Question about Epson TM U375 Matrix Label Printer
ERROR ligth flashes three times, pauses, repeats.
Epson TM-U375 printer - ERROR light flashes three times, pauses, repeats.
  • Epson Master
  • 4,737 Answers
Well, the Error light indicates Paper jam and system error/faulty, but the pattern of "error light flashing" is different and little abnormal.
There's no much troubleshooting methods for this printer with the error, but you can try these if you haven't; first please check for paper jam, visible or not visible, please open it up as you do when you install the ribbon and look around for pieces of papers or any foreign particles.
I hope you know how to remove and install the ribbon of your printer, if you have problem please refer to the user manual's pages 2 to... (click here to download the user manual)
If this isn't helpful, turn off the printer, remove the power cord and leave it Off for few minutes again restart the machine and check whether the problem persists or not.
In case both these tips don't help, it must be a fatal system error which i can assure you that it can be repaired, your only option is to call a technician, so that he/she can personally inspect the machine to find out the culprit, there's no possibility from my side without the machine being physically diagnosed by me. I hope you understand the condition.
Anyway, I wish you Good Luck.
Thanks for using FixYa.
Posted on Jul 05, 2010
  • 3 more comments
  • Robert Brown Jul 05, 2010
    The printer has been completely disassembled and reassembled. All surfaces, contacts and switches wiped off and blown out with compressed air. Cycling the power resets the ERROR light and the printer works until the cover is opened to replace the paper. Then the three flashes, pause repeat sequence returns until the power is recycled.
    Strange, very strange.
  • Lebanon Raingam
    Lebanon Raingam Jul 05, 2010
    I am sorry that I couldn't give you the specific solution, but if I were you, I would disassemble the machine and reconnect or reinstall everything. Possibly, internal connection problem, after disassembling, reconnect and re-seat all the connections and check for any twisted or bent connectors or sensors. Try pushing a hard/thicker paper through the paper passage so that it'd clear any possible obstructions.
    These are all that I can assist, I am sorry that i can't place my hands on it. If you can, please call in a Technician, so that he/she can give a try. It's only my suggestion, it's upto you, I only suggest you with what I can.
    Good luck.
    Do you have a service manual for the Epson TM-U375 printer?
  • Lebanon Raingam
    Sorry, I don't have that either, but we use this tips (click here to open) whenever necessary and also check updates from the canon website.
    Good luck.
    After running the self-test as described on the referenced site, the problem seems to be resolved.
Left 1/3 of receipt not printing
Run the cleaning programme on your printer, you will find it in the menu for maintainance.
Nov 14, 2013 | Epson TM-U375 Printer
No puedo instalar la impresora en xp
Necesito mas detalles.Hubo algun mensaje de error?
Nov 02, 2010 | Epson TM-U375 Printer
Error light on the printer flashes twice every couple of seconds
check for the event log if it helps you find the reason
Jul 07, 2009 | Epson TM-U220 Matrix Printer
RE: Epson TM-U200 printer with error (2 Flashes)
programmer can be used. example Makefile is included for LED flashing sample project in ..... but gives no such newsgroup error after specify the title. ...... Uses two-wire serial data communication through printer port. ...... The simple emitter-follower does not have a gain of exactly one,
May 27, 2009 | Epson TM-U220 Matrix Printer
http://www.icscale.com/TECH%20MANUALS/TMU220_TRG_RevD.pdf
Oct 27, 2008 | Epson TM-U220 Matrix Printer
Epsom TM-U220 Error Codes
From the manual its probably one of this item.
-printer temp is too high
-cover is not properly closed
-print head is not in the correct position
-paper cutter is not in the correct position
-paper jam
Try turning off the printer, remove the power cable, turn it on again for 5 seconds to reset it. Connect back power cable, press the feed button and turn it back on. The printer should do a self test, turn it off and on again after the self test. It should make the red light go away.
Epson TM-U375
The Print head ribbon cable is 99% of the problems on printing! Don't worry about any cable coming from the unit to the machine itself. Now there is a Platen bar that the ink ribbon presses on to print. So if is light on one side or both you can adjust that! Go from the back side or the unit, you should see a black box thing. On each side is adjustments, stick a flat head, small, screwdriver in there and turn it. Be careful!!! You do not want to turn to hard it is plastic and will strip!!! That will adjust your platen bar.
If any more problems let me know! I work on these everyday!! Welch Systems Inc. Peoria, IL
Feb 21, 2008 | Epson TM U375 Matrix Label Printer
Error LED keeps flashing
your printer needs to be serviced
http://pos.epson.com/service/servASPP.htm
look for a service provider on this website
Feb 20, 2008 | Epson TM-U220PD Matrix Printer
Receipts
theres no platen gap lever/adjuster on those type of printer which are normally found on dot-matrix printers
Feb 12, 2008 | Epson TM-U220 Matrix Printer
Epson TM U375 Matrix Label Printer Logo
114 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
