Question about Polycom SoundStation 2 Systems Non-Expandable Station, Expandable and Mics (PLOYCOM)
HOW DO YOU WIRE ANALOG LINE TO THE PUNCH BOARD? I NEED A WIRING DIAGRAM FOR THIS ISSUE
My phone says "Line in use" but nobody is using it.
Some of my telephones will read "Line In Use" when the phone doesn't detect a dial tone. I like to use an old wired telephone to check whether the problem is with the cordless phone base or the phone line wiring.
First plug in the test phone and check for a dial tone. If there is no dial tone, try a different RJ-11 cable between the phone and the jack. If there is still no dial tone, use the test phone at another jack and check for a dial tone. If you have two jacks with no dial tone, find your incoming telephone service box. If you have a relatively new phone service installation, the service box will have RJ-11 jacks. Plug your test phone into the jack and check for a dial tone. If there is still no dial tone, contact your telephone company. They will repair an outside wiring problem for free. If the service box doesn't have an RJ-11 jack, you'll need to ask your telephone company to test the phone line for you.
If there is a dial tone at another jack or at the service box, you have an inside wiring problem. You can check for loose or broken wires inside of the jack. Most use either screw terminals or a punch-down design. For the screw terminals, strip another section of the unbroken part of the wire, if needed. Secure the wire under the screw. For the punch-down terminal, take off the cover. Then you'll need a tool that is available in most hardware stores in the electrical wiring section. Do not strip the wire; just place it over the correct place in the terminal and push it into the contacts with the tool. Trim off any excess wire with a small pair of small wire cutting pliers, if the excess wire is blocking the cover from fitting back onto the terminal. http://www.lanshack.com/wire_phone_jack.aspx has a good diagram of the wire color and pin assignments. If the wiring is okay at the jack, you'll need to check the rest of the wiring for problems. Since the broken wire might be inside the wall, you may want to have a professional check it out. Your telephone provider's technicians can do this for a fee. If you have a DSL computer line, you should check the DSL filter. If the filter is inside at the jack, you'll need to replace the filter. If it is out at the service box, your telephone company will do the replacement.
If there is a dial tone at the jack with the test phone, check the purchase date on the L401 system. If it is under warranty (1 year usually), contact Motorola. Otherwise, replace your Motorola phone system. It's generally not worth the minimum repair and shipping costs.
I hope this helps.
(I've had dial tone issues after lightning strikes (the DSL filter was damaged), mice eating wires (buried phone line) and due to county road crew/contractors who dug too close to the wire. The first two problems required phone calls to get a technician to fix the outside line. The last one gets fixed by the contractors/phone company as soon as they can.)
Nov 09, 2015 | Motorola L401 DECT 6.0 Digital Cordless...
Wiring diagram for Cocao-Sox Covert Spy Hidden Hat Camera.There are three wires that are attached on the large PC board with a Large IC and next to it there is a smaller IC there is also a heat sink...
Since you have meter, check for this:
Red is mostly used for supply voltage; likely 5VDC.
Black is mostly ground.
Blue is often used for a switched supply line.
Good luck-
Dec 25, 2014 | Televison & Video
WIRING DIAGRAM FOR BRYANT 127ANA036-A
The blue wire from the Ac goes to the y2 on the board for the furnace the yellow and brown goes to c on the board for the furnace and the last wire goes to y1 on the board for the furnace
Jun 16, 2014 | Bryant 462AJC021BA Air Conditioner
Range made a loud popping noise, shortly after the wife said the analog clock on the range had stopped. when we tried to use the range neither the burners nor the oven would start. upon investigation the...
Matt you did not pass us a model number so how are we supposed ot even begin to look for a diagram. Places to start looking for wiring problems.
1. The terminal board connection inside the range for the input power connection.
2. The terminal connections all 4 burners
3. The terminal connections of the 2 bake elements
Usually when you have a sudden short there was a hot wire and only ONE wire will be obviously damaged.
I have nothing to use to look for a wiring duagram at the moment. Usually there is a wiring diagram in a tech data sheep packet inside the control panel or on the back of the Range near one of the legs taped / glued onto the side wall of the cabinet. The packet will be 3 x 5 or 4 x 6 in size.
If you respond with a model number I will see what I can find as far as a wiring diagrm.
