stop the cycle of defrost and cause the freezer and the cold food section to warm spoiling the food and increase the freezer temp. Try turning the timer screw clockwise until you hear the fridge compressor stop. If after this listen for a crackling noise that will be the sound of defrost taking place. If doing this starts defrost, you will need to replace the timer.
SOURCE: GE Monogram side by side freezer and refrigerator
HI thanks for your question. the problem could have been, a defrost timer, stuck on defrost. or a failing thermostat. keep a close eye on it, if it stops again. get in touch and we fix the problem. thanks
SOURCE: GE Monogram freezer side working but refrigerator side is not.
Did you clean the condenser? Is the unit FULLY defrosted? Defrost fully!!!!!!
Did he check the amount of gas in the unit? If your unit has low gas...it is in need of more. R12 is expensive.
Check gas level: Shut unit for at least one hour. View compressor. Several pipes...we're looking at the largest. Start the unit. This pipe will begin to frost. If it does not clear to dry, ice or wet...stays frosted...it is low. Get the repair guy back ... but ask how much he'll charge first.
SOURCE: 48" side by side Monogram center between doors getting very hot
this problem is due to low or no air flow aross the condenser coil on your refrigerator. according to sthe model number you listed I'm assuming this is a bult in unit so the condenser coils are going to be on top of the unit. Here are the steps to check and possibly repair your unit:
if the motor is bad you can position a regular house fan blowing into the motor compartment and it will get everything back to normal until the unit is repaired.
Fyi: there is a hot gas freon line that runs between the doors that controls exterior unit moisture and when there is poor or no air flow across the condenser coil it causes this area to get extremely hot. There is no fire hazzard tho.
If I can be of further assistance please ask.Thanks Peyton
SOURCE: GE Monogram freezer not freezing food & refreegiration side not cold enough
first thing to look for is the freezer fan running. then is the air circulating in compartment. blockage is a cause. themostat setting is important.you can leave freezer door open and trigger the door switch.you should feel cold air comming ot. i know it may sound silly check to see if freezer light goes off when shutting door. fan,circulation,cold air input.thermostat,lightoff. good luck
