Question about Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum
Bissell proheat 2x
The brushes will not spin when turned or, nor will it **** the water back from the carpet ver well...(maybe b/c the brushes arent spinning...) any tips?
    President:
  • 1,673 Answers
Check the brush motor, I have had to replace of few of them. If the brushes aren't turning, this could be the problem.
Posted on Apr 18, 2008
Brushes don't rotate on proheat2X,
How to Replace the Belt & Brushroll on Bissell ProHeat 2X ...
? 2:11
https://www.youtube.com/watch?v=Jj_43IHz9U4
Dec 28, 2012 - Uploaded by eVacuumBags
How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... How to Replace Bissell Deep Cleaner Pump Belt orBrush Belt - Duration: 1:44. ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
Brushes Will Not Rotate Deep Clean Essential - YouTube
? 0:53
https://www.youtube.com/watch?v=gbEXY5jkWSc
Apr 9, 2015 - Uploaded by BISSELL
If your machine is turned on and in the upright position yourbrushes will not turn. ... How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
bissell pro heat 2x brushes wont spin Questions & Answers ...
www.fixya.com > Forum > Tags
... bissell pro heat pet 2x and my brushes won't turn or operate... check the belt belts ok brushes won't turn/rotate turn dial on bottom front on the water tank to ...
Feb 03, 2016 | Vacuums
My bissell proheat 2x dual dirtlifter is not succioning very well then the carpet smells
We have several parts here for the Proheat 2X,
Proheat 2X Shampooer Shampooer Parts
It may be a clog in your tank, preventing the water being sucked back up. Check your tank and tubes for clogs or damage. Make sure the brush is still rotating and the belt is not broken too.
800-775-6586
GoodVac com
Feb 26, 2015 | Bissell 2X Proheat 9200 rug cleaner
How can I operate the Bissell PROheat 2X carpet/upholstery cleaner without instructions?
Your solenoid that activates the hand unit is most likely burned up. Bissell 2X machines generally last 4 to 6 uses and a solenoid burns up. This is the only machine that we do not offer repair service for in my store. It is a terribly poor quality design.
BTW, the brushes aren't supposed to turn when the machine is in the upright position.
Sep 18, 2014 | Bissell 9500 ProHeat 2X CleanShot Upright...
No suction and brushes not turning
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
43q3
Sep 27, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
We have a 2x brushes bissell carpet scrubber. Do
heatman101
x
Aug 29, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell proheat 2x carpet cleaner
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will give you all the information you need to fix your Bissell Proheat Vacuum Problem.
heatman101
May 30, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell pro heat 2x multi surface carpet cleaner making spots
maybe there's not enough vacuum or it hasn't been primed enough. I have a proheat that drove me crazy till I started leaving the heat switch on. I get wads of carpet fiber that mat around brush and spit out on the carpet, so I frequently remove them. I'm just wondering if after you empty the water, it may not have built up the suction. Good luck! hope this may be helpful
Jan 13, 2009 | Bissell 1699 ProHeat Clear View Upright...
No cleaning fluid or water comming out of cleaner
not sure of your model but on most of the bissell's ( except there new style) the belt drives the pump and the brush on the bottom. no pump action then no spray action. you probably need a new belt.
Sep 03, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum Logo
571 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