Thanks for choosing FixYa,
Kelly
Sep 02, 2011 | GE Kitchen Ranges
I need help wiring in a new speed control on my bosch table saw 4000. The new speed control came with a large black wire, a small black wire and a small blue wire. The large black wire was easy and I...
ts4000 Bosch motor wiring (post #210578, reply #6 of 7)
by emils01 in reply to emils01 [original] on Tue, 09/30/2014 - 15:50
So I called Bosch on Monday and they were well informed and helpful. They emailed me a schematic and explanation of ...
4000 PCB wiring diagram.
1. White AC line cord to white field wire.
2. Black AC line cord to thin blue wire on PCB.
3. Black motor field wire to thin black wire on PCB.
4. Black long, thick wire on PCB to red motor brush wire with push on connector.
Sep 18, 2017 | Bosch 4000 - 07 Electric Table Saws
Mod.59516.603 fan will run in "on" pos. switch to
there is a fix for this, when u purchased new board u have to bypass a wire for a/c hook up only.it should be on the instructions that came with board if not, call dometic and ask for tech help they are very good about helping and can send you the diagram thru an e mail.
Apr 05, 2011 | Dometic Rooftop RV Air Conditioner
Phone less than a year old. no dial tone with inability to call out or receive calls. other phone functions seem to be working
First check if it is the phone or the line. Try replacing the cables. Use another phone (known working) to see if the jack has a dial tone with it. If you have dial tone on another phone and not on this phone with any set of RJ-11 cords, then send the phone to AT&T for repair. It had a 1 year warranty. Contact the customer service at www.telephones.att.com, or call 1 800 222-3111.
Try both phone on other jacks with that line, if available. If the phones work on other jacks but not on the first one, open up the faceplate and check for loose wires. Most either use screws to hold the wires or have keystones with punch downs. If you have the screw type, strip the wire strand if needed and resecure the wire. http://www.lanshack.com/wire_phone_jack.aspx has the diagram of the wiring. The keystone punchdown tool is available at stores like Lowes and Home Depot, among others - in the section for wiring a new home.
Try then on another line, if possible. If the phones work here, then it is a general wiring issue on the other line.
Find where your telephone service comes in and see if the box has RJ-11 connections. Try your phones there. If the phones do not work at other jacks and the service connection is not RJ-11, call your telephone provider. They can test the line and will repair the line free if it is an outside issue. If the issue is inside, check all exposed wiring for damage. Check the jacks as well. If it is a problem inside the wall, you may want a professional. Your telephone service provider will probably fix it for a fee.
I hope this helps.
Feb 04, 2011 | AT&T 1855 Phone
Hello I need to hardwire a tripplite n001-010-bl catse cable to a belkin cat5e keystone jack bel-r6d024-ab5e I do not know the correct wiring configuration to do this. Please advise?
The wiring is done as if you are building your own CAT5e wire. See the following URL: http://www.beginnercode.com/2006/11/09/connecting-network-cable-ends/ . There are other sites. As long as both ends are the same the cable will work (unless you want a crossover connection).
For a PDF version see: http://www.n-tron.com/pdf/cat5ecableschemes.pdf .
I hope this helps.
(Keystone jacks for ethernet come in two types: plug in RJ-45 and punch down the individual wires with the tool. All of the punch down jacks came with a diagram, had the wire arrangement indicated on the unit, and a cheap plastic punch down tool.)
Jan 17, 2011 | Tripp Lite TRIPPLITE N001-010-BL Snagless...
I need help connecting black wire ( hot line wire) from safty switch. It fell off and I can't figuar out where to put it back on the control board.
On the reverse side of the door panel is a wiring diagram. It is in very small print so get a magnifying glass. Find "L1" on the Schematic side of the wiring diagram (the picture more like a road map). Follow the wire thru the door switch and then down to the control board. It will connect to a terminal possibly marked D1, T1, L1 or what ever the diagram says. Please make sure power is off to the heater prior to doing this.
Nov 06, 2009 | Goodman GMS80903BNA Heater
2002 dodge blows 40 amp fuse
try this link www.dodgeram.org/tech/mods/electric/trailer_wire.htm see how i compare to what you have
Jun 30, 2009 | 2008 Dodge Ram Pickup 1500
Lands Phones Logo
50 people viewed this question
Top Polycom Lands Phones Experts
Gerald Ridge
Gerald Ridge
Level 1 Expert
David Burbee
David Burbee
TEKUSER
TEKUSER
Are you a Polycom Lands Phone Expert? Answer questions, earn points and help others
